› Sviluppare funzionalita su Microsoft Office con VBA › Salvare file excel in pdf tramite vba
Buongiorno a tutti,
Ho sviluppato il seguente codice:
Option Explicit Function ritorno(dato As String) As String Dim caratteri As Variant, strfile As Variant Dim strnome As Variant, snome As String caratteri = Split(dato, "\") strnome = caratteri(UBound(caratteri)) strfile = Split(strnome, ".") snome = strfile(LBound(strfile)) ritorno = snome End Function Sub ProjectBook() Dim sh As Worksheet Dim tSh As Worksheet Dim ws, wb As Workbook Dim wk1 As Workbook Dim sh1 As Worksheet Dim sh2 As Worksheet Dim a As Integer Dim x() As Variant Dim DisplayStatusBar As Boolean Dim NewFileName As String Sheets("X").Select With Sheets("X") .Range(.Cells(4, Columns.Count).End(xlToLeft), .Cells(Rows.Count, 3).End(xlUp)).Select Selection.Copy Sheets("Foglio1").Activate Range("B80").Select Selection.PasteSpecial xlPasteFormats Selection.PasteSpecial xlPasteValuesAndNumberFormats Sheets("Foglio2").Activate Range("B35").Select Selection.PasteSpecial xlPasteFormats Selection.PasteSpecial xlPasteValuesAndNumberFormats Sheets("Foglio3").Activate Range("B45").Select Selection.PasteSpecial xlPasteFormats Selection.PasteSpecial xlPasteValuesAndNumberFormats Sheets("Foglio4").Activate Range("B15").Select Selection.PasteSpecial xlPasteFormats Selection.PasteSpecial xlPasteValuesAndNumberFormats Application.CutCopyMode = False End With x = Array("Foglio1", "Foglio2", "Foglio3", "Foglio4") Application.DisplayAlerts = False For Each ws In ThisWorkbook.Sheets NewFileName = ThisWorkbook.Path & "\" & ws.Name & ".xlsm" a = LBound(x) Do If x(a) = ws.Name Then ws.Copy ActiveWorkbook.Sheets(1).Name = ritorno(NewFileName) ActiveWorkbook.SaveAs Filename:=NewFileName, FileFormat:=xlOpenXMLWorkbookMacroEnabled ActiveWorkbook.Close SaveChanges:=False End If a = a + 1 Loop Until a = UBound(x) + 1 Next Application.ScreenUpdating = True End SubCon il codice allegato, riesco a cancellare tutti i fogli di un file tranne i fogli: "Foglio1, foglio2, foglio3 e foglio4". E salvo i 4 fogli vengono salvati in altrettanti file excel avanti il nome del foglio.
Adesso vorrei creare 4 file pdf che corrispondano ai 4 file excel che ho ottenuto, che devono essere salvati nella stessa dir dei file excel, aventi lo stesso nome dei file excel.
Qualcuno ha qualche idea/consiglio da darmi?
prova ad inserire queste righe di codice
` ActiveWorkbook.ExportAsFixedFormat _ Type:=xlTypePDF, _ Filename:=NewFileName, _ Quality:=xlQualityStandard, _ IncludeDocProperties:=True, _ IgnorePrintAreas:=False, _ OpenAfterPublish:=False`Qual è il punto di avere gusti diversi, se non mostrare che i cervelli lavorano diversamente, che pensiamo diversamente? ( Alan Turing)
( Charles Baudelaire )Grazie Albatros funziona!
Ma io vorrei anche potergli dire quando andare a capo, cioè vorrei poter decidere quando spezzare le colonne di excel, non so se sono stato chiaro.
Espresso90 wrote:Ma io vorrei anche potergli dire quando andare a capo, cioè vorrei poter decidere quando spezzare le colonne di excel, non so se sono stato chiaro
( Charles Baudelaire )Espresso90 wrote:vorrei poter decidere quando spezzare le colonne di excel
Allora devi giocare con le interruzioni di pagina nel foglio Excel e con i margini di pagina.
ActiveSheet.PageSetup.RightMargin = Application.InchesToPoints(4.52755905511811)imposta il margine destro a 11,5 cm. Fai un po' di prove col registratore di macro e poi pulisci la schifezza che ne deriva fin a ottenere un codice accettabile.
Si scusami cerco di spiegarmi meglio, vorrei dare un' interruzione di riga tramite macro, pensi sia possibile?
Espresso90 wrote:pensi sia possibile?
Certo, lo penso
Hai provato a registrare una macro che lo faccia, analizzando il codice prodotto e applicandolo al tuo caso specifico?
Son riuscito a trovare la soluzione.
ActiveWindow.SelectedSheets.HPageBreaks.Add Before:=Cells(intLastRowIndex, strRFQFirtsColumn)Grazie a tutti per il supporto!
