› Sviluppare funzionalita su Microsoft Office con VBA › Errore Strano in PrintOut di un foglio
Buongiorno a tutti!
Fino a prima di aggiungere due if per fare o non fare stampare alcuni valori funzionava tutto!
Ora mi va in errore!
Boh???
Private Sub CommandButtonDownload_Click() Dim IndexMP As Integer Dim WNet As Object Dim N As Integer Dim shPC As Worksheet Set shPC = ThisWorkbook.Sheets("Stampa1") Dim shPP As Worksheet Set shPP = ThisWorkbook.Sheets("Stampa2") Dim shPT As Worksheet Set shPT = ThisWorkbook.Sheets("Stampa3") Dim shTE As Worksheet Set shTE = ThisWorkbook.Sheets("Stampa4") 'Discrimina su quale Multipage si sta Operando per lanciare la Stampa Corretta --> (Contabilità-Paghe-Tecnico) IndexMP = UserForm2.MultiPage1.Value If IndexMP = 0 Then 'Tessera shTE.Range("C12").Value = UserForm2.TextBox1.Value shTE.Range("G12").Value = UserForm2.TextBox156.Value shTE.Range("C15").Value = UserForm2.TextBox157.Value shTE.Range("C17").Value = UserForm2.ComboBoxTT.Value shTE.Range("C19").Value = UserForm2.ComboBoxTOP.Value 'GestioneOption Button If UserForm2.OptionButtonTACSi.Value = True Then shTE.Range("G15").Value = " X - SI" shTE.Range("H15").Value = " - NO" Else shTE.Range("G15").Value = " - SI" shTE.Range("H15").Value = " X - NO" End If If UserForm2.OptionButtonTAllSi.Value = True Then shTE.Range("G17").Value = " X - SI" shTE.Range("H17").Value = " - NO" Else shTE.Range("G17").Value = " - SI" shTE.Range("H17").Value = " X - NO" End If If UserForm2.OptionButtonTTraSi.Value = True Then shTE.Range("G19").Value = " X - SI" shTE.Range("H19").Value = " - NO" Else shTE.Range("G19").Value = " - SI" shTE.Range("H19").Value = " X - NO" End If shTE.Range("C24").Value = UserForm2.TextBox161.Value shTE.Range("C26").Value = UserForm2.TextBox160.Value shTE.Range("C27").Value = UserForm2.TextBox159.Value 'Impostazione Pagina With shTE.PageSetup .PrintTitleRows = "" .PrintTitleColumns = "" .PrintArea = "" .LeftHeader = "" .CenterHeader = "" .RightHeader = "" .LeftFooter = "" .CenterFooter = "" .RightFooter = "" .LeftMargin = Application.InchesToPoints(0.33) .RightMargin = Application.InchesToPoints(0.33) .TopMargin = Application.InchesToPoints(0.5) .BottomMargin = Application.InchesToPoints(0.5) .HeaderMargin = Application.InchesToPoints(0.25) .FooterMargin = Application.InchesToPoints(0.25) .PrintHeadings = False .PrintGridlines = False .PrintComments = xlPrintNoComments .PrintQuality = 300 .CenterHorizontally = True .CenterVertically = True .Orientation = xlLandscape .Draft = False .PaperSize = xlPaperA4 .FirstPageNumber = xlAutomatic .Order = xlDownThenOver .BlackAndWhite = True .Zoom = False .FitToPagesWide = 1 .FitToPagesTall = 1 End With 'Reale Stampa Foglio shTE.PrintOut End Subciao a tutti,
ciao PMC
per evitare questo tipo di inconvenienti, ti conviene imparare ad indentare il codice.
Se provi, sono convinto che l'errore lo trovi da solo.
Buon lavoro
Frank
Purtroppo il problema non è il discorso indentatura!
In allegato il file corretto (come su mio codice VBA)
Tanto è vero che fino a poco fa (senza alcuni campi che vengono caricati) funzionava!
Vedi allegato
You must be logged in to view attached files. -
