Sviluppare funzionalita su Microsoft Office con VBA blocca e sblocca più fogli di lavoro con l'istruzione di VBA.
  • #27522 Score: 0 | Risposta
    tempusfugit
      Buonasera, ho
      creato una macro che mi crea una copia di sicurezza di un file e poi mi blocca anche la copia di backup, vorrei sapere come faccio a dirgli quali fogli mi deve bloccare e quali no?
      Sub Pulisci()
      Dim Prova
          ActiveSheet.Unprotect ("pippo01")
          ActiveSheet.Protect ("pippo01")
          Prova = MsgBox("ATTENZIONE TUTTI I DATI SARANNO CANCELLATI!! Vuoi proseguire ?", vbYesNo)
              If Prova = vbYes Then
          Worksheets("Viaggi").Copy After:=Worksheets("Viaggi")
          Range("D9:D40").Select
          Selection.ClearContents
          Range("E9:E14").Select
          Range("E16").Select
          Range("E18:E22").Select
          Range("E24:E27").Select
          Range("E29:E30").Select
          Range("E32").Select
          Range("E34").Select
          Range("E36").Select
          Range("E38").Select
          Range("E40").Select
          Range("F9:F40").Select
          Range("H9:H14").Select
          Range("H16").Select
          Range("H18:H22").Select
          Range("H24:H27").Select
          Range("H29:H30").Select
          Range("H32").Select
          Range("H34").Select
          Range("H36").Select
          Range("H38").Select
          Range("H40").Select
          Range("I9:I40").Select
          Range("K9:K14").Select
          Range("K16").Select
          Range("K18:K22").Select
          Range("K24:K27").Select
          Range("K29:K30").Select
          Range("K32").Select
          Range("K34").Select
          Range("K36").Select
          Range("K38").Select
          Range("K40").Select
          Range("L9:L40").Select
          Range("N9:N14").Select
          Range("N16").Select
          Range("N18:N22").Select
          Range("N24:N27").Select
          Range("N29:N30").Select
          Range("N32").Select
          Range("N34").Select
          Range("N36").Select
          Range("N38").Select
          Range("N40").Select
          Range("O9:O40").Select
          Range("Q9:Q14").Select
          Range("Q16").Select
          Range("Q18:Q22").Select
          Range("Q24:Q27").Select
          Range("Q29:Q30").Select
          Range("Q32").Select
          Range("Q34").Select
          Range("Q36").Select
          Range("Q38").Select
          Range("Q40").Select
          Range("R9:R40").Select
          Range("T9:T14").Select
          Range("T16").Select
          Range("T18:T22").Select
          Range("T24:T27").Select
          Range("T29:T30").Select
          Range("T32").Select
          Range("T34").Select
          Range("T36").Select
          Range("T38").Select
          Range("T40").Select
          Range("U9:U40").Select
          Range("W9:W14").Select
          Range("W16").Select
          Range("W18:W22").Select
          Range("W24:W27").Select
          Range("W29:W30").Select
          Range("W32").Select
          Range("W34").Select
          Range("W36").Select
          Range("W38").Select
          Range("W40").Select
          Range("X9:X40").Select
      #27526 Score: 0 | Risposta
      alfrimpa
        33 pts
        Non c’è bisogno di usare tutti quei select e selection.
        Si può scrivere direttamente ad esempio
        Range(“A1”).ClearContents
        Per la protezione dei fogli puoi impostare un ciclo For che scansioni i fogli della cartella e protegga o meno il foglio in base al nome dello stesso.
        #27527 Score: 1 | Risposta
          58 pts
          Se ho capito bene, devi creare un ciclo che spazzoli tutti i Fogli e se il nome del Foglio è ="pippo01" allora non bloccarlo (ovviamente vedi tu quali sono i fogli che non vuoi bloccare).
          Un'altra cosa. Noto che per cancellare i dati nei vari intervalli utilizzi
          Range("E16").Select
          eccetera, eccetera ......
          Premesso che non è necessario selezionare l'intervallo per cancellarne il contenuto, potresti (ho preso le prime tre righe per farti l'esempio) fare così:
          Range("D9:D40,E9:E14,E16").ClearContents
          Edit: Alfredo è stato più veloce di me.
          #27528 Score: 1 | Risposta
          alfrimpa
            33 pts
            Mario two is megl che one
          Rispondi a: blocca e sblocca più fogli di lavoro con l'istruzione di VBA.
