Stai vedendo 6 articoli - dal 1 a 6 (di 6 totali)
  • #12386 Score: 0 | Risposta
    Oscar
      45 pts
      Salve il mio problema che la macro funziona benissimo , ma mi salva i File in formato File anzi che in documento di testo
       Dim MyFile As String
            Dim percorso As String
            Dim FileTesto As String
            percorso = ActiveWorkbook.Path
            MyFile = Dir(percorso & "\*.txt")
            Do While MyFile <> ""
               FileTesto = percorso & "\" & MyFile
              'MsgBox FileTesto
               Call ImpFilesTesto(FileTesto)
               MyFile = Dir()
      FileTesto = Mid(FileTesto, 44, 7)
      '------------------------------Scompatto il File
      riga = Cells(Rows.Count, 1).End(xlUp).Row
           Range("a1", "a" & riga).Select
           Selection.TextToColumns Destination:=Range("A1"), DataType:=xlDelimited, _
              TextQualifier:=xlDoubleQuote, ConsecutiveDelimiter:=True, Tab:=False, _
              Semicolon:=False, Comma:=False, Space:=True, Other:=False, FieldInfo _
              :=Array(Array(1, 1), Array(2, 1), Array(3, 1), Array(4, 1), Array(5, 1)), _
              TrailingMinusNumbers:=True
              Range("A1").Select
      '------------------------------------------------------------------------------Ordino il foglio
         Dim Colonna, Col As Variant
            Colonna = Cells(1, Columns.Count).End(xlToLeft).Column
         If Colonna = 1 Then: Col = "A"
         If Colonna = 2 Then: Col = "B"
         If Colonna = 3 Then: Col = "C"
         If Colonna = 4 Then: Col = "D"
         If Colonna = 5 Then: Col = "E"
         If Colonna = 6 Then: Col = "F"
         If Colonna = 7 Then: Col = "G"
         If Colonna = 8 Then: Col = "H"
         If Colonna = 9 Then: Col = "I"
         If Colonna = 10 Then: Col = "J"
              ActiveWorkbook.Worksheets("Dati").Sort.SortFields.Clear
          ActiveWorkbook.Worksheets("Dati").Sort.SortFields.Add Key:=Range("A1"), _
              SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
          With ActiveWorkbook.Worksheets("Dati").Sort
              .SetRange Range("A1", Col & riga)
              .Header = xlNo
              .MatchCase = False
              .Orientation = xlTopToBottom
              .SortMethod = xlPinYin
              .Apply
      '------------------------------Salvo il File in un'altra cartella
      ChDir "C:\Prova\"
      Dim Y, i As Integer
      Colonna = 10
      riga = WorksheetFunction.CountA(Foglio1.Range("A:A"))
      Open FileTesto For Output As #1
      For Y = 1 To riga
      For i = 1 To Colonna
      valore = Cells(Y, i).Value
      If i = Colonna Then
      valore = valore & vbCrLf
      valore = valore & " "
      Print #1, valore;
      Next Y
      Close #1
      '------------------------------Fine salvataggio
      Loop
      Sub ImpFilesTesto(FileTesto As String)
      DoEvents
       Range("A:A") = ""
          Dim nRiga As Long, nvo As Integer, nv As Integer
          Dim nCol As Integer, Testo As String, riga As String
          Range("A:J") = ""
          Sheets("dati").Select
              Open FileTesto For Input As #1
              nRiga = Range("A65000").End(xlUp).Row
              If nRiga = 1 Then
                 nRiga = 0
                 nRiga = 1 'nRiga + 1
      leggiAncora:
              nRiga = nRiga + 1
              If Not EOF(1) Then
                  Line Input #1, riga
                  nvo = 0: nCt = Len(riga): nCol = 0
      scanTesto:
                  nCol = nCol + 1
                  nv = InStr(nvo + 1, riga, ",")
                  If nv = 0 Then
                    Testo = Right(riga$, nCt - nvo)
                    Cells(nRiga, nCol) = Testo$
                    GoTo leggiAncora
                  Testo = Mid(riga$, nvo + 1, (nv - 1) - nvo)
                  nvo = nv
                  GoTo scanTesto
          Close #1
      #12392 Score: 0 | Risposta
        51 pts
        Potresti spiegare cosa vuoi ottenere ? la macro è frutto di una discussione precedente ?
        #12403 Score: 0 | Risposta
        Oscar
          45 pts
          Ciao patel
          la parte dove salva il File lo salva benissimo il problema è che viene salvato come (File) e invece mi vuole come (Documento di testo)
          Nell'allegato puoi vedere il primo è come me lo salva il secondo è come dovrebbe essere
          #12406 Score: 0 | Risposta
          Oscar
            45 pts
            Patel ho risolto  mi è bastato modificare questa riga  grazie per il tuo intervento sei sempre gentilissimo
            FileTesto = Mid(FileTesto, 44, 7) & ".txt"
            #12410 Score: 0 | Risposta
              Volevo dirlo io, che il problema era che mancava l'estensione, ma poi avevo visto solo
              e quindi evidentemente l'estensione c'era. Sono stato a pensarci un po' poi ho fatto altro.
              Mi era sfuggita purtroppo  l'istruzione successiva:
              Altrimenti sollevavo subito l'osservazione.
              Questa riga comunque è un errore concettuale enorme quando il nome del file txt selezionato ha una lunghezza diversa da quella prestabilita; tu vuoi recuperare solo il nome del file a partire dall'ultimo slash? la strada da percorrere è un'altra. Usa InstrRev.
              #12417 Score: 0 | Risposta
              Oscar
                45 pts
                Si in effetti prima  avevo fatto la seguente modifica , ma poi spostando la cartella non andava più quindi sono passato alla successiva
                FileTesto = Mid(FileTesto, 40, 7) & ".txt"
                la seconda in qualunque posizione si trovi va sempre bene h'hè prima non ci avevo proprio pensato
                grazie vecchio frac
                FileTesto = Right(FileTesto, 11)
              Rispondi a: Ordinare File Txt
