Private Sub CMDVOLUME_Click()
Dim valore1 As Double
Dim valore2 As Double
Dim valore3 As Double
Dim valore4 As Double
Dim valore5 As Double
Dim valore6 As Double
Dim valore7 As Double
Dim valore8 As Double
Dim valore9 As Double
Dim valore10 As Double
Dim valoretot As Double
Dim LATO1 As Double
Dim LATO2 As Double
Dim LATO3 As Double
Dim LBLFM1tot As Double
Dim minore As Double, maggiore As Double, medio As Double
' calcolo il volume con la seguente operazione
lblvol1 = Round(((Val(TEXTL1.Text) * Val(TEXTP1.Text) * Val(TEXTH1.Text)) / 5000) * Val(Textpkg1.Text), 2)
lblvol2 = Round(((Val(TEXTL2.Text) * Val(TEXTP2.Text) * Val(TEXTH2.Text)) / 5000) * Val(Textpkg2.Text), 2)
lblvol3 = Round(((Val(TEXTL3.Text) * Val(TEXTP3.Text) * Val(TEXTH3.Text)) / 5000) * Val(Textpkg3.Text), 2)
lblvol4 = Round(((Val(TEXTL4.Text) * Val(TEXTP4.Text) * Val(TEXTH4.Text)) / 5000) * Val(Textpkg4.Text), 2)
lblvol5 = Round(((Val(TEXTL5.Text) * Val(TEXTP5.Text) * Val(TEXTH5.Text)) / 5000) * Val(Textpkg5.Text), 2)
lblvol6 = Round(((Val(TEXTL6.Text) * Val(TEXTP6.Text) * Val(TEXTH6.Text)) / 5000) * Val(Textpkg6.Text), 2)
lblvol7 = Round(((Val(TEXTL7.Text) * Val(TEXTP7.Text) * Val(TEXTH7.Text)) / 5000) * Val(Textpkg7.Text), 2)
lblvol8 = Round(((Val(TEXTL8.Text) * Val(TEXTP8.Text) * Val(TEXTH8.Text)) / 5000) * Val(Textpkg8.Text), 2)
lblvol9 = Round(((Val(TEXTL9.Text) * Val(TEXTP9.Text) * Val(TEXTH9.Text)) / 5000) * Val(Textpkg9.Text), 2)
lblvol10 = Round(((Val(TEXTL10.Text) * Val(TEXTP10.Text) * Val(TEXTH10.Text)) / 5000) * Val(Textpkg10.Text), 2)
valore1 = CSng(Replace(lblvol1.Caption, ".", ","))
valore2 = CSng(Replace(lblvol2.Caption, ".", ","))
valore3 = CSng(Replace(lblvol3.Caption, ".", ","))
valore4 = CSng(Replace(lblvol4.Caption, ".", ","))
valore5 = CSng(Replace(lblvol5.Caption, ".", ","))
valore6 = CSng(Replace(lblvol6.Caption, ".", ","))
valore7 = CSng(Replace(lblvol7.Caption, ".", ","))
valore8 = CSng(Replace(lblvol8.Caption, ".", ","))
valore9 = CSng(Replace(lblvol9.Caption, ".", ","))
valore10 = CSng(Replace(lblvol10.Caption, ".", ","))
valoretot = Round(valore1 + valore2 + valore3 + valore4 + valore5 + valore6 + valore7 + valore8 + valore9 + valore10, 2)
LBLVOLtot = valoretot
valoretot = CSng(Replace(LBLVOLtot.Caption, ".", ","))
' inseriti 3 numeri in 3 textbox determino i valori dal piu grande al piu piccolo (o viceversa) e calcolo il volumetrico
' mi sono fermato qui per evitare di ripetere per 10 volte la stessa cosa dichiarando altre variabili
LATO1 = Val(TEXTL1.Text)
LATO2 = Val(TEXTP1.Text)
LATO3 = Val(TEXTH1.Text)
If LATO1 < LATO2 Then
If LATO1 < LATO3 Then
If LATO3 < LATO2 Then
minore = LATO1
maggiore = LATO2
medio = LATO3
LBLFM1.Caption = ((minore + medio) * 2) + maggiore
minore = LATO3
medio = LATO1
maggiore = LATO2
If LATO2 < LATO3 Then
minore = LATO2
medio = LATO3
maggiore = LATO1
medio = LATO2
minore = LATO3
maggiore = LATO1
dim valore(1 to 10) as Double, valoretot as double, lato(1 to 3) as Double, minore as Double, maggiore as Double, medio as Double, LBLFM1tot As Double |
for i =1 to 10 lblvol(i) = Round(((Val(TEXTL(i).Text) * Val(TEXTP(i).Text) * Val(TEXTH(i).Text)) / 5000) * Val(Textpkg(i).Text), 2) next i for ii = 1 to 10 valore(ii) = CSng(Replace(lblvol(ii).Caption, ".", ",")) next ii |
for i =1 to 10
next i
for ii = 1 to 10
next ii
ecc.. ecc.. ecc
Dim valore(1 To 10) As Double, valoretot As Double, lato(1 To 3) As Double, minore As Double, maggiore As Double, medio As Double, LBLFM1tot As Double
Dim i As Integer
Dim ii As Integer
'calcolo il volume con la seguente operazione
For i = 1 To 10
'lblvol1 = Round(((Val(TEXTL1.Text) * Val(TEXTP1.Text) * Val(TEXTH1.Text)) / 5000) * Val(Textpkg1.Text), 2)
'lblvol2 = Round(((Val(TEXTL2.Text) * Val(TEXTP2.Text) * Val(TEXTH2.Text)) / 5000) * Val(Textpkg2.Text), 2)
'lblvol3 = Round(((Val(TEXTL3.Text) * Val(TEXTP3.Text) * Val(TEXTH3.Text)) / 5000) * Val(Textpkg3.Text), 2)
'lblvol4 = Round(((Val(TEXTL4.Text) * Val(TEXTP4.Text) * Val(TEXTH4.Text)) / 5000) * Val(Textpkg4.Text), 2)
'lblvol5 = Round(((Val(TEXTL5.Text) * Val(TEXTP5.Text) * Val(TEXTH5.Text)) / 5000) * Val(Textpkg5.Text), 2)
'lblvol6 = Round(((Val(TEXTL6.Text) * Val(TEXTP6.Text) * Val(TEXTH6.Text)) / 5000) * Val(Textpkg6.Text), 2)
'lblvol7 = Round(((Val(TEXTL7.Text) * Val(TEXTP7.Text) * Val(TEXTH7.Text)) / 5000) * Val(Textpkg7.Text), 2)
'lblvol8 = Round(((Val(TEXTL8.Text) * Val(TEXTP8.Text) * Val(TEXTH8.Text)) / 5000) * Val(Textpkg8.Text), 2)
'lblvol9 = Round(((Val(TEXTL9.Text) * Val(TEXTP9.Text) * Val(TEXTH9.Text)) / 5000) * Val(Textpkg9.Text), 2)
'lblvol10 = Round(((Val(TEXTL10.Text) * Val(TEXTP10.Text) * Val(TEXTH10.Text)) / 5000) * Val(Textpkg10.Text), 2)
For ii = 1 To 10
Next ii
'valore1 = CSng(Replace(lblvol1.Caption, ".", ","))
'valore2 = CSng(Replace(lblvol2.Caption, ".", ","))
'valore3 = CSng(Replace(lblvol3.Caption, ".", ","))
'valore4 = CSng(Replace(lblvol4.Caption, ".", ","))
'valore5 = CSng(Replace(lblvol5.Caption, ".", ","))
'valore6 = CSng(Replace(lblvol6.Caption, ".", ","))
'valore7 = CSng(Replace(lblvol7.Caption, ".", ","))
'valore8 = CSng(Replace(lblvol8.Caption, ".", ","))
'valore9 = CSng(Replace(lblvol9.Caption, ".", ","))
'valore10 = CSng(Replace(lblvol10.Caption, ".", ","))
minore = LATO1
maggiore = LATO2
medio = LATO3
minore = LATO3
medio = LATO1
maggiore = LATO2
minore = LATO2
medio = LATO3
maggiore = LATO1
medio = LATO2
minore = LATO3
maggiore = LATO1
Dim x(1 To 4) As Integer, y(1 To 10) As Integer
Dim i As Integer
For i = 1 To 10
x1 = "textl" & (i)
x2 = "textp" & (i)
x3 = "texth" & (i)
x4 = " textpkg" & (i)
y(i) = Funcion.Controls("lblvol" & (i))
y(i) = Round(((Val(x1) * Val(x2) * Val(x3)) / 5000) * Val(x4), 2)
For i = 1 To 10
y(i) = Funcion.Controls("lblvol" & (i)).Caption
valore(i) = CSng(Replace(y(i), ".", ","))
LATO1 = Val(textl1.Text)
minore = LATO1
maggiore = LATO2
medio = LATO3
minore = LATO3
medio = LATO1
maggiore = LATO2
minore = LATO2
medio = LATO3
maggiore = LATO1
medio = LATO2
minore = LATO3
maggiore = LATO1
For i = 1 To 10
Dim x(1 To 4) As Integer, y(1 To 10) As Double
Dim i As Integer
For i = 1 To 10
x1 = UserForm2.Controls("TEXTL" & (i))
x2 = UserForm2.Controls("TEXTP" & (i))
x3 = UserForm2.Controls("TEXTH" & (i))
x4 = UserForm2.Controls("TEXTPKG" & (i))
UserForm2.Controls("lblvol" & (i)) = y(i)
For i = 1 To 10
Sub mia() Dim miatxt as variant Set miatxt = TextBox1 MsgBox (miatxt) End Sub |
