Sub PrintRicevuta(numeroricevuta As String)
'Mail merge e stampa su stampante di default
'On Error GoTo ErrorHandler
' open template in Word
Dim filepath, SQLStmt, WorkbookName As String
Dim WordApp As Word.Application
Dim WordDoc As Word.Document
Set WordApp = New Word.Application
filepath = ThisWorkbook.Path
WorkbookName = ThisWorkbook.FullName
Debug.Print filepath, numeroricevuta
With WordApp
.Visible = True
Set WordDoc = .Documents.Open(filepath & "stamparicevuta.docx")
SQLStmt = "SELECT * FROM `Ricevute$` WHERE [Numero] = " & numeroricevuta
'MailMerge selected records from table to Word document
With WordDoc
With .MailMerge
.MainDocumentType = wdFormLetters
.OpenDataSource Name:=WorkbookName, _
ConfirmConversions:=False, ReadOnly:=False, LinkToSource:=True, _
AddToRecentFiles:=False, PasswordDocument:="", PasswordTemplate:="", _
WritePasswordDocument:="", WritePasswordTemplate:="", Revert:=False, _
Format:=wdOpenFormatAuto, Connection:="rangericevute", _
SQLStatement:=SQLStmt, SQLStatement1:="", _
SubType:=wdMergeSubTypeAccess
.SuppressBlankLines = True
With .DataSource
.FirstRecord = wdDefaultFirstRecord
.LastRecord = wdDefaultLastRecord
'Selezionare la stampante. Per questa funzione, la stampa
'viene diretta sulla stampante di rete SAMSUNG ML-8610
' Bisogna trovare il nome completo di windows per questa stampante
Dim sPrinter As String
Dim sDefaultPrinter As String
Debug.Print "Default printer: ", Application.ActivePrinter
'store default printer
sDefaultPrinter = Application.ActivePrinter
'Get complete name using known characters
sPrinter = GetPrinterFullName("Stylus Office")
If sPrinter = vbNullString Then ' no match
Debug.Print "No match"
.Application.ActivePrinter = sPrinter
Debug.Print "Temp printer: ", .Application.ActivePrinter
'execute merge and Print with temp printer
.Destination = wdSendToPrinter
.Execute Pause:=False
.Application.ActivePrinter = sDefaultPrinter ' restore default printer
WordDoc.Close SaveChanges:=False
WordApp.Quit
ErrorHandlerExit:
ErrorHandler:
If Err = 429 Then
'word is not running; open word with CreateObject
Set appWord = CreateObject(Class:="Word.Application")
Public Function GetPrinterFullName(Printer As String) As String
' This function returns the full name of the first printerdevice that matches Printer.
' Full name is like "PDFCreator on Ne01:" for a English Windows and like
' "PDFCreator sur Ne01:" for French.
' Created: Frans Bus, 2015. See
Const HKEY_CURRENT_USER = &H80000001
Dim regobj As Object
Dim aTypes As Variant
Dim aDevices As Variant
Dim vDevice As Variant
Dim sValue As String
Dim v As Variant
Dim sLocaleOn As String
' get locale "on" from current activeprinter
v = Split(Application.ActivePrinter, Space(1))
sLocaleOn = Space(1) & CStr(v(UBound(v) - 1)) & Space(1)
' connect to WMI registry provider on current machine with current user
Set regobj = GetObject("WINMGMTS:{impersonationLevel=impersonate}!\.
ootdefault:StdRegProv")
' get the Devices from the registry
regobj.EnumValues HKEY_CURRENT_USER, "SoftwareMicrosoftWindows NTCurrentVersionDevices", aDevices, aTypes
' find Printer and create full name
For Each vDevice In aDevices
' get port of device
regobj.GetStringValue HKEY_CURRENT_USER, "SoftwareMicrosoftWindows NTCurrentVersionDevices", vDevice, sValue
' select device
If InStr(vDevice, Printer) > 0 Then
'If Left(vDevice, Len(Printer)) = Printer Then ' match!
' create localized printername
GetPrinterFullName = vDevice & sLocaleOn & Split(sValue, ",")(1)
Exit Function
' at this point no match found
GetPrinterFullName = vbNullString
'in un modulo
'seleziona una stampante e la rende temporaneamente predefinita
Type PRINTER_INFO_1
flags As Long
pPDescription As Long
pName As Long
pComment As Long
End Type
Type PRINTER_INFO_5
pPrinterName As Long
pPortName As Long
Attributes As Long
DeviceNotSelectedTimeout As Long
TransmissionRetryTimeout As Long
End Type
Private Const PRINTER_ENUM_LOCAL = &H2
Private Declare Function Enumprinters Lib "winspool.drv" Alias "EnumPrintersA"_
(ByVal flags As Long, ByVal Name As String, ByVal Level As Long, pPrinterEnum _
As Any, ByVal cdBuf As Long, pcbNeeded As Long, pcReturned As Long) As Long
Private Declare Sub MoveMemory Lib "KERNEL32" Alias "RtlMoveMemory" (Dest As _
Any, Source As Any, ByVal length&)
Private Declare Function SetDefaultPrinter Lib "winspool.drv" Alias _
"SetDefaultPrinterA" (ByVal pszPrinter As String) As Long
Sub Main()
Dim original_printer As String, new_printer As String, i As Integer
original_printer = ActivePrinter
new_printer = EnumPrinter
If new_printer = "" Then Exit Sub
SetDefaultPrinter new_printer
'ActiveSheet.PrintOut '<<<<<< decommentare per stampare il foglio attivo
i = InStrRev(original_printer, " ", InStrRev(original_printer, " ")) - 1
SetDefaultPrinter Left(original_printer, i)
Private Function EnumPrinter()
Dim rc As Long, i As Integer, nSizeOfStruct As Long, Level As Long
Dim pPrinterEnum() As Byte, pcbNeeded As Long, pcReturned As Long
Dim PI_1() As PRINTER_INFO_1
Dim Msg As String
Dim v As Variant
Dim ChgP As Integer
Level = 1
rc = Enumprinters(PRINTER_ENUM_LOCAL, vbNullString, Level, ByVal 0&, 0, pcbNeeded, pcReturned)
ReDim pPrinterEnum(pcbNeeded - 1) As Byte
rc = Enumprinters(PRINTER_ENUM_LOCAL, vbNullString, Level, _
pPrinterEnum(0), pcbNeeded, pcbNeeded, pcReturned)
ReDim PI_1(pcReturned - 1) As PRINTER_INFO_1
nSizeOfStruct = Len(PI_1(0))
Msg = "Digita il numero della nuova stampante predefinita:" & vbCrLf
For i = 0 To pcReturned - 1
Call MoveMemory(PI_1(i), pPrinterEnum(nSizeOfStruct * i), _
nSizeOfStruct)
Msg = Msg & i + 1 & " > " & gGetStr(PI_1(i).pName, 64) & vbCrLf
v = InputBox(Msg)
If Trim(v) = "" Then EnumPrinter = "": Exit Function
ChgP = v
EnumPrinter = gGetStr(PI_1(ChgP - 1).pName, 64)
Private Function gGetStr(pString As Long, nBytes As Long) As String
ReDim BufArray(nBytes) As Byte
Call MoveMemory(BufArray(0), ByVal pString, nBytes)
gGetStr = gGetStrBuffer(StrConv(BufArray(), vbUnicode))
Private Function gGetStrBuffer(sString As String) As String
If InStr(sString, vbNullChar) Then
gGetStrBuffer = Left$(sString, InStr(sString, vbNullChar) - 1)
gGetStrBuffer = sString
End Function |
Dim Msg As String
Dim v As Variant
Dim ChgP As Integer
Level = 1
rc = Enumprinters(PRINTER_ENUM_LOCAL, vbNullString, Level, pPrinterEnum(0), pcbNeeded, pcbNeeded, pcReturned)
Call MoveMemory(PI_1(i), pPrinterEnum(nSizeOfStruct * i), nSizeOfStruct)
v = gGetStr(PI_1(i).pName, 64)
If InStr(LCase(v), "samsung") > 0 Then Exit For
If EnumPrinter = "" Then Exit Function
EnumPrinter = gGetStr(PI_1(i).pName, 64)
Level = 1
rc = Enumprinters(PRINTER_ENUM_LOCAL OR PRINTER_ENUM_NETWORK, vbNullString, Level, ByVal 0&, 0, pcbNeeded, pcReturned)
