Sub prova()
Dim rng As Range
Dim cel As Range
Dim LR As Long
Dim ur As Long
LR = Sheets("Foglio1").Cells(Rows.Count, 3).End(xlUp).Row
Set rng = Sheets("Foglio1").Range("C10:C" & LR)
For Each cel In rng
ur = Sheets("Foglio2").Cells(Rows.Count, 1).End(xlUp).Row
If cel.Value <> "" And cel.Value <> "Codice" Then
Sheets("Foglio2").Cells(ur + 1, 1) = cel.Value
Sheets("Foglio2").Cells(ur + 1, 2) = cel.Offset(0, 1).Value
Sheets("Foglio2").Cells(ur + 1, 3) = cel.Offset(1, 5).Value
Sheets("Foglio2").Cells(ur + 1, 4) = cel.Offset(1, 6).Value
Next cel
Sub prova()
Dim i As Integer
Dim uRiga As Integer
Dim rng As Range
Dim cel As Range
Dim LR As Long
Dim ur As Long
For Each cel In rng
Next cel
uRiga = Sheets("Foglio2").Cells(Rows.Count, 1).End(xlUp).Row
For i = uRiga To 2 Step -1
If Left(Range("a" & i).Value, 1) <> "A" Then
Range("a" & i).EntireRow.Delete
If Left(Range("a" & i).Value, 1) <> "A" |
Sub elimina_righe()
Dim Intervallo As Range
Dim Righe, R, Colonne, C, FL As Boolean
Sheets("Foglio2").Select
Set Intervallo = ActiveSheet.UsedRange
Righe = Intervallo.Rows.Count
Colonne = Intervallo.Columns.Count
For R = Righe To 1 Step -1 ' questo è il ciclo modificato
FL = False
For C = 1 To Colonne
If Intervallo(R, C) <> "" Then
FL = True
If FL = False Then
Intervallo(R, 1).EntireRow.Delete
Sub prova()
Dim i As Integer
Dim rng As Range
Dim cel As Range
Dim LR As Long
Dim ur As Long
For Each cel In rng
Next cel
If Mid(Range("a" & i).Value, 2, 1) <> "." Then
Sub prova()
Dim i As Integer
Dim rng As Range
Dim cel As Range
Dim LR As Long
Dim ur As Long
For Each cel In rng
Next cel
Sub processing()
Dim dict As Object, re As Object
Dim ac As Range, c As Range, cel As Range
Dim s As String
Dim i As Long, iRow As Long, j As Long
Dim v As Variant, o As Variant
Dim last_address As String
Dim codice As String, desc_breve As String, desc_estesa As String, u_m As String, prezzo As String
Sheets("Foglio2").Range("A2:E5000").ClearContents
Sheets("Foglio1").Select
Set dict = CreateObject("Scripting.Dictionary")
Set re = CreateObject("VBScript.RegExp")
re.Global = True
re.IgnoreCase = False 'ignore case
'Codici ammessi: A, B, C, CE, D, E, F, G, H, I, IG, IT, L, M, O, P, Q, R, SL, SIC, T.
re.Pattern = "(?:C[AE]).|(?:I[GT]).|SL.|SIC.|[ABCDEFGHILMOPQRT]."
For Each ac In Range("C:C").SpecialCells(xlCellTypeConstants)
If re.test(ac) Then
s = Trim(ac)
i = i + 1
dict.Add i, Array(s, ac.Address) 'dict(i) = contenuto cella, indirizzo cella
dict.Add i + 1, Array("FINE", Range(dict(i)(1)).Offset(10).Address)
iRow = 2
For j = 1 To i
Set c = Range(Range(dict(j)(1)), Range(dict(j + 1)(1)).Offset(-1, 6))
codice = dict(j)(0)
s = ""
For Each cel In c.Columns(3).Cells
If cel.MergeArea.Count = 4 And LCase(cel) <> "descrizione" Then
If Trim(cel) <> "" Then
s = s & Trim(cel) & vbCrLf
last_address = cel.Address
desc_estesa = s
o = Split(desc_estesa, vbLf)
If Right(codice, 1) Like "[0-9]" Then
desc_breve = o(2)
desc_breve = o(3)
u_m = Range(last_address).Offset(1, 1)
If u_m = "" Then
u_m = Join(Application.Transpose(c.Columns(7)))
u_m = Trim(u_m)
u_m = Trim(Replace(u_m, "U.M.", ""))
prezzo = Range(last_address).Offset(1, 2)
If prezzo = "" Then
prezzo = Join(Application.Transpose(c.Columns(8)))
prezzo = Trim(prezzo)
prezzo = Trim(Replace(prezzo, "PREZZO", ""))
With Sheets("Foglio2")
.Cells(iRow, "A") = codice
.Cells(iRow, "B") = desc_breve
.Cells(iRow, "C") = desc_estesa
.Cells(iRow, "D") = u_m
.Cells(iRow, "E") = prezzo
iRow = iRow + 1
Cells.WrapText = False
Range("A1").Select
MsgBox "Finito!", vbInformation
