Declare Function GetSystemMetrics Lib "user32" (ByVal nIndex As Long) As Long '--------------------------------- Public Function GetSR() As Variant GetSR = Array(GetSystemMetrics(0), GetSystemMetrics(1)) End Function '----------------- Sub ResizeForm_R1() ' Adjusts userform size to compensate for screen resolution changes. 'Call function to get actual screen resolution varSize = GetSR resX = varSize(0) resY = varSize(1) 'Determine ratio of actual screen resolution to 'the original or base resolution. RatioX = resX / UserForm1.Width RatioY = resY / UserForm1.Height RY = 3.5 RX = 1.66 Fact = 1 ' 1 = full screen 'Adjust userform magnification and size. UserForm1.Zoom = 100 * RatioX / 1.66 / Fact UserForm1.Width = UserForm1.Width * RatioX / RX / Fact UserForm1.Height = UserForm1.Height * RatioY / RY / Fact UserForm1.Show End Sub |
Public Declare Function GetDesktopWindow Lib "user32.dll" () As Long
Public Declare Function GetWindowRect Lib "user32.dll" ( _
ByVal hwnd As Long, _
ByRef lpRect As RECT) As Long
Public Type RECT
Left As Long
Top As Long
Right As Long
Bottom As Long
End Type
Sub AdattaForm(frm As String)
Dim hwndDesk As Long
Dim DeskRect As RECT
Dim DeskH As Long, DeskW As Long
Dim ProjW As Integer, ProjH As Integer
Dim OrigW As Integer, OrigH As Integer
Dim r As Integer, nz As Integer
Dim i As Integer, frmIndex As Integer
For i = 0 To UserForms.Count
If UserForms(i).Name = frm Then
frmIndex = i
Exit For
ProjW = 1600 'imposto la risoluzione di progettazione
ProjH = 900
hwndDesk = GetDesktopWindow
GetWindowRect hwndDesk, DeskRect
DeskW = DeskRect.Right - DeskRect.Left
DeskH = DeskRect.Bottom - DeskRect.Top
OrigW = UserForms(frmIndex).Width
OrigH = UserForms(frmIndex).Height
UserForms(frmIndex).Width = (OrigW * DeskW) / ProjW
UserForms(frmIndex).Height = (OrigH * DeskH) / ProjH
nz = (UserForms(frmIndex).Zoom * DeskH) / ProjH
NewZoom = IIf(nz > 400, 400, IIf(nz < 10, 10, nz))
UserForms(frmIndex).Zoom = NewZoom
Unload Me
'by scossa e marius
Dim nWd As Double
With Me
nWd = Application.Width / .Width
.Top = Application.Top
.Left = Application.Left
.Width = Application.Width / 2
.Height = Application.Height / 2
.Zoom = (Round(nWd, 1) * 100) / 2
Dim controlli As Control
For Each controlli In Me.Controls
If TypeOf controlli Is MSForms.Frame Then
controlli.Font.Size = 11
controlli.FontSize = 10
Next controlli |
Application.WindowState = xlMaximized
Zo_W = Application.Width / UserForm1.Width
Zo_H = Application.Height / UserForm1.Height
If Zo_W < Zo_H Then
mZoom = Zo_W
mZoom = Zo_H
mZoom = mZoom * 1 ' < < = = = = = 1 è un fattore di aggiustamento cambia al variare della risoluzione
mH = UserForm1.Height
mW = UserForm1.Width
UserForm1.Width = UserForm1.Width * mZoom
UserForm1.Height = UserForm1.Height * mZoom
Zo_W = UserForm1.Width / mW
Zo_H = UserForm1.Height / mH
For Each ctr In UserForm1.Controls
ctr.Width = ctr.Width * Zo_W
ctr.Height = ctr.Height * Zo_H
ctr.Font.Size = ctr.Font.Size * Zo_H * 1
ctr.Top = ctr.Top * Zo_H
ctr.Left = ctr.Left * Zo_W
Dim x As Double, h As Double, alta As Double, larga As Double
Dim xa As Double, ha As Double, rap1 As Double, rap2 As Double
x = Application.UsableWidth
h = Application.UsableHeight
alta = Me.Height
larga = Me.Width
If x > 597 Then
xa = x / 597
ha = h / 309
With Me
.Top = 1
.Left = 1
.Height = Application.UsableHeight + 140
.Width = Application.UsableWidth
If .Height > alta Then rap1 = ha Else rap1 = 1 / ha
If .Width > larga Then rap2 = xa Else rap2 = 1 / xa
For Each ctr In Me.Controls
ctr.Width = ctr.Width * rap2
ctr.Height = ctr.Height * rap1
ctr.Font.Size = ctr.Font.Size * rap2
ctr.Top = ctr.Top * rap1
ctr.Left = ctr.Left * rap2
Unload Me
Const ZoomStep = 1
Dim Grow As Single
Sub ctlResize(ByVal ctl As MSForms.Control)
With ctl
.Height = .Height / Grow
.Width = .Width / Grow
.Left = .Left / Grow
.Top = .Top / Grow
Unload Me
Private Sub ListBox1_Click()
Private Sub SpinButton1_Change()
Dim oldZ As Long
With Me
oldZ = Zoom
.Zoom = .SpinButton1.Value
Grow = Zoom / oldZ
.Height = .Height * Grow
.Width = .Width * Grow
ctlResize .SpinButton1
ctlResize .Label1
With .Label1
.Font.Size = .Font.Size / Grow
With Me.SpinButton1
.Value = Me.Zoom
.SmallChange = ZoomStep
