Sub auto_open()
For Each cn In ThisWorkbook.Connections 'elimina connessioni
cn.Delete
Sheets("Foglio1").Visible = True
Sheets("Foglio3").Visible = True
Application.ScreenUpdating = False 'refresh schermo
Sheets(Array("Foglio1", "eCAV")).Select 'cancella fogli
Range("A1").Select
Range(Selection, ActiveCell.SpecialCells(xlLastCell)).Select
Selection.ClearContents
Sheets("foglio3").Select 'azzera [importa] tabella modello
Cells.Select
Selection.Copy
Sheets("eCAV").Select
Cells.Select
ActiveSheet.Paste
Dim fd As FileDialog 'seleziona cartella
Set fd = Application.FileDialog(msoFileDialogFolderPicker)
Dim CartellaSelezionata As Variant
With fd
If .Show = -1 Then
For Each CartellaSelezionata In .SelectedItems
miaCartella = CartellaSelezionata
Else: Exit Sub
Sheets("foglio1").Select
Dim MyFile As String
MyFile = Dir(miaCartella & "*.dmo")
Do While MyFile <> ""
With ActiveSheet.QueryTables.Add(Connection:= _
"TEXT;" & miaCartella & "" & MyFile, Destination:=Range("A1"))
.Name = "SOM59054_NP2216552_BFA_REP1_1"
.FieldNames = True
.RowNumbers = False
.FillAdjacentFormulas = False
.PreserveFormatting = True
.RefreshOnFileOpen = False
.RefreshStyle = xlInsertDeleteCells
.SavePassword = False
.SaveData = True
.AdjustColumnWidth = True
.RefreshPeriod = 0
.TextFilePromptOnRefresh = False
.TextFilePlatform = 1252
.TextFileStartRow = 1
.TextFileParseType = xlDelimited
.TextFileTextQualifier = xlTextQualifierDoubleQuote
.TextFileConsecutiveDelimiter = True
.TextFileTabDelimiter = True
.TextFileSemicolonDelimiter = False
.TextFileCommaDelimiter = False
.TextFileSpaceDelimiter = True
.TextFileColumnDataTypes = Array(1, 1, 1, 1, 1, 1)
.TextFileTrailingMinusNumbers = True
MyFile = Dir
Loop
For i = 2 To 30 'imposta distanza tra report
If Left(Cells(1, 1).Value, 10) = Left(Cells(1, i).Value, 10) Then
dist = i - 1
Exit For
For i = 3 To 100 'offset verticale
If IsNumeric(Trim(Cells(i, 3))) Then
Offset = i
Exit For
k = 0 'valori misurati
For j = 0 To Cells(Columns.Count).End(xlToLeft).Column Step dist
y = 1
For i = Offset To Cells(Rows.Count, 1).End(xlUp).Row
With Sheets("eCAV")
If IsNumeric(Cells(i, 2 + j)) And Cells(i, 2 + j) <> "" And Application.IsText(Cells(i - 1, 2 + j).Value) Then
.Cells(25 + k, 5 + y) = Cells(i, 2 + j)
y = y + 1
k = k + 1
Next j
y = 1
With Sheets("eCAV")
If IsNumeric(Cells(i, 2)) And Cells(i, 2) <> "" And Application.IsText(Cells(i - 1, 2).Value) Then
.Cells(6, 5 + y) = Cells(i - 1, 2) 'nomi quote
.Cells(7, 5 + y) = Cells(i, 3) 'nominali
.Cells(8, 5 + y) = Cells(i, 3) + Cells(i, 5) 'valori max toll
.Cells(9, 5 + y) = Cells(i, 3) + Cells(i, 6) 'valori min toll
y = y + 1
m = y
k = 0 'valori misurati quote strane
y = m
With Sheets("eCAV")
If (IsNumeric(Cells(i, 2)) And IsNumeric(Cells(i - 1, 2))) Or (IsNumeric(Cells(i, 2)) And Trim(Cells(i - 1, 2).Value = "")) Then
y = y + 1
' If IsNumeric(Cells(i, 4)) And Cells(i, 1) Like "PROFILE" Then
' .Cells(25 + k, 5 + y) = Cells(i, 4 + j)
' y = y + 1
' End If
k = k + 1
Next j
y = m 'nominali quote strane
With Sheets("eCAV")
If (IsNumeric(Cells(i, 2)) And IsNumeric(Cells(i - 1, 2))) Or (IsNumeric(Cells(i, 2)) And Cells(i - 1, 2).Value = "") Then
.Cells(6, 5 + y) = Cells(i, 1) 'nomi quote
y = y + 1
stringa = Cells(1, 1)
s = Split(stringa, "")
Sheets("eCAV").Cells(3, 1) = s(3)
Dim a As String 'autofit colonne 'autofit colonne di tutti i fogli
Dim b As Worksheet
a = ActiveSheet.Name
For Each b In ActiveWorkbook.Worksheets
b.Activate
Cells.EntireColumn.AutoFit
Next b
Cells.Select
Range("A76").Activate
Selection.ColumnWidth = 10
Sheets("Foglio1").Visible = False
Sheets("Foglio3").Visible = False
Application.ScreenUpdating = True 'refresh schermo
Dim f As Object, ff As Object
Const myPath = "C:..............."
Set ff = CreateObject("Scripting.FileSystemObject").GetFolder(myPath).Files
For Each f In ff
If Right(f, 4) = ".txt" Then
With ActiveSheet.QueryTables.Add(Connection:="TEXT;" & f, Destination:=[A1])
.FieldNames = True
.RowNumbers = False
.SaveData = True
.RefreshPeriod = 0
Next |
'seleziona cartella
If fd.Show = 0 Then Exit Sub
miaCartella = fd.SelectedItems(1) |
Sub test()
Dim cn As Variant, mia_cartella As String, ff As Object, f As Object
Dim i As Integer, j As Integer, k As Integer, y As Integer, offset As Integer
Dim sh As Worksheet, dist As Integer, m As Integer
cn.Delete
'refresh schermo
'cancella fogli
For Each sh In Sheets(Array("Foglio1", "eCAV"))
sh.Cells.ClearContents
[a1].Select
Sheets("foglio3").Cells.Copy Destination:=Sheets("ecav").[a1]
'seleziona cartella
mia_cartella = fd.SelectedItems(1)
Set ff = CreateObject("Scripting.FileSystemObject").GetFolder(mia_cartella).Files
For Each f In ff
With ActiveSheet.QueryTables.Add(Connection:="TEXT;" & f, Destination:=[a1])
.FieldNames = True
.RowNumbers = False
.SaveData = True
.RefreshPeriod = 0
.TextFileSpaceDelimiter = False
For i = 2 To 30
dist = i - 1
Exit For
'offset verticale
For i = 3 To 100
offset = i
Exit For
'valori misurati
k = 0
y = 1
For i = offset To Cells(Rows.Count, 1).End(xlUp).Row
With Sheets("eCAV")
y = y + 1
k = k + 1
Next j
y = 1
With Sheets("eCAV")
y = y + 1
m = y
y = m
With Sheets("eCAV")
y = y + 1
' If IsNumeric(Cells(i, 4)) And UCase(Cells(i, 1)) = "PROFILE" Then
' y = y + 1
' End If
k = k + 1
Next j
With Sheets("eCAV")
y = y + 1
Sheets("eCAV").[A3] = Split([a1], "")(3)
'autofit colonne
For Each sh In ActiveWorkbook.Worksheets
sh.Cells.EntireColumn.AutoFit
Sheets("foglio1").[A76].ColumnWidth = 10
