Sub BABA()
If Range("F31") = Range("F21") Then
Range("F31").Select
Selection.ClearContents
If Range("F32") = Range("F21") Then
Range("F32").Select
If Range("F33") = Range("F21") Then
Range("F33").Select
If Range("F34") = Range("F21") Then
Range("F34").Select
If Range("F35") = Range("F21") Then
Range("F35").Select
If Range("F36") = Range("F21") Then
Range("F36").Select
If Range("F37") = Range("F21") Then
Range("F37").Select
If Range("F38") = Range("F21") Then
Range("F38").Select
If Range("F39") = Range("F21") Then
Range("F39").Select
If Range("F40") = Range("F21") Then
Range("F40").Select
If Range("F41") = Range("F21") Then
Range("F41").Select
If Range("F42") = Range("F21") Then
Range("F42").Select
If Range("F43") = Range("F21") Then
Range("F43").Select
If Range("F44") = Range("F21") Then
Range("F44").Select
If Range("F45") = Range("F21") Then
Range("F45").Select
Sub PROVA()
Dim I As Integer
For I = 1 To 45
If Range("F30") = Range("F21") Then
Range("F30").Select
Next I
