Sub ParseHTMLRegEx()
Dim wb As Workbook
Dim ws As Worksheet
Dim cella As Range
Dim ie As Object
Dim ie_Element As Object
Dim nLoops As Long
Dim re As Object
Dim reMatch As Variant
Dim nItems As Long
Dim j As Long
Dim nStart As Long
Dim nEnd As Long
Dim sTesto As String
Dim sParsed As String
Dim sToken As String
Dim sPatt As String
Const sWeb As String = "####://scossavr.altervista.org/Downloads/Excel/filebuono.html" 'sostituire con il tuo indirizzo web
Const sID = "_ContentPlaceHolder1_GridView1_ct"
On Error GoTo parseHTML_Error
Set wb = ThisWorkbook
Set ws = wb.Worksheets("Foglio2")
Set re = CreateObject("vbscript.regexp")
Set ie = CreateObject("InternetExplorer.Application")
With ie
.Silent = True
.Visible = True
.navigate sWeb
Application.Wait Now + TimeValue("0:00:03")
nLoops = 0
Do Until .ReadyState = 4
DoEvents
nLoops = nLoops + 1
If nLoops > 50000 Then
Err.Raise vbObjectError + 513, , "Il server non risponde"
Loop
sTesto = .document.body.innerHTML
ie.Quit
With re
.Global = True
.IgnoreCase = True
'--------- NUM ----------------------------
Set cella = ws.Cells(ws.Cells(Rows.Count, 1).End(xlUp).Row + 1, 1)
sPatt = "GridView1_ctldd_NUM>"
.Pattern = sPatt
Set reMatch = .Execute(sTesto)
With reMatch
nItems = .Count
If nItems > 0 Then
For j = 0 To nItems - 1
nStart = .item(j).Firstindex + .item(j).Length + 1
nEnd = InStr(nStart, sTesto, "", vbTextCompare)
sParsed = Mid(sTesto, nStart, nEnd - nStart)
cella.Value = sParsed
Set cella = cella.Offset(1, 0)
'--------- cognome ----------------------------
Set cella = ws.Cells(ws.Cells(Rows.Count, 2).End(xlUp).Row + 1, 2)
sPatt = "GridView1_ctldd_cognome>"
.Pattern = sPatt
With reMatch
nItems = .Count
If nItems > 0 Then
'End If
'--------- nome ----------------------------
Set cella = ws.Cells(ws.Cells(Rows.Count, 3).End(xlUp).Row + 1, 3)
sPatt = "GridView1_ctldd_nome>"
.Pattern = sPatt
With reMatch
nItems = .Count
If nItems > 0 Then
'If sParsed <> "" Then
'--------- inizio ----------------------------
Set cella = ws.Cells(ws.Cells(Rows.Count, 4).End(xlUp).Row + 1, 4)
sPatt = "GridView1_ctldd_inizio>"
.Pattern = sPatt
With reMatch
nItems = .Count
If nItems > 0 Then
'--------- termine ----------------------------
Set cella = ws.Cells(ws.Cells(Rows.Count, 5).End(xlUp).Row + 1, 5)
sPatt = "GridView1_ctldd_termine>"
.Pattern = sPatt
With reMatch
nItems = .Count
If nItems > 0 Then
parseHTML_Error:
Set cella = Nothing
Set ws = Nothing
Set wb = Nothing
Set re = Nothing
Set reMatch = Nothing
Set ie = Nothing
If Err.Number <> 0 Then
MsgBox "Error: " & Err.Description, vbCritical, "ERRORE"
MsgBox "Elaborazione Terminata", vbInformation
Sub ParseHTML()
Dim wb As Workbook
Dim ws As Worksheet
Dim cella As Range
Dim ie As Object
Dim nLoops As Long
Dim re As Object
Dim nItems As Long
Dim j As Long
Dim nStart As Long
Dim nEnd As Long
Dim sPatt As String
Const sWeb As String = "h##p://scossavr.altervista.org/Downloads/Excel/filebuono.html" 'sostituire con il tuo indirizzo web
Const sID = "_ContentPlaceHolder1_GridView1_ct" ' attivare al posto di quella sotto
'Const sID = "footer"
Set cella = ws.Cells(ws.Cells(Rows.Count, 1).End(xlUp).Row, 1)
With ie
.Silent = True
.Visible = False 'True
.navigate sWeb
nLoops = 0
DoEvents
nLoops = nLoops + 1
Loop
'sTesto = .document.body.innerHTML
For Each ie_Element In .document.getElementsByTagName("SPAN")
Debug.Print ie_Element.ID
Select Case True
Case InStr(1, ie_Element.ID, "_NUM", vbBinaryCompare) > 0
sTesto = ie_Element.innerText
j = j + 1
cella.Offset(j, 0).Value = sTesto
Case InStr(1, ie_Element.ID, "_cognome", vbBinaryCompare) > 0
cella.Offset(j, 1).Value = sTesto
Case InStr(1, ie_Element.ID, "_nome", vbBinaryCompare) > 0
cella.Offset(j, 2).Value = sTesto
Case InStr(1, ie_Element.ID, "_inizio", vbBinaryCompare) > 0
cella.Offset(j, 3).Value = sTesto
Case InStr(1, ie_Element.ID, "_termine", vbBinaryCompare) > 0
cella.Offset(j, 4).Value = sTesto
End Select
ie.Quit
parseHTML_Error:
Set cella = Nothing
Set ws = Nothing
Set wb = Nothing
Set re = Nothing
Set ie = Nothing
