Sub inserimentodati()
Dim a As String
Dim b As String
Dim c As String
c = [B9]
For a = 7 To 450
If Foglio20.Cells(a, 7).Value = Foglio22.Cells(9, 2).Value Then
For b = c To 31
If Foglio20.Cells(b, 7).Value = Foglio22.Cells(1, 2).Value Then
'Foglio20.Cells(b, 11).Value = Foglio22.Cells(11, 2).Value
'Foglio20.Cells(b, 12).Value = Foglio22.Cells(13, 2).Value
'Foglio20.Cells(b, 13).Value = Foglio22.Cells(15, 2).Value
'Foglio20.Cells(b, 14).Value = Foglio22.Cells(17, 2).Value
'Foglio20.Cells(b, 15).Value = Foglio22.Cells(19, 2).Value
Foglio20.Cells(b, 12).Value = "ok"
Next b
Next a
Dim a As Integer, b As Integer, c As Integer
c = [B9]
With Foglio22
Foglio20.Select
For a = 7 To 450
If Cells(a, 7) = .Cells(9, 2) Then
For b = c To 31
If Cells(b, 7) = .Cells(1, 2) Then
Cells(b, 11) = .Cells(11, 2)
Cells(b, 12) = .Cells(13, 2)
Cells(b, 13) = .Cells(15, 2)
Cells(b, 14) = .Cells(17, 2)
Cells(b, 15) = .Cells(19, 2)
Cells(b, 12) = "ok"
Next b
Next a
Dim a As Integer, b As Integer, c As String
c = [B9]
With Foglio22
Foglio20.Select
For a = 7 To 450
For b = c To 31 'il ciclo b parte dal valore della cella (a, 7)
Next b
Next a
