Dim ur As Long
ur = Sheets("REGISTRO TELEFONATE").Range("A" & Rows.Count).End(xlUp).Row + 1
With ActiveCell.EntireRow
Sheets("REGISTRO TELEFONATE").Range("B" & ur).Value = .Cells(1, 3) & " " & .Cells(1, 2)
Sheets("REGISTRO TELEFONATE").Range("C" & ur).Value = .Cells(1, 4)
Sheets("REGISTRO TELEFONATE").Range("D" & ur).Value = Time
Sheets("REGISTRO TELEFONATE").Range("E" & ur).Value = Date
Sheets("REGISTRO TELEFONATE").Range("F" & ur).Value = TextBox2
If TextBox1 <> "" Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = TextBox1
ElseIf ToggleButton1.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton1.Caption
ElseIf ToggleButton2.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton2.Caption
ElseIf ToggleButton3.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton3.Caption
ElseIf ToggleButton4.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton4.Caption
ElseIf ToggleButton5.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton5.Caption
ElseIf ToggleButton6.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton6.Caption
ElseIf ToggleButton7.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton7.Caption
ElseIf ToggleButton8.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton8.Caption
ElseIf ToggleButton9.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton9.Caption
ElseIf ToggleButton10.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton10.Caption
ElseIf ToggleButton11.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton11.Caption
ElseIf ToggleButton12.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton12.Caption
ElseIf ToggleButton13.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton13.Caption
ElseIf ToggleButton14.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton14.Caption
ElseIf ToggleButton15.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton15.Caption
ElseIf ToggleButton16.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton16.Caption
ElseIf ToggleButton17.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton17.Caption
ElseIf ToggleButton18.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton18.Caption
ElseIf ToggleButton19.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton19.Caption
ElseIf ToggleButton20.Value = True Then
Sheets("REGISTRO TELEFONATE").Range("A" & ur).Value = ToggleButton20.Caption
Unload Me
