Private Declare Function midiOutOpen Lib "winmm.dll" (lphMidiOut As Long, ByVal uDeviceID As Long, ByVal dwCallback As Long, ByVal dwInstance As Long, ByVal dwFlags As Long) As Long
Private Declare Function midiOutClose Lib "winmm.dll" _
(ByVal hMidiOut As Long) As Long
Private Declare Function midiOutShortMsg Lib "winmm.dll" _
(ByVal hMidiOut As Long, _
ByVal dwMsg As Long) As Long
Private Declare Sub Sleep Lib "Kernel32" (ByVal dwMilliseconds As Long)
Dim hMidiOut As Long
Public lanote As Long
Sub PlayMIDI(voiceNum, noteNum, Duration)
Dim Note As Long
midiOutClose hMidiOut
midiOutOpen hMidiOut, 0, 0, 0, 0
midiOutShortMsg hMidiOut, RGB(192, voiceNum - 1, 127)
lanote = 12 + CLng(noteNum)
Note = RGB(144, lanote, 127)
midiOutShortMsg hMidiOut, Note
Sleep (Duration)
The PlayMIDI Sub procedure accepts three arguments, and plays a single note. The argument are:
• voiceNum: A number from 1-128 that represents the instrument sound. Here’s a list of the MIDI voice numbers.
• noteNum: A number that indicates the note to play. For reference, C is 0, 12, 24, 36, etc. C# is 1, 13, 25, 37, etc.
• Duration: A number that indicates how long to play the note, in milliseconds (1,000 equals 1 second).
To play around with this, I set up a worksheet that has a 4-column list of notes. A lookup table provides the actual note letters for the values in column B. In the figure, I have it set up to generate random notes and durations. Then, a simple macro plays the song.
Then, a simple macro plays the song represented by the worksheet data.
Sub TestMidi()
Dim r As Long
ActiveSheet.Calculate
For r = 2 To Application.CountA(Range("A:A"))
Call PlayMIDI(Cells(r, 1), Cells(r, 2), Cells(r, 3))
Next r
