Private Sub cb_ricercanome_Click()
cb_ricercaordine = ""
Dim riga As String
Dim testo As String
Dim Visto As String
Sheets("storico").Select
Range("A1").Select
riga = cb_ricercanome.ListIndex + 2
Cells(riga, 1).Select
testo = cb_ricercanome.Text
If testo <> "" Then
n_ordine = Worksheets("storico").Range("a" & riga)
tx_nome = Worksheets("storico").Range("b" & riga)
tx_cognome = Worksheets("storico").Range("c" & riga)
tx_via = Worksheets("storico").Range("d" & riga)
tx_cap = Worksheets("storico").Range("e" & riga)
tx_citta = Worksheets("storico").Range("f" & riga)
cb_nazione = Worksheets("storico").Range("g" & riga)
tx_tel = Worksheets("storico").Range("i" & riga)
tx_mail1 = Worksheets("storico").Range("j" & riga)
cb_copie = Worksheets("storico").Range("af" & riga)
Select Case Visto
Case Worksheets("storico").Range("k" & riga) = "X"
CheckBox1.Value = True
Case Worksheets("storico").Range("l" & riga) = "X"
CheckBox2.Value = True
Case Worksheets("storico").Range("m" & riga) = "X"
CheckBox3.Value = True
Case Worksheets("storico").Range("n" & riga) = "X"
CheckBox4.Value = True
Case Worksheets("storico").Range("o" & riga) = "X"
CheckBox5.Value = True
Case Worksheets("storico").Range("p" & riga) = "X"
CheckBox6.Value = True
Case Worksheets("storico").Range("q" & riga) = "X"
CheckBox7.Value = True
Case Worksheets("storico").Range("r" & riga) = "X"
CheckBox8.Value = True
Case Worksheets("storico").Range("s" & riga) = "X"
CheckBox9.Value = True
Case Worksheets("storico").Range("t" & riga) = "X"
CheckBox10.Value = True
Case Worksheets("storico").Range("u" & riga) = "X"
CheckBox11.Value = True
Case Worksheets("storico").Range("v" & riga) = "X"
CheckBox12.Value = True
Case Worksheets("storico").Range("w" & riga) = "X"
CheckBox13.Value = True
Case Worksheets("storico").Range("x" & riga) = "X"
CheckBox14.Value = True
Case Worksheets("storico").Range("y" & riga) = "X"
CheckBox15.Value = True
Case Worksheets("storico").Range("z" & riga) = "X"
CheckBox16.Value = True
Case Worksheets("storico").Range("aa" & riga) = "X"
CheckBox17.Value = True
Case Worksheets("storico").Range("ab" & riga) = "X"
CheckBox18.Value = True
Case Worksheets("storico").Range("ac" & riga) = "X"
CheckBox22.Value = True
Case Worksheets("storico").Range("ae" & riga) = "SI"
CheckBox19.Value = True
End Select
