Sub ProvaLuca()
Dim MioRangeL
Dim MiaCellaW1
Dim DaAggiungere()
Dim Vettore()
Dim Indice As Integer
Dim Index2 As Integer
Dim MiaCella As Range
Dim Trovato As Boolean
Dim UltimaCella As Range
Dim PrimaCella As Range
Set MiaCellaW1 = Range("A2")
Set MioRangeL = Range(MiaCellaW1.Offset(1, 0), MiaCellaW1.Offset(1, 0).End(xlToRight).End(xlDown))
MioRangeL.Select
ActiveWorkbook.Worksheets("Foglio2").Sort.SortFields.Clear
ActiveWorkbook.Worksheets("Foglio2").Sort.SortFields.Add Key:=Intersect(MioRangeL, MioRangeL.Columns(1)) _
, SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
xlSortTextAsNumbers
ActiveWorkbook.Worksheets("Foglio2").Sort.SortFields.Add Key:=Intersect(MioRangeL, MioRangeL.Columns(2)) _
, SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
ActiveWorkbook.Worksheets("Foglio2").Sort.SortFields.Add Key:=Intersect(MioRangeL, MioRangeL.Columns(3)) _
With ActiveWorkbook.Worksheets("Foglio2").Sort
.SetRange MioRangeL
.Header = xlYes
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
Set UltimaCella = MioRangeL.Cells(1, 1)
ReDim DaAggiungere(1 To 3, 0)
Set PrimaCella = MioRangeL.Cells(1, 1)
Do
ReDim Vettore(1 To 2, 0)
Do
Set MiaCella = UltimaCella
MiaCella.Select
If UBound(Vettore, 2) = 0 Then
ReDim Vettore(1 To 2, 1)
Vettore(1, 1) = MiaCella.Offset(0, 2)
Trovato = False
For Indice = 1 To UBound(Vettore, 2)
If Vettore(1, Indice) = MiaCella.Offset(0, 2) Then
Trovato = True
Exit For
If Not Trovato Then
ReDim Preserve Vettore(1 To 2, UBound(Vettore, 2) + 1)
Vettore(1, UBound(Vettore, 2)) = MiaCella.Offset(0, 2)
Set MiaCella = MiaCella.Offset(1, 0)
Set UltimaCella = MiaCella
Loop While MiaCella = MiaCella.Offset(-1, 0)
Set MiaCella = PrimaCella
Do
Vettore(2, Indice) = False
Next Indice
Do
MiaCella.Select
Vettore(2, Indice) = True
Next Indice
Loop While MiaCella.Offset(-1, 1) = MiaCella.Offset(0, 1)
If Vettore(2, Indice) = False Then
ReDim Preserve DaAggiungere(1 To 3, UBound(DaAggiungere, 2) + 1)
DaAggiungere(1, UBound(DaAggiungere, 2)) = MiaCella.Offset(-1, 0)
DaAggiungere(2, UBound(DaAggiungere, 2)) = MiaCella.Offset(-1, 1)
DaAggiungere(3, UBound(DaAggiungere, 2)) = Vettore(1, Indice)
Next Indice
'Set MiaCella = MiaCella.Offset(1, 0)
Set PrimaCella = UltimaCella.Offset(1, 0)
Loop While MiaCella.Offset(-1, 0) = MiaCella
Loop While MiaCella.Offset(1, 0) <> ""
' MsgBox "pippo"
UltimaCella.Select
For Indice = 1 To UBound(DaAggiungere, 2)
For Index2 = 1 To 3
UltimaCella.Offset(Indice - 1, Index2 - 1) = DaAggiungere(Index2, Indice)
Range(UltimaCella.Offset(-1, 0), UltimaCella.Offset(-1, 2)).Copy
With Range(UltimaCella, UltimaCella.Offset(UBound(DaAggiungere, 2) - 1, 3 - 1))
.Select
.PasteSpecial _
Paste:=xlPasteFormats, Operation:=xlNone, _
SkipBlanks:=False, Transpose:=False
With .Interior
.Pattern = xlSolid
.PatternColorIndex = xlAutomatic
.Color = 65535
.TintAndShade = 0
.PatternTintAndShade = 0
Set MioRangeL = Range("A2")
Set MioRangeL = Range(MioRangeL.Offset(1, 0), MioRangeL.Offset(1, 0).End(xlToRight).End(xlDown))
MioRangeL.Select
xlSortTextAsNumbers
.SetRange MioRangeL
.Header = xlYes
.MatchCase = False
.Apply
MioRangeL.Select
xlSortTextAsNumbers
.SetRange MioRangeL
.Header = xlYes
.MatchCase = False
.Apply
