Set CellaIni = Activecell.Offset(0,0) 'sono nella cella D10 CellaIni.Select With Range(ActiveCell(0, -3), ActiveCell(300, -3)).Select For Each c In Selection If c.Value = "[Africa settentrionale]" Then ActiveCell.Resize(1, 14).Insert Shift:=xlDown ActiveCell.Value = "TOTALE" ActiveCell.Offset(0, 2).Formula = Sum([Activecell.Columns & X], [Activecell.offset(-1,0)]) 'come si scrive la somma? ActiveCell.Offset(0, 2).Select Selection.AutoFill Destination:=Range(ActiveCell.Offset(0, 2), ActiveCell.Offset(0, 14)), Type:=xlFillDefault End If Next End With |
