Option Compare Text
Public rig As Long
Dim i As Integer
Dim ur As Long
ur = Worksheets("Foglio1").Cells(Rows.Count, 1).End(xlUp).Row
For i = 1 To 7
Worksheets("Foglio1").Cells(ur + 1, i) = Me.Controls("TextBox" & i).Value
Worksheets("Foglio1").Cells(ur + 1, 8) = Me.ComboBox1.Value
If Me.OptionButton1 = True Then
Worksheets("Foglio1").Cells(ur + 1, 9) = "SI"
Worksheets("Foglio1").Cells(ur + 1, 9) = "NO"
Worksheets("Foglio1").Cells(ur + 1, 10) = Me.TextBox9.Value
For i = 10 To 11
Worksheets("Foglio1").Cells(ur + 1, i + 1) = Me.Controls("TextBox" & i).Value
Worksheets("Foglio1").Cells(ur + 1, 14) = Me.TextBox13.Value
Worksheets("Foglio1").Cells(ur + 1, 15) = Me.TextBox14.Value
Dim i As Integer
Dim cli As String
'Dim rig As Long
Call CreaElencoUnivoco
cli = UserForm2.ComboBox1.Value
rig = Trovariga(Worksheets("Foglio1").Range("a1:a10"), cli)
For i = 1 To 7
Me.Controls("TextBox" & i).Value = Worksheets("Foglio1").Cells(rig, i)
Me.ComboBox1.Value = Worksheets("Foglio1").Cells(rig, 8)
Me.TextBox9.Value = Worksheets("Foglio1").Cells(rig, 10)
Me.TextBox10.Value = Worksheets("Foglio1").Cells(rig, 11)
Me.TextBox11.Value = Worksheets("Foglio1").Cells(rig, 12)
Me.TextBox13.Value = Worksheets("Foglio1").Cells(rig, 14)
Me.TextBox14.Value = Worksheets("Foglio1").Cells(rig, 15)
If Worksheets("Foglio1").Cells(rig, 9) = "SI" Then
Me.OptionButton1.Value = True
Me.OptionButton2.Value = True
Private Sub CommandButton4_Click()
UserForm1.Hide
Dim ctrl As Control
For Each ctrl In UserForm1.Controls
If TypeName(ctrl) = "TextBox" Or TypeName(ctrl) = "ComboBox" Then
ctrl.Value = ""
Next ctrl
Private Sub CommandButton5_Click()
Dim j As Integer
For j = 1 To 7
Worksheets("Foglio1").Cells(rig, j) = Me.Controls("TextBox" & j).Value
Next j
Worksheets("Foglio1").Cells(rig, 8) = Me.ComboBox1.Value
For j = 10 To 12
Worksheets("Foglio1").Cells(rig, j) = Me.Controls("TextBox" & j - 1).Value
Next j
Worksheets("Foglio1").Cells(rig, 14) = Me.TextBox13.Value
Worksheets("Foglio1").Cells(rig, 15) = Me.TextBox14.Value
If Me.OptionButton1.Value = True Then
Worksheets("Foglio1").Cells(rig, 9) = "NO"
If Me.ComboBox1.Value = "" Then
MsgBox "Effettuare scelta cliente"
UserForm2.Hide
Private Sub UserForm_QueryClose(Cancel As Integer, CloseMode As Integer)
If CloseMode = 0 Then Cancel = True
unction Trovariga(Tabella_Dati As Range, parola As Variant) As Variant
If parola = "" Then
Trovariga = ""
Exit Function
Trovariga = Tabella_Dati.Find(parola, LookAt:=xlWhole).Row
Sub CreaElencoUnivoco()
Dim CL As Range, Intervallo As Range, Elenco As New Collection
Dim Valori As Variant
Dim cnt As Long
cnt = Worksheets("Foglio1").Cells(Rows.Count, 1).End(xlUp).Row
Set Intervallo = Worksheets("Foglio1").Range("a1:a" & cnt)
Set Intervallo = Intervallo.Offset(1, 0).Resize(Intervallo.Rows.Count - 1, Intervallo.Columns.Count)
For Each CL In Intervallo
Elenco.Add CL.Value, CStr(CL.Value)
On Error GoTo 0
With UserForm2
.ComboBox1.Clear
For Each Valori In Elenco
.ComboBox1.AddItem Valori
UserForm2.Show
