Sub SalvaFogli()
Dim n As Long
Dim myNome As String
Dim myPath As String
myPath = "C:Temp" 'da modificare
With ActiveWorkbook
For n = 1 To .Sheets.Count
myNome = .Sheets(n).Name
.Sheets(n).Copy
ActiveWorkbook.SaveAs Filename:=myPath & myNome
ActiveWorkbook.Close
Next n
MsgBox "Sono stati creati " & n - 1 & " files"
Function SeparaFogli(strPath, File)
'@@utilities@@ i fogli contenuti in una cartella xls diventano singoli file xls (chiede dove salvarli)
Dim ChDir, NomeFile, StrCartella, Vuoi As String
Workbooks.Open Filename:=strPath & "" & File
NomeF = ActiveWorkbook.Name
MsgBox (NomeF)
ChDir = ActiveWorkbook.Path
Vuoi = MsgBox("Salvo in questa Cartella->" & ChDir & "?", vbYesNo)
If Vuoi = vbNo Then
Set FD = Application.FileDialog(msoFileDialogFolderPicker)
With FD
If .Show = False Then
Exit Function
StrCartella = .SelectedItems(1)
If StrCartella <> "" Then
ChDir = StrCartella
For g = 1 To Sheets.Count
Worksheets(g).Activate
ActiveSheet.Select
ActiveSheet.Copy
NomeFile = NomeF & "_" & ActiveSheet.Name & ".xls"
ActiveWorkbook.SaveAs Filename:=ChDir & "" & NomeFile _
, FileFormat:=xlNormal, password:="", WriteResPassword:="", _
ReadOnlyRecommended:=False, CreateBackup:=False
Windows(NomeF).Activate
Sub ElencaFile()
' Elenca tutti i file in una cartella
Dim objFso, objFolder, objFiles, strFolder, strFile
' impostare qui la cartella desiderata
strPath = "c:prova"
Set objFso = CreateObject("Scripting.FileSystemObject")
Set objFolder = objFso.GetFolder(strPath)
Set objFiles = objFolder.Files
For Each strFile In objFiles
c = SeparaFogli(strPath, strFile.Name)
Set objFso = Nothing
Set objFolder = Nothing
Set objFiles = Nothing
Function SeparaFogli(strPath, File, NuovaCartella)
'apre il file presente a questo indirizzo
' MsgBox (NomeF)
ActiveSheet.Select
ActiveSheet.Copy
' cartella in cui salvare i diversi fogli come file xls
ActiveWorkbook.SaveAs Filename:=strPath & "" & NuovaCartella & "" & NomeFile _
Sub ElencaFile()
Dim objFso, objFolder, objFiles, strFolder, strFile, ChDir, NomeFile, StrCartella, Vuoi
' qui la macro chiede qual e' la cartella da selezionare
Vuoi = MsgBox("Cartella in cui si trovano i file xls->" & ChDir & "?", vbYesNo)
If Vuoi = vbNo Then
With FD
strPath = .SelectedItems(1)
If strPath <> "" Then
ChDir = strPath
Set objFolder = objFso.GetFolder(ChDir)
i = 0
' mi ricavo il nome del file senza xls finale per creare le cartelle
cd = Split(strFile.Name, ".")
' VERIFICO CHE SIA UN FILE XLS PRIMA DI PROCEDERE
If cd(UBound(cd)) = "xls" Then
NomeCart = cd(0)
d = Crea_Cartella(ChDir, NomeCart)
c = SeparaFogli(ChDir, strFile.Name, NomeCart)
i = i + 1
MsgBox (" Processati " & i & " File xls")
Function Crea_Cartella(Path, NomeCartella)
Cartella = Path & "" & NomeCartella
If Not fso.FolderExists(Cartella) Then
fso.CreateFolder (Cartella)
End Function |
If ActiveSheet.Name Like ("blocco*") Then |
' MsgBox (NomeF)
If ActiveSheet.Name Like ("BLOCCO*") Then 'Estraggo solo i fogli il cui nome inizia con BLOCCO
ActiveSheet.Select
ActiveSheet.Copy
, FileFormat:=xlNormal, Password:="", WriteResPassword:="", _
End if
End Function |
