' nella USERFORM **********
StopTimer
Unload UserForm1
datainput = TextBox1.Value
Private Sub TextBox1_Change()
Check = 1
CheckUse
Check = 1
CheckUse
TextBox1 = Format(Date, "ddd dd/mm/yy")
' in un MODULO **********
Public TimeDelay As Double, Check As Integer
Public datainput
Function StartTimer()
TimeDelay = Now + TimeSerial(0, 0, 20)
Application.OnTime EarliestTime:=TimeDelay, Procedure:="CheckUse", Schedule:=True
Check = 0
Function CheckUse()
If Check = 1 Then
StartTimer
StopTimer
Unload UserForm1
Check = 3
Function StopTimer()
Application.OnTime EarliestTime:=TimeDelay, Procedure:="CheckUse", Schedule:=False
End Function |
