Sub CONTROLLO_ACCONTO()
Sheets("Inserimento dati").Select
Range("F10").Select
If Range("H3").Value = Range("N7").Value Then
Range("C3").Select
MsgBox "ATTENZIONE SOCIO GIA' REGISTRATO PER ACCONTO TORNA A INIZIO INSERIMENTO"
Else: Call COPIA_CONTEGGI_ACCONTO: End If
Range("F10").Select
If IsError(Range("N7").Value) Then
MsgBox "Rilevato errore nella formula", vbCritical, "Avviso"
ElseIf Range("H3").Value = Range("N7").Value Then
Range("C3").Select
