Sub LoopExample()
Dim StartNumber As Integer 'riga inizio primo range
Dim EndNumberRange1 As Integer 'riga fine primo range
Dim EndNumber As Integer 'variabile fine loop
Dim counter As Integer 'numero checkbox
NumCheck = 100 'inizializzazione counter
For counter = 1 To NumCheck
For StartNumber = 8 To EndNumber Step 2 'dalla riga 8
EndNumberRange1 = StartNumber + 1 'riga successiva che chiude il range riga 9
StartNumberSt = CStr(StartNumber) 'converto intero in stringa
MsgBox StartNumberSt
EndNumberRange1St = CStr(EndNumberRange1) 'converto intero in stringa
MsgBox EndNumberRange1St
If Sheet1.Controls("Checkbox" & counter).Value = True Then 'parto dalla checkbox1
Dim range1 As String
range1 = "C" & StartNumberSt 'definisco cella c8
MsgBox range1
Dim range2 As String
range2 = "E" & EndNumberRange1St 'definisco cella E9
Worksheets("Sheet1").Range(range1, range2).Copy _
Destination:=Worksheets("Sheet2").Range(range1)
Dim range11 As String
range1 = "F" & StartNumberSt 'definisco cella F8
MsgBox range11
Dim range22 As String
range2 = "I" & EndNumberRange1St 'definisco cella I9
MsgBox range22
Worksheets("Sheet1").Range(range11, range22).Copy _
Destination:=Worksheets("Sheet2").Range(range11)
If Sheet1.Controls("Checkbox" & counter).Value = False Then
Worksheets("Sheet1").Range(range1, range11).Copy _
counter = counter + 1
Next StartNumber
Next counter
Private Sub CheckBox1_Click()
