Private Sub CommandButton9_Click() 'paga1
If usPRFTCAR.txtRC30 = "" Then
If usPRFTCAR.txtRC7 = "" Then
MsgBox "MANCANO DATI", vbExclamation
If usPRFTCAR.txtRC11.Text = "" Then
MsgBox "MANCA L'IMPORTO DELLA RATA", vbExclamation
usPRFTCAR.txtRC11.SetFocus
If usPRFTCAR.txtRC12.Text = "" Then
MsgBox "MANCA LA DATA DEL PAGAMENTO", vbExclamation
usPRFTCAR.txtRC12.SetFocus
If usPRFTCAR.txtRC8.Text = "" Then
usPRFTCAR.txtRC8.Text = 0
If usPRFTCAR.txtRC9.Text = "" Then
usPRFTCAR.txtRC9.Text = 0
'xxxxxxxxxxxxxxxxxxxxxxxxxxxx calcolo progressivo
FPR1 = usPRFTCAR.txtRC8.Value
FPR2 = usPRFTCAR.txtRC11.Value
FPR3 = FPR1 + FPR2
usPRFTCAR.txtRC8 = FPR3
'xxxxxxxxxxxxxxxxxxxxxxxxx calcolo rimanenza
FPR1 = usPRFTCAR.txtRC7
FPR2 = usPRFTCAR.txtRC8
FPR3 = FPR1 - FPR2
usPRFTCAR.txtRC9 = FPR3
'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
FPR1 = usPRFTCAR.txtRC9.Value
If FPR1 <= 0 Then
CHIARO
VERDE
CHIARO
ROSSO
usPRFTCAR.txtRC30.Text = "P1"
ActiveCell.Value = usPRFTCAR.txtRC1
ActiveCell.Offset(0, 1) = usPRFTCAR.txtRC2
ActiveCell.Offset(0, 2) = usPRFTCAR.txtRC3
ActiveCell.Offset(0, 3) = usPRFTCAR.txtRC4
ActiveCell.Offset(0, 4) = usPRFTCAR.txtRC5
ActiveCell.Offset(0, 5) = usPRFTCAR.txtRC6
ActiveCell.Offset(0, 6) = usPRFTCAR.txtRC7
ActiveCell.Offset(0, 7) = usPRFTCAR.txtRC8
ActiveCell.Offset(0, 8) = usPRFTCAR.txtRC9
ActiveCell.Offset(0, 9) = usPRFTCAR.txtRC10
ActiveCell.Offset(0, 10) = usPRFTCAR.txtRC11
ActiveCell.Offset(0, 11) = usPRFTCAR.txtRC12
ActiveCell.Offset(0, 12) = usPRFTCAR.txtRC13
ActiveCell.Offset(0, 13) = usPRFTCAR.txtRC14
ActiveCell.Offset(0, 14) = usPRFTCAR.txtRC15
ActiveCell.Offset(0, 15) = usPRFTCAR.txtRC16
ActiveCell.Offset(0, 16) = usPRFTCAR.txtRC17
ActiveCell.Offset(0, 17) = usPRFTCAR.txtRC18
ActiveCell.Offset(0, 18) = usPRFTCAR.txtRC19
ActiveCell.Offset(0, 19) = usPRFTCAR.txtRC20
ActiveCell.Offset(0, 20) = usPRFTCAR.txtRC21
ActiveCell.Offset(0, 21) = usPRFTCAR.txtRC22
ActiveCell.Offset(0, 22) = usPRFTCAR.txtRC23
ActiveCell.Offset(0, 23) = usPRFTCAR.txtRC24
ActiveCell.Offset(0, 24) = usPRFTCAR.txtRC25
ActiveCell.Offset(0, 25) = usPRFTCAR.txtRC26
'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ActiveCell.Offset(0, 50) = usPRFTCAR.txtRC30
ActiveCell.Offset(0, 51) = usPRFTCAR.txtRC31
ActiveCell.Offset(0, 52) = usPRFTCAR.txtRC32
ActiveCell.Offset(0, 53) = usPRFTCAR.txtRC33
ActiveCell.Offset(0, 54) = usPRFTCAR.txtRc34
ActiveCell.Offset(0, 55) = usPRFTCAR.txtRC35
ActiveCell.Offset(0, 56) = usPRFTCAR.txtRC36
ActiveCell.Offset(0, 57) = usPRFTCAR.txtRC37
'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
SALVA
MsgBox "MODIFICA ESEGUITA E SALVATA", vbInformation
MsgBox "DATO GIA' INSERITO UTILIZZARE ALTRI INSERIMENTI", vbCritical
ActiveCell.Value = (usPRFTCAR.txtRC1)*1 ActiveCell.Offset(0, 1) = (usPRFTCAR.txtRC2)*1 ActiveCell.Offset(0, 2) = (usPRFTCAR.txtRC3)*1 |
Private Sub CommandButton9_Click() 'paga1 If usPRFTSCAR.txt30FS = "" Then If usPRFTSCAR.txt7FS = "" Then MsgBox "MANCANO DATI", vbExclamation Exit Sub End If If usPRFTSCAR.txt13FS = "" Then MsgBox "MANCA L'IMPORTO DELLA RATA", vbExclamation usPRFTSCAR.txt13FS.SetFocus Exit Sub End If If usPRFTSCAR.txt14FS = "" Then MsgBox "MANCA LA DATA DEL PAGAMENTO", vbExclamation usPRFTSCAR.txt14FS.SetFocus Exit Sub End If If usPRFTSCAR.txt10FS = "" Then usPRFTSCAR.txt10FS = 0 End If If usPRFTSCAR.txt11FS = "" Then usPRFTSCAR.txt11FS = 0 End If 'assegno alle variabili i valori inseriti nelle texbox inserite nella userform 'xx calcolo progressivo FPS1 = usPRFTSCAR.txt10FS.Value FPS2 = usPRFTSCAR.txt13FS.Value FPS3 = FPS1 + FPS2 usPRFTSCAR.txt10FS = FPS3 'assegno alle variabili i valori inseriti nelle texbox inserite nella userform 'xxxxxxxxxxxxxxxxxxxxxxxxx calcolo rimanenza FPS1 = usPRFTSCAR.txt7FS.Value FPS2 = usPRFTSCAR.txt10FS.Value FPS3 = FPS1 - FPS2 usPRFTSCAR.txt11FS = FPS3 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx FPS1 = usPRFTSCAR.txt11FS If FPS1 <= 0 Then CHIARO VERDE Else CHIARO ROSSO End If usPRFTSCAR.txt30FS = "P1" 'Salvataggio dati inseriti sul foglio di lavoro ActiveCell.Value = usPRFTSCAR.txt1FS ActiveCell.Offset(0, 1) = usPRFTSCAR.txt2FS ActiveCell.Offset(0, 2) = usPRFTSCAR.txt3FS ActiveCell.Offset(0, 3) = usPRFTSCAR.txt4FS ActiveCell.Offset(0, 4) = usPRFTSCAR.txt5FS ActiveCell.Offset(0, 5) = usPRFTSCAR.txt6FS ActiveCell.Offset(0, 6) = usPRFTSCAR.txt7FS ActiveCell.Offset(0, 7) = usPRFTSCAR.txt8FS ActiveCell.Offset(0, 8) = usPRFTSCAR.txt9FS ActiveCell.Offset(0, 9) = (usPRFTSCAR.txt10FS) * 1 ActiveCell.Offset(0, 10) = (usPRFTSCAR.txt11FS) * 1 ActiveCell.Offset(0, 11) = usPRFTSCAR.txt12FS ActiveCell.Offset(0, 12) = usPRFTSCAR.txt13FS ActiveCell.Offset(0, 13) = usPRFTSCAR.txt14FS ActiveCell.Offset(0, 14) = usPRFTSCAR.txt15FS ActiveCell.Offset(0, 15) = usPRFTSCAR.txt16FS ActiveCell.Offset(0, 16) = usPRFTSCAR.txt17FS ActiveCell.Offset(0, 17) = usPRFTSCAR.txt18FS ActiveCell.Offset(0, 18) = usPRFTSCAR.txt19FS ActiveCell.Offset(0, 19) = usPRFTSCAR.txt20FS ActiveCell.Offset(0, 20) = usPRFTSCAR.txt21FS ActiveCell.Offset(0, 21) = usPRFTSCAR.txt22FS ActiveCell.Offset(0, 22) = usPRFTSCAR.txt23FS ActiveCell.Offset(0, 23) = usPRFTSCAR.txt24FS ActiveCell.Offset(0, 24) = usPRFTSCAR.txt25FS ActiveCell.Offset(0, 25) = usPRFTSCAR.txt26FS ActiveCell.Offset(0, 26) = usPRFTSCAR.txt27FS ActiveCell.Offset(0, 27) = usPRFTSCAR.txt28FS 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx ActiveCell.Offset(0, 50) = usPRFTSCAR.txt30FS ActiveCell.Offset(0, 51) = usPRFTSCAR.txt31FS ActiveCell.Offset(0, 52) = usPRFTSCAR.txt32FS ActiveCell.Offset(0, 53) = usPRFTSCAR.txt33FS ActiveCell.Offset(0, 54) = usPRFTSCAR.txt34FS ActiveCell.Offset(0, 55) = usPRFTSCAR.txt35FS ActiveCell.Offset(0, 56) = usPRFTSCAR.txt36FS ActiveCell.Offset(0, 57) = usPRFTSCAR.txt37FS SALVA MsgBox "MODIFICA ESEGUITA E SALVATA", vbInformation Else MsgBox "DATO GIA' INSERITO UTILIZZARE ALTRI INSERIMENTI", vbCritical Exit Sub End If End Sub |
A B C
___│________________│___________________│_______
1 │ 1.212 │ 1212 │
2 │(formato n.ro) │ (formato testo) │
3 │ │ │
4 │ │ │
5 │ │ │
ActiveCell.Value = usPRFTSCAR.txt1FS ActiveCell.Offset(0, 1) = usPRFTSCAR.txt2FS ActiveCell.Offset(0, 2) = usPRFTSCAR.txt3FS ActiveCell.Offset(0, 3) = usPRFTSCAR.txt4FS ActiveCell.Offset(0, 4) = CDbl(IIf(RTrim(usPRFTSCAR.txt5FS & "") = "", 0, RTrim(usPRFTSCAR.txt5FS & ""))) ActiveCell.Offset(0, 5) = CDbl(IIf(RTrim(usPRFTSCAR.txt6FS & "") = "", 0, RTrim(usPRFTSCAR.txt6FS & ""))) ActiveCell.Offset(0, 6) = CDbl(IIf(RTrim(usPRFTSCAR.txt7FS & "") = "", 0, RTrim(usPRFTSCAR.txt7FS & ""))) ActiveCell.Offset(0, 7) = usPRFTSCAR.txt8FS ActiveCell.Offset(0, 8) = usPRFTSCAR.txt9FS ActiveCell.Offset(0, 9) = CDbl(IIf(RTrim(usPRFTSCAR.txt10FS & "") = "", 0, RTrim(usPRFTSCAR.txt10FS & ""))) ActiveCell.Offset(0, 10) = CDbl(IIf(RTrim(usPRFTSCAR.txt11FS & "") = "", 0, RTrim(usPRFTSCAR.txt11FS & ""))) ActiveCell.Offset(0, 11) = usPRFTSCAR.txt12FS ActiveCell.Offset(0, 12) = usPRFTSCAR.txt13FS ActiveCell.Offset(0, 13) = usPRFTSCAR.txt14FS ActiveCell.Offset(0, 14) = usPRFTSCAR.txt15FS ActiveCell.Offset(0, 15) = usPRFTSCAR.txt16FS Active |
I?ll immediately tcuclh your rss feed as I can not in finding your e-mail subscription link or newsletter service. Do you've any? Kindly let me recognise so that I may just subscribe. Thanks. |
