Dim oXLApp As Object, oXLwb As Object, oXLws As Object
Dim lRow As Long
Set oXLApp = GetObject(, "Excel.Application")
'~~> If not found then create new instance
If Err.Number <> 0 Then
Set oXLApp = CreateObject("Excel.Application")
Err.Clear
On Error GoTo 0
'~~> Show Excel
oXLApp.Visible = True
'~~> Open the relevant file
Set oXLwb = oXLApp.Workbooks.Open("C:Usersma036650 0-TRAVAINITravaini TEMPLTLT.xlsm")
'~~> Set the relevant output sheet. Change as applicable
Set oXLws = oXLwb.Sheets(1)
lRow = oXLws.Range("A" & oXLApp.Rows.Count).End(-4162).Row + 1
'-4162 = xlup
'~~> Write to outlook
With oXLws
'~~> Code here to output data from email to Excel File
'~~> For example
.Range("A" & lRow).Value = MyMail.Subject
.Range("B" & lRow).Value = MyMail.SenderName
'~~> Close and Clean up Excel
oXLwb.Close (True)
oXLApp.Quit
Set oXLws = Nothing
Set oXLwb = Nothing
Set oXLApp = Nothing
