Private Sub ComboBox1_Enter()
Dim r As Integer, Occorrenza As Integer
Dim col As Collection, v As Variant
Dim LastRow As Long
ComboBox1.Clear
Frame1.Visible = False
LastRow = Range("A" & Rows.Count).End(xlUp).Row
Set col = New Collection
For r = 7 To LastRow
If Cells(r, 1) <> "" Then
col.Add Cells(r, 1).Value, CStr(Cells(r, 1).Value)
For Each v In col
Me.ComboBox1.AddItem v
Dim i As Long, iRow As Long
iRow = Worksheets("Lista Attività").Range("A" & Rows.Count).End(xlUp).Row
For i = 7 To iRow
If Cells(i, 1) = Me.ComboBox1.Value Then
Me.ComboBox2.AddItem Cells(i, 12) 'esempio a caso, inserico nella listbox il campo "Nr LAB" a parità di "Cta Ref"
Private Sub ComboBox2_Change()
Dim j As Integer, i As Integer
Frame1.Visible = True
ComboBox1.Enabled = False
iRow = Worksheets("Lista Attività").Range("L" & Rows.Count).End(xlUp).Row
For i = 7 To iRow
If Cells(i, 12) = Me.ComboBox2.Value Then
TextBox1 = Cells(i, 22)
ComboBox3.Value = Cells(i, 23)
TextBox6 = Cells(i, 24)
TextBox2 = Cells(i, 25)
TextBox3 = Cells(i, 26)
If TextBox1 <> "" Then
TextBox1.Enabled = False
If TextBox2 <> "" Then
TextBox2.Enabled = False
If TextBox3 <> "" Then
TextBox3.Enabled = False
If TextBox6 <> "" Then
TextBox6.Enabled = False
If ComboBox3.Value <> "" Then
ComboBox3.Enabled = False
Dim j As Long, p As Long, Casella As Variant
For Each Casella In Worksheets("Lista Attività").Range(Cells(7, 12), Cells(iRow, 12))
If CStr(Casella.Value) = Me.ComboBox2 Then
Casella.Offset(0, 10) = TextBox1
Casella.Offset(0, 11) = ComboBox3
Casella.Offset(0, 12) = TextBox6
Casella.Offset(0, 13) = TextBox2
Casella.Offset(0, 14) = TextBox3
Casella.Offset(0, 15) = ComboBox4
Casella.Offset(0, 16) = TextBox4
Casella.Offset(0, 17) = TextBox5
For p = 1 To 6
UserForm2.Controls("TextBox" & p) = ""
Next p
For j = 2 To 4
UserForm2.Controls("ComboBox" & j) = ""
Next j
TextBox1.Enabled = True
TextBox2.Enabled = True
TextBox3.Enabled = True
TextBox4.Enabled = True
TextBox5.Enabled = True
TextBox6.Enabled = True
ComboBox3.Enabled = True
ComboBox4.Enabled = True
Unload Me
UserForm2.Show
Unload Me
Private Sub UserForm_Click()
