Private Sub Sfoglia_Files()
''''' ATTENZIONE RICHIEDE L'ATTIVAZIONE DELLA LIBRERIA MICROSOFT SCRIPTING RUNTIME '''''
Dim strPath As String
Dim objFSY As FileSystemObject
Dim objFOL As Folder
Dim objFIL As File
Dim wbFrom As Workbook, wbTo As Workbook
Dim wsFrom As Worksheet, wsTo As Worksheet
Dim x As Long, i As Long
Dim rngCopy As Range
Set wbTo = ThisWorkbook
Set wsTo = wbTo.Sheets(1)
strPath = "C:ProveFiles" '''QUI IL PERCORSO
Set objFSY = New FileSystemObject
Set objFOL = objFSY.GetFolder(strPath)
For Each objFIL In objFOL.Files
x = wsTo.Range("B" & wsTo.Rows.Count).End(xlUp).Row + 1
Set wbFrom = Application.Workbooks.Open(objFIL)
Set wsFrom = wbFrom.Sheets(1)
With wsFrom
i = .Range("B" & .Rows.Count).End(xlUp).Row
Set rngCopy = .Range("B3:Q" & i)
rngCopy.Copy wsTo.Cells(x, 2)
Set rngCopy = Nothing
wbFrom.Close 0
Set wbFrom = Nothing
Set wsFrom = Nothing
Set objFSY = Nothing
Set objFOL = Nothing
Set wsTo = Nothing
Sub unionefile()
' unionefile Macro
' Scelta rapida da tastiera: CTRL+h
'Sub Copia_Dati_da_più_File()
Dim File_El As String, MiaDir As String, Perc_Stor As String, File_Cop As Integer
Dim Nome_Iniziale As String, Nome_Attuale As String, RR As Integer, I As Integer, J As Integer, Righe As Integer
Dim WS_In As String, WS_Out As String
Nome_Iniziale = ActiveWorkbook.Name
WS_Out = ActiveSheet.Name
' attenzione a mettere le "" finali !!!
MiaDir = "C:Moduli_Ricevuti" ' ----->> ADATTA i nomi
Perc_Stor = "Storico" ' ----->> ADATTA i nomi
File_El = Dir(MiaDir & "*.xls")
If File_El = "" Then
MsgBox "ATTENZIONE: nel percorso '" & MiaDir & "' non sono stati trovati file"
I = Workbooks(Nome_Iniziale).Sheets(WS_Out).Range("A" & Rows.Count).End(xlUp).Row + 1
Righe = I
File_Cop = 0
While File_El <> ""
Nome_Attuale = File_El
Workbooks.Open Filename:=MiaDir & Nome_Attuale
WS_In = Workbooks(Nome_Attuale).ActiveSheet.Name
RR = Workbooks(Nome_Attuale).Sheets(WS_In).Range("A" & Rows.Count).End(xlUp).Row
For J = 2 To RR
Workbooks(Nome_Iniziale).Sheets(WS_Out).Cells(I, 1) = File_El
Workbooks(Nome_Iniziale).Sheets(WS_Out).Cells(I, 2) = Date
' QUI vanno inserite le istruzioni per copiare i dati
' Nell'esempio vengono copiate le colonne A, B, C e D ---->> ADATTARE in base alle esigenze
Workbooks(Nome_Iniziale).Sheets(WS_Out).Cells(I, 3) = Workbooks(Nome_Attuale).Sheets(WS_In).Cells(J, 1)
Workbooks(Nome_Iniziale).Sheets(WS_Out).Cells(I, 4) = Workbooks(Nome_Attuale).Sheets(WS_In).Cells(J, 2)
Workbooks(Nome_Iniziale).Sheets(WS_Out).Cells(I, 5) = Workbooks(Nome_Attuale).Sheets(WS_In).Cells(J, 3)
Workbooks(Nome_Iniziale).Sheets(WS_Out).Cells(I, 6) = Workbooks(Nome_Attuale).Sheets(WS_In).Cells(J, 4)
I = I + 1
Next J
File_Cop = File_Cop + 1
Windows(Nome_Attuale).Close
On Error GoTo Errore
Name MiaDir & Nome_Attuale As MiaDir & Perc_Stor & Nome_Attuale
File_El = Dir
Wend
MsgBox "Sono state copiate: '" & I - Righe & "' righe di dati" & vbCrLf & _
"Presenti in: '" & File_Cop & "' File"
Errore:
MsgBox "ATTENZIONE !!!" & vbCrLf & "Il File: '" & Nome_Attuale & _
"'" & vbCrLf & "E' stato già elaborato e storicizzato" & vbCrLf & vbCrLf & _
"L'elaborazione viene interrotta !!!", vbCritical
Dim oFSY As FileSystemObject 'variabile oggetto della libreria indicata
'h t t p: / /msdn .m ic roso ft.com/ it-it/l ibrary/a a711216(v= vs.71).aspx
Dim oFOL As Folder 'come sopra
Dim oFIL As File 'idem con patate
Dim oFD As FileDialog 'variabile oggetto, da guida in linea "un'istanza della finestra di dialogo dei file."
'trattasi di proprietà dell'oggetto "application"
Dim oScelta As Variant 'qui non so se sia la scelta migliore, serve per "catturare" la scelta fatta sul filedialog"
'due variabili workbook, una la istanzieremo su quello dove importare
'l'altra diverrà di volta in volta il file che apriremo
'come sopra, ma due worksheet
'serviranno per determinare da che riga a che riga copiare e dove incollare
'- chiede di selezionare una directory in cui ci sono excel files '
Set oFD = Application.FileDialog(msoFileDialogFolderPicker)
With oFD
.InitialFileName = "C:" 'qui modificare eventuale cartella di default
.Title = "Sfoglia cartelle"
.ButtonName = "Ok"
.AllowMultiSelect = False
.InitialView = msoFileDialogViewDetails
.Show
For Each oScelta In .SelectedItems
strPath = oScelta 'la variabile stringa diventa il percorso della cartella selezionata
Next oScelta
If strPath = "" Then GoTo Uscita
'istanziamo il foglio dove incollare i dati come il foglio "MAIN" come indicato
Set wsTo = wbTo.Sheets("MAIN")
Set oFSY = New FileSystemObject
'sempre grazie alla libreria di cui a inizio routine, applicahiamo il metodo "Getfolder" all'oggetto "oFSY"
'Guida Microsoft per dettagli: ht t p: // m s d n . m i c r o s o ft.com/en- u s / l i b r ary/off i c e/gg278492.aspx
Set oFOL = oFSY.GetFolder(strPath)
'- per ogni file all'interno della directory, lo apre, va al primo foglio e copia tutti i dati (un solo foglio per ogni file) '
For Each oFIL In oFOL.Files 'per ogni file
'troviamo la prima riga libera di colonna "B" del foglio dove andremo ad incollare i dati
'questo perchè in colonna A dobbiamo scrivere il nome del file
'istanziamo l'oggetto workbook sul file da cui vogliamo copiare
Set wbFrom = Application.Workbooks.Open(oFIL)
'idem per il foglio da cui copiare, arbitrariamente il primo (1)
With wsFrom
'troviamo ultima riga di colonna A, supponendo di dover copiare da lì in mancanza di maggiori informazioni
'stabiliamo che range copiare, sempre arbitrariamente da seconda riga a colonna Q in mancanza di maggiori dettagli
Set rngCopy = .Range("A2:Q" & i)
'copiamo il range
rngCopy.Copy 'wsTo.Cells(x, 2)
' incolla i dati in un nuovo file/foglio che si chiama MAIN '
''hai detto dati duindi procediamo con copia e incolla speciale '
wsTo.Cells(x, 2).PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks:=False, Transpose:=False
'nella prima colonna del foglio MAIN, inserisca il nome '
'del file su ogni cella della prima colonna a seconda '
'del file da cui i dati sono stati copiati '
wsTo.Range("A" & x & ":A" & x + rngCopy.Rows.Count - 1) = wbFrom.Name
'qui il "-1" è perchè copiamo da riga 2 occhio!
'distruggiamo oggetto range
'chiudiamo senza salvare il file aperto
wbFrom.Close 0
'distruggiamo gli oggetti istanziati poco sopra
'ripeta la stessa operazione per tutti i files presenti nella directory '
Next oFIL
Uscita:
Set oFSY = Nothing
Set oFOL = Nothing
Set wsTo = Nothing
