Sub Crea_pulsanti()
' Crea_Pulsanti Macro
' Scelta rapida da tastiera: CTRL+p
ActiveSheet.Shapes.AddShape(msoShapeRoundedRectangle, 354, 0.75, 62.2, 15). _
Select
Selection.OnAction = "PERSONAL.XLSB!spazio_nomefile"
Selection.ShapeRange(1).TextFrame2.TextRange.Characters.Text = "Nome file"
With Selection.ShapeRange(1).TextFrame2.TextRange.Characters(1, 9). _
ParagraphFormat
.FirstLineIndent = 0
.Alignment = msoAlignLeft
With Selection.ShapeRange(1).TextFrame2.TextRange.Characters(1, 9).Font
.NameComplexScript = "+mn-cs"
.NameFarEast = "+mn-ea"
.Fill.Visible = msoTrue
.Fill.ForeColor.ObjectThemeColor = msoThemeColorLight1
.Fill.ForeColor.TintAndShade = 0
' .Fill.ForeColor.Brightness = 0
.Fill.Transparency = 0
.Fill.Solid
.Size = 11
.Name = "+mn-lt"
Selection.ShapeRange.ScaleHeight 1.35, msoFalse, msoScaleFromTopLeft
Selection.Placement = xlFreeFloating
Selection.PrintObject = msoFalse
Selection.ShapeRange.TextFrame2.AutoSize = msoAutoSizeShapeToFitText
ActiveSheet.Shapes.AddShape(msoShapeRoundedRectangle, 434.25, 0.75, 68.25, 24). _
Select
Selection.OnAction = "PERSONAL.XLSB!Ultima_colonna"
Selection.ShapeRange(1).TextFrame2.TextRange.Characters.Text = "Ultima Colonna"
With Selection.ShapeRange(1).TextFrame2.TextRange.Characters(1, 14). _
ParagraphFormat
With Selection.ShapeRange(1).TextFrame2.TextRange.Characters(1, 14).Font
.Fill.Solid
.Size = 11
.Name = "+mn-lt"
With Selection.ShapeRange.Fill
.Visible = msoTrue
.ForeColor.ObjectThemeColor = msoThemeColorAccent6
' .ForeColor.Brightness = 0
.Transparency = 0
.Solid
Selection.ShapeRange.ScaleWidth 1.2087912088, msoFalse, msoScaleFromTopLeft
Selection.ShapeRange.ScaleWidth 1.0818181818, msoFalse, msoScaleFromTopLeft
ActiveSheet.Shapes.AddShape(msoShapeRoundedRectangle, 542.25, 0.75, 97.5, 24.75 _
).Select
Selection.OnAction = "PERSONAL.XLSB!Altre_colonne"
Selection.ShapeRange(1).TextFrame2.TextRange.Characters.Text = "Altre Colonne"
With Selection.ShapeRange(1).TextFrame2.TextRange.Characters(1, 13). _
ParagraphFormat
With Selection.ShapeRange(1).TextFrame2.TextRange.Characters(1, 13).Font
.Fill.Solid
.Size = 11
.Name = "+mn-lt"
.Visible = msoTrue
.Transparency = 0
.Solid
Selection.ShapeRange.ScaleWidth 0.8076923077, msoFalse, msoScaleFromTopLeft
ActiveSheet.Shapes.AddShape(msoShapeRoundedRectangle, 636, 0.75, 55.5, 24). _
Select
Selection.OnAction = "PERSONAL.XLSB!Totali"
Selection.ShapeRange(1).TextFrame2.TextRange.Characters.Text = "Totali"
With Selection.ShapeRange(1).TextFrame2.TextRange.Characters(1, 6). _
ParagraphFormat
With Selection.ShapeRange(1).TextFrame2.TextRange.Characters(1, 6).Font
.Fill.Solid
.Size = 11
.Name = "+mn-lt"
.Visible = msoTrue
.ForeColor.ObjectThemeColor = msoThemeColorAccent3
.Transparency = 0
.Solid
Selection.ShapeRange.ScaleWidth 0.7567567568, msoFalse, msoScaleFromTopLeft
Sub spazio_nomefile()
' nomefile Macro
' Scelta rapida da tastiera: CTRL+q
' pulisco celle unite e inserisco spazio
Cells.Select
With Selection
.HorizontalAlignment = xlGeneral
.VerticalAlignment = xlCenter
.WrapText = False
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.ShrinkToFit = False
.ReadingOrder = xlContext
.MergeCells = False
Cells.Select
Selection.Columns.AutoFit
Selection.Rows.AutoFit
Selection.UnMerge
Rows("1:1").Select
Selection.Insert Shift:=xlDown
' inserisco il nome del file e carattere
Range("A1").Select
Selection.Font.Bold = True
With Selection.Font
.Name = "Tahoma"
.Size = 10
.Strikethrough = False
.Superscript = False
.Subscript = False
.OutlineFont = False
.Shadow = False
.Underline = xlUnderlineStyleNone
.ColorIndex = xlAutomatic
.TintAndShade = 0
.ThemeFont = xlThemeFontNone
Range("A1").Select
ActiveCell.FormulaR1C1 = _
"=MID(CELL(""FILENAME"",R[79]C[7]),FIND(""["",CELL(""FILENAME"",R[79]C[7]))+5,FIND(""]"",CELL(""FILENAME"",R[79]C[7]))-FIND(""["",CELL(""FILENAME"",R[79]C[7]))-11)& "" - ""& (MID(R[2]C,9,LEN(R[2]C)))"
Range("A2").Select
'eseguo la sub maiuscole
'creo una variabile CD come OGGETTO
Dim CD As Object
'creo delle variabili stringa temporanee
Dim temp As String
'seleziono una zona del foglio dove voglio operare
Set zona = Range("a1")
'in tale zona eseguo un ciclo cella per cella
'ne estraggo la prima lettera che converto in maiuscola
'prendo le residue lettere e le trasformo in minuscole
For Each CD In zona
temp = CD.Value
temp1 = UCase(Left$(temp, 1))
'la riga sotto se voglio solo la prima maiuscola metto LCase
temp2 = UCase$(Mid$(temp, 2, Len(temp) - 1))
temp = temp1 & temp2
CD.Value = temp
Sub Totali()
' Totali Macro
' Scelta rapida da tastiera: CTRL+t
With Selection
.HorizontalAlignment = xlRight
.WrapText = False
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.MergeCells = True
' Selection.UnMerge
' ActiveCell.Offset(-1, 0).Range("A1").Select
' Selection.AutoFill Destination:=ActiveCell.Range("A1:A2"), Type:= _
' xlFillDefault
ActiveCell.Range("A1:A2").Select
ActiveCell.Offset(1, 0).Range("A1").Select
ActiveCell.FormulaR1C1 = "=SUMIF(R1C1:R100C1,""*"",C:C)"
' ActiveCell.FormulaR1C1 = "=SUM(R[-16]C:R[-1]C)"
ActiveCell.Select
' ActiveCell.Offset(0, 1).Range("A1").Select
' Selection.AutoFill Destination:=ActiveCell.Range("A1:E1"), Type:= _
' xlFillDefault
' ActiveCell.Range("A1:E1").Select
' faccio il controllo del colore e replico i totali
Do Until ActiveCell.Interior.ColorIndex < 1
With Selection
.WrapText = False
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.MergeCells = True
Selection.Copy
Selection.PasteSpecial Paste:=xlPasteFormulasAndNumberFormats, Operation:= _
xlNone, SkipBlanks:=False, Transpose:=False
Loop
ActiveCell.Select
Selection.Delete
Sub Ultima_colonna()
' Ultima_colonna Macro
' Scelta rapida da tastiera: CTRL+e
Do Until ActiveCell.Value = ""
"=SUMIF(INDIRECT(ADDRESS(3,COLUMN()+1)&"":""&ADDRESS(3,COUNTA(R3))),LEFT(INDIRECT(ADDRESS(3,COLUMN()+1)),2)&""*""," & Chr(10) & "INDIRECT(ADDRESS(ROW(),COLUMN()+1)&"":""&ADDRESS(ROW(),COUNTA(R3)+2)))"
Loop
xlFillDefault
Sub Altre_colonne()
' Altre_colonne Macro
' Scelta rapida da tastiera: CTRL+w
"=SUMIF(INDIRECT(ADDRESS(3,COLUMN()+1)&"":""&ADDRESS(3,MATCH(""TOT*"",INDIRECT(ADDRESS(3,COLUMN()+1)&"":""&ADDRESS(3,COUNTA(R3))),0)+2))," & Chr(10) & "LEFT(INDIRECT(ADDRESS(3,COLUMN()+1)),2)&""*"",INDIRECT(ADDRESS(ROW(),COLUMN()+1)&"":""&ADDRESS(ROW(),MATCH(""TOT*""," & Chr(10) & "INDIRECT(ADDRESS(3,COLUMN()+1)&"":""&ADDRESS(3,COUNTA(R3))),0)+2)))"
Loop
xlFillDefault
Sub formattazione_calcolo()
' formattazione Macro
' Scelta rapida da tastiera: CTRL+y
' già integrata in quella dei totali utile solo per TEST
With Selection
.WrapText = False
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.MergeCells = True
Selection.Copy
Loop
ActiveCell.Select
Selection.Delete
