Option Compare Text 'nessuna diff tra maius e minus
Dim sha As Worksheet, shr As Worksheet
Dim c As Range, d As Range, E As Range
Private Sub UserForm_QueryClose(Cancel As Integer, CloseMode As Integer)
If CloseMode <> 1 Then
MsgBox ("Usa il pulsante CHIUDI per terminare il lavoro"), vbInformation
Cancel = True
Dim N1 As String, n2 As String, n3 As String
Dim Ro As Integer
Set shr = Worksheets("ricerca")
Set sha = Worksheets("archivio")
N1 = TextBox1.Text
n2 = TextBox2.Text
n3 = ComboBox2.Value
Ro = 2
shr.Activate
shr.Range("A2:V3000").ClearContents
If ComboBox1 = "" Then
MsgBox ("ATTENZIONE CAMPO UFFICIO OBBLIGATORIO"), vbCritical
If TextBox2 <> "" And TextBox1 <> "" Then
MsgBox ("ATTENZIONE SCEGLIRE SOLO UN NOME")
For Each c In sha.Range("E:E")
If c.Value = "" Then Exit For
If c.Value = N1 And c.Offset(, 2) = ComboBox1 And c.Offset(, 3) = ComboBox2 Then
Range(c.Offset(0, -4), c.Offset(0, 17)).Copy
shr.Cells(Ro, 1).Select
Selection.PasteSpecial Paste:=xlPasteValues
Ro = Ro + 1
If c.Value = N1 And c.Offset(, 2) = ComboBox1 Then
Ro = Ro + 1
Next c
shr.Activate
shr.Cells(2, 1).Select
If shr.Cells(2, 1) <> "" Then
GoTo 10
For Each d In sha.Range("F:F")
If d.Value = "" Then Exit For
If d.Value = n2 And d.Offset(, 1) = ComboBox1 And c.Offset(, 3) = ComboBox2 Then
Range(d.Offset(0, -5), d.Offset(0, 16)).Copy
Ro = Ro + 1
If d.Value = n2 And d.Offset(, 1) = ComboBox1 Then
Ro = Ro + 1
Next d
GoTo 10
If shr.Cells(2, 1) = "" Then
For Each E In sha.Range("H:H")
If E.Value = "" Then Exit For
If E.Value = n3 And E.Offset(, -1) = ComboBox1 And c.Offset(, 3) = ComboBox2 Then
Range(E.Offset(0, -7), E.Offset(0, 14)).Copy
Ro = Ro + 1
If E.Value = n3 And E.Offset(, -1) = ComboBox1 Then
Ro = Ro + 1
Next E
MsgBox "Nessuna corrispondenza", vbInformation
MsgBox "Ricerca effettuata con successo", vbInformation
ComboBox3.RowSource = "ricerca!a2:a1500"
shr.Cells(1, 1).Select
Private Sub ComboBox1_AfterUpdate()
Dim x As Long, R As Long, ind, SH As Worksheet, xx As Long, XXX As Long
Set SH = Worksheets("VIARIO")
ind = ActiveSheet.Name
If ComboBox1 = "" Then Exit Sub
SH.Activate
For x = 3 To 8
If SH.Cells(1, x) = ComboBox1 Then
R = SH.Cells(Rows.Count, x).End(xlUp).Row
ComboBox2.RowSource = SH.Range(Cells(2, x), Cells(R, x)).Address
Exit For
Next x
For xx = 27 To 31
If SH.Cells(1, xx) = ComboBox1 Then
R = SH.Cells(Rows.Count, xx).End(xlUp).Row
ComboBox4.RowSource = SH.Range(Cells(2, xx), Cells(R, xx)).Address
Exit For
Next xx
Sheets(ind).Select
