preceding cell identification
di last cell (utente non iscritto) data: 09/08/2014 15:41:23
Hi everybody ,
I am struggling to find a way to keep track of the cell i am from . said in other way "activecell.row" "active cell.column" it is related to the current position i would like to find a way to know same information but related to the preceding cell.
many thanks
di lepat (utente non iscritto) data: 09/08/2014 17:14:23
try this code
Dim cell As Range
Sub Worksheet_SelectionChange(ByVal Target As Range)
MsgBox ("current cell " & Target.Address)
MsgBox ("Previous cell " & cell.Address)
Set cell = Target
di scossa data: 09/08/2014 18:16:02
Hi,
if you want to keep track even if you close the file, try this:
First step: select a cell and assign it the name PrevCell;
Second step: insert the code below in the class module of ThisWorkbook.
Hope this help.
| scossa's web site |
Private Sub Workbook_SheetDeActivate(ByVal Sh As Object)
MsgBox "ActiveCell: " & ActiveCell.Address(0, 0, external:=True) & vbCrLf & _
"PrevCell: " & [PrevCell].Address(0, 0, external:=True)
'Me.Names("PrevCell").RefersTo = "=" & ActiveCell.Address(external:=True)
Private Sub Workbook_SheetSelectionChange(ByVal Sh As Object, ByVal Target As Range)
