'unifica tutte le tabelle dei singoli fogli in un unico foglio, il primo
Sub unifica()
Dim first_sheet As Worksheet, sh As Worksheet
Set first_sheet = Foglio1
For Each sh In ThisWorkbook.Sheets
If sh.Name <> first_sheet.Name Then sh.[A1].CurrentRegion.Copy first_sheet.Cells([COUNTA(A:A)] + 1, 1)
Sub separa()
Dim cella As Range, i As Integer, sep As Integer, v As Variant, k As Integer
For Each cella In [A2:A760]
i = i + 1
Cells(cella.Row, 6) = "GEO" & Format(i, "0000") 'codice
k = 7
For Each v In Split(cella.Offset(, 1), vbLf) 'separa la domanda dalle risposte
Cells(cella.Row, k) = Trim(v)
k = k + 1
Cells(cella.Row, 12) = Trim(cella.Offset(, 2)) 'risposta esatta
MsgBox "Ho terminato."
Sub separa()
Dim cella As Range, i As Integer, sep As Integer, v As Variant, w As Variant, k As Integer, s As String
For Each cella In [A2:A268]
i = i + 1
Cells(cella.Row, 6) = "ING" & Format(i, "0000") 'codice
k = 7
w = Split(cella.Offset(, 1), vbLf)
If UBound(w) >= 4 Then
For Each v In w 'separa la domanda dalle risposte
If Trim(v) <> "" Then
Cells(cella.Row, k) = Replace(Trim(v), vbLf, "")
k = k + 1
w = Split(cella.Offset(, 1), ")")
Cells(cella.Row, 7) = Replace(Trim(Left(w(0), Len(w(0)) - 1)), vbLf, "")
Cells(cella.Row, 8) = Replace("A) " & Trim(Left(w(1), Len(w(1)) - 1)), vbLf, "")
Cells(cella.Row, 9) = Replace("B) " & Trim(Left(w(2), Len(w(2)) - 1)), vbLf, "")
Cells(cella.Row, 10) = Replace("C) " & Trim(Left(w(3), Len(w(3)) - 1)), vbLf, "")
Cells(cella.Row, 11) = Replace("D) " & Trim(Left(w(4), Len(w(4)) - 1)), vbLf, "")
s = cella.Offset(, 2)
s = Replace(s, vbLf, "")
Cells(cella.Row, 12) = Trim(s) 'risposta esatta
Sub dividi()
Dim x, y, L1, L2, L3, L4, r, col, n, n1, n2, n3, n4, dd, d1, d2, d3, d4, sh1 As Worksheet, sh2 As Worksheet
Set sh1 = Worksheets("Table 1")
Set sh2 = Worksheets("Foglio1")
sh1.Activate
r = 2
col = 4
For x = 8 To Cells(Rows.Count, 1).End(xlUp).Row
sh2.Cells(r, 1) = Cells(x, 1)
sh2.Cells(r, 3) = Cells(x, 4)
L1 = Len(Cells(x, 2))
For y = 1 To L1
L4 = Mid(Cells(x, 2), y, 2)
Select Case L4
Case "A)"
dd = y
Case "B)"
d1 = y
Case "C)"
d2 = y
Case "D)"
d3 = y
End Select
Next y
n = d1 - dd
n1 = Trim(Mid(Cells(x, 2), dd, n))
n = d2 - d1
n2 = Trim(Mid(Cells(x, 2), d1, n))
If d3 > d2 Then n = d3 - d2 Else n = d2 - d3
n3 = Trim(Mid(Cells(x, 2), d2, n))
n4 = Trim(Mid(Cells(x, 2), d3, L1))
sh2.Cells(r, 2) = Trim(Mid(Cells(x, 2), 1, dd - 2))
sh2.Cells(r, 4) = n1
sh2.Cells(r, 5) = n2
sh2.Cells(r, 6) = n3
sh2.Cells(r, 7) = n4
r = r + 1
Private Sub Workbook_Open()
Sheets("Sfondo").Activate
ActiveSheet.EnableSelection = xlNoSelection
ActiveSheet.Protect Contents:=True, UserInterfaceOnly:=True
'ActiveSheet Unprotect per sbloccare questo foglio!
