Sub WWWWWWWWW()
' WWWWWWWWW Macro
Range("AF1:AF22").Select
Selection.Copy
Sheets("ORDINI_DOPPI").Select
Range("A1").Select
Selection.End(xlDown).Select
Range("A4").Select
ActiveSheet.Paste
Sub a()
Sheets(1).Range("A1:A22").Copy Sheets(2).Range("A1").End(xlDown).Offset(1, 0)
Sub Macro1()
Range("AF1", Range("AF1").End(xlDown)).Copy
Dim indice As Integer
indice = Range("A1").End(xlDown).Row + 1
Cells(indice, 1).PasteSpecial
Sheets(CARICO).Range("A1:A22").Copy Sheets(ORDINI_DOPPI).Range("A1").End(xlDown).Offset(1, 0) |
Sheets("CARICO").Range("AF2", Range("AF2").End(xlDown)).Copy
Sheets("ORDINI_DOPPI").Range("A1").End(xlDown).Offset(1, 0).PasteSpecial |
Sub ORDINIDOPPI()
' ORDINIDOPPI Macro
Dim i As Integer
For i = 1 To 200
If Sheets("CARICO").Cells(i, 32) <> "" Then
Sheets("CARICO").Cells(i, 32).Copy
Sheets("ORDINI_DOPPI").Range("A1").End(xlDown).Offset(1, 0).PasteSpecial Paste:=xlPasteValues
