Sub Arr_pg()
Dim Arr() As String
Dim WS As Worksheet
Dim R As Range
Dim N As Long, x As Long, y As Long
Dim Formula As String
Columns("A:B").Clear
N = Range("H" & Rows.Count).End(xlUp).Row
ReDim Arr(N + 5)
x = 1
Do While Cells(x, 8) <> ""
Arr(x) = Cells(x, 8)
x = x + 1
Loop
Set R = Range("A1").Resize(UBound(Arr) - LBound(Arr) + 1, 1)
R = Application.Transpose(Arr)
R.Sort key1:=R, order1:=xlAscending, MatchCase:=False
y = Range("A" & Rows.Count).End(xlUp).Row
For N = 1 To y
Arr(N) = R(N, 1)
Next N
Columns("A").Select
ActiveSheet.Range("$A$1:$A$" & y).RemoveDuplicates Columns:=1, Header:=xlNo
For x = 1 To y
Formula = "=CONTA.SE($H:$H;$A" & x & ")"
Cells(x, 2).FormulaLocal = Formula
Cells(x, 2).Copy
Cells(x, 2).PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks:=False, Transpose:=False
Next x
Columns("A:B").Select
ActiveWorkbook.ActiveSheet.Sort.SortFields.Clear
ActiveWorkbook.ActiveSheet.Sort.SortFields.Add Key:=Range("B1:B" & y), _
SortOn:=xlSortOnValues, Order:=xlDescending, DataOption:=xlSortNormal
ActiveWorkbook.ActiveSheet.Sort.SortFields.Add Key:=Range("A1:A" & y), _
SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
With ActiveWorkbook.ActiveSheet.Sort
.SetRange Range("A1:B" & y)
.Header = xlGuess
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
Range("A11:B" & y).ClearContents
Range("A1").Select
| scossa's web site |
| Se tu hai una mela, ed io ho una mela, e ce le scambiamo, allora tu ed io abbiamo sempre una mela per uno. Ma se tu hai un'idea, ed io ho un'idea, e ce le scambiamo, allora abbiamo entrambi due idee. (George Bernard Shaw) |
' Procedure : uModa
' Author : Scossa
' Date : 17/03/2014
' Purpose : restituisce una matrice bidimensionale con gli elementi ordinati
' in base alla "moda"
Public Function uModa(ByVal rng As Range) As Variant
Dim nCnt As Long
Dim cDati As New Collection
Dim cella As Range
Dim vDato As Variant
Dim aDati As Variant
Dim j As Integer
Dim vRet As Variant
For Each cella In rng
With cella
nCnt = Application.WorksheetFunction.CountIf(rng, .Value)
cDati.Add Array(.Value, nCnt), CStr(.Value)
On Error GoTo 0
ReDim aDati(1 To cDati.Count, 1 To 2)
j = 0
For Each vDato In cDati
j = j + 1
aDati(j, 1) = vDato(1)
aDati(j, 2) = vDato(0)
aDati = ArrayBiSort(aDati)
uModa = aDati
' Function : ArrayBiSort
' Author : Scossa
' Date : 17/03/2014
' Purpose : ordina un array bidimensionale in base alla prima dimensione
' (dal maggiore al minore)
Private Function ArrayBiSort(ByVal ArrayIn As Variant)
Dim vMaster As Variant
Dim vSlave As Variant
Dim i As Long
Dim j As Long
For i = LBound(ArrayIn) To UBound(ArrayIn)
For j = i + 1 To UBound(ArrayIn)
If ArrayIn(i, 1) < ArrayIn(j, 1) Then
vMaster = ArrayIn(j, 1)
vSlave = ArrayIn(j, 2)
ArrayIn(j, 1) = ArrayIn(i, 1)
ArrayIn(j, 2) = ArrayIn(i, 2)
ArrayIn(i, 1) = vMaster
ArrayIn(i, 2) = vSlave
Next j
ArrayBiSort = ArrayIn
| scossa's web site |
