Sub Combina()
Set angolo = Range("CD10")
Range("da10:bcd12").ClearContents
For r = 10 To 12
c = 104
For i = angolo.Column To angolo.Column + 18
uno = Cells(r, i).Value
For j = i + 1 To angolo.Column + 19
due = Cells(r, j).Value
For k = j + 1 To angolo.Column + 20
tre = Cells(r, k).Value
ris = 0
ris = uno + due + tre
c = c + 1
Cells(r, c).Select
If ris > 2 Then Cells(r, c) = ris
Next k
Next j
Next r
Dim angolo As Range Dim r as long, c as long, i as long, j as long, k as long Dim uno as integer, due as integer, tre as integer, ris as integer |
