Sub Pulsante12_Click()
' Pulsante Creazione Massive
' Filtro Dati più Estrazione Campi per creazione massive
Windows("Slot Provvisorio.xlsx").Activate
Rows("1:1").Select
With ActiveWindow
.SplitColumn = 0
.SplitRow = 1
ActiveWindow.FreezePanes = True
Selection.AutoFilter
ActiveWindow.Zoom = 85
ActiveWindow.LargeScroll ToRight:=-1
ActiveWindow.ScrollColumn = 7
ActiveWindow.ScrollColumn = 6
ActiveWindow.ScrollColumn = 5
ActiveWindow.ScrollColumn = 4
ActiveWindow.ScrollColumn = 3
ActiveWindow.ScrollColumn = 1
ActiveSheet.Range("$A$1:$AK$5823").AutoFilter Field:=1, Criteria1:="=*c", Operator:=xlAnd
ActiveSheet.Range("$A$1:$AK$5823").AutoFilter Field:=7, Criteria1:="00 - Open"
ActiveSheet.Range("$A$1:$AK$5823").AutoFilter Field:=10, Criteria1:="A"
Cells.Find(What:="data prossima proposta", After:=ActiveCell, LookIn:= _
xlValues, LookAt:=xlPart, SearchOrder:=xlByRows, SearchDirection:=xlNext, MatchCase:=False).Activate
Dim campo As Integer
campo = ActiveCell.Column - ActiveCell.End(xlToLeft).Column + 1
ActiveCell.AutoFilter Field:=campo, Criteria1:=xlFilterNextWeek, Operator:=xlFilterDynamic
Range("A:A,B:B,H:H,K:K,N:N").Select
Range("N1").Activate
Selection.Copy
Sheets.Add After:=Sheets(Sheets.Count)
ActiveSheet.Paste
Columns("A:E").Select
Columns("A:E").EntireColumn.AutoFit
Range("F1").Select
With Selection.Interior
.Pattern = xlSolid
.PatternColorIndex = xlAutomatic
.ColorIndex = 40
.TintAndShade = 0
.PatternTintAndShade = 0
Selection.NumberFormat = "General"
ActiveCell.FormulaR1C1 = "pct az"
Range("G1").Select
.Pattern = xlSolid
.ColorIndex = 40
.TintAndShade = 0
ActiveCell.FormulaR1C1 = "referente"
Range("H1").Select
.Pattern = xlSolid
.ColorIndex = 40
.TintAndShade = 0
ActiveCell.FormulaR1C1 = "sessione"
Range("F2").Select
Windows("Estrazione azionario.xlsx").Activate
Range("A1").Select
Range(Selection, Selection.End(xlToRight)).Select
Selection.Copy
ActiveSheet.Paste
Sheets("Foglio1").Select
Range("F2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-5],Foglio2!C[-5]:C[-1],5,FALSE)"
Range("f2").Select
ActiveSheet.Range("e2").End(xlDown).Offset(0, 1).Select
Range(Selection, Selection.End(xlUp)).Select
ActiveWindow.ScrollRow = 1
Selection.FillDown
Range("G2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-2],[Aree_2013.xlsx]Aree!C1:C5,5,FALSE)"
Range("G2").Select
ActiveSheet.Range("e2").End(xlDown).Offset(0, 2).Select
Selection.FillDown
'Formula suddivisione ptf
Range("H2").Select
ActiveCell.FormulaR1C1 = "=IF(RC[-2]=""#N/D"",""#N/D"",IF(RC[-5]<750000,IF(OR(RC[-4]=""PC2MO"",RC[-4]=""PC1PR""),""UCM"",""UDA""),IF(RC[-4]=""PC2MO"",IF(RC[-2]<22,""BCM"",IF(OR(LEFT(RC[-1],2)=""BR"",LEFT(RC[-1],2)=""CA"",LEFT(RC[-1],2)=""DI"",LEFT(RC[-1],2)=""FA""),""CMA"",""CMB"")),IF(RC[-4]=""PC1PR"",IF(OR(LEFT(RC[-1],2)=""BR"",LEFT(RC[-1],2)=""CA"",LEFT(RC[-1],2)=""DI"",LEFT(RC[-1],2)=""FA""),""CMA"",""CMB""),IF(RC[-4]=""PC3DI"",IF(RC[-2]<52,""BDA"",""DA""),""BDA"")))))"
Range("H2").Select
ActiveSheet.Range("e2").End(xlDown).Offset(0, 3).Select
Selection.FillDown
Columns("F:G").Select
Selection.Copy
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks:=False, Transpose:=False
'Nomenclatura Folder
Sheets("Foglio1").Name = "Sessione"
Sheets("Foglio2").Select
Sheets("Foglio2").Name = "Pct Azionaria"
Sheets("Foglio3").Select
Sheets("Foglio3").Name = "Verifica"
'Conteggio ptf per sessione
Sheets("Sessione").Select
Range("J3").Select
ActiveCell.FormulaR1C1 = "CMA"
Range("J4").Select
ActiveCell.FormulaR1C1 = "CMB"
Range("J5").Select
ActiveCell.FormulaR1C1 = "BCM"
Range("J6").Select
ActiveCell.FormulaR1C1 = "DA"
Range("J7").Select
ActiveCell.FormulaR1C1 = "BDA"
Range("J8").Select
ActiveCell.FormulaR1C1 = "UCM"
Range("J9").Select
ActiveCell.FormulaR1C1 = "UDA"
Range("J10").Select
ActiveCell.FormulaR1C1 = "#N/D"
Range("K3:K10").Select
Selection.FormulaR1C1 = "=COUNTIF(C[-3],RC[-1])"
Range("k12").Select
ActiveCell.FormulaR1C1 = "=SUM(R[-8]C:R[-1]C)"
Sheets("sessione").Activate
Rows("1:1").Select
With ActiveWindow
.SplitColumn = 0
.SplitRow = 1
If Range("K10") > 0 Then
MsgBox ("ATTENZIONE PTF NON PRESENTI IN ESTRAZIONE AZ")
ActiveSheet.Range("$A$1:$f$5823").AutoFilter Field:=6, Criteria1:="#N/D"
Dim cell As Range
LR = Cells(Rows.Count, "F").End(xlUp).Row
For Each cell In Range("F2:F" & LR)
If Application.WorksheetFunction.IsNA(cell) Then
s = InputBox("Inserire l'esposizione azionaria del ptf")
cell.Value = s
Rows("1:1").Select
'Apertura file sessioni e cancella contenuti a partire da riga 4
ChDir _
"T:InvAmm\Creazioni Massivesessioni"
Workbooks.Open Filename:= _
"T:InvAmm\Creazioni MassivesessioniBCM.xls"
"T:InvAmm\Creazioni MassivesessioniBDA.xls"
"T:InvAmm\Creazioni MassivesessioniCMA.xls"
"T:InvAmm\Creazioni MassivesessioniCMB.xls"
"T:InvAmm\Creazioni MassivesessioniDA.xls"
"T:InvAmm\Creazioni MassivesessioniUCM.xls"
"T:InvAmm\Creazioni MassivesessioniUDA.xls"
Application.Run "ConnectChartEvents"
Windows("UDA.xls").Activate
Range("A4").Select
Selection.Delete Shift:=xlUp
Range("a4").Select
Windows("UCM.xls").Activate
Range("A4").Select
Range("a4").Select
Windows("DA.xls").Activate
Range("A4").Select
Range("a4").Select
Windows("CMB.xls").Activate
Range("A4").Select
Range("a4").Select
Windows("CMA.xls").Activate
Range("A4").Select
Range("a4").Select
Windows("BDA.xls").Activate
Range("A4").Select
Range("A4").Select
Windows("BCM.xls").Activate
Range("A4").Select
Range("A4").Select
' Estrazione valori per singola sessione e copia nel singolo file
' selezione dei dati da copiare nelle singole sessioni
'UCM
LR1 = Workbooks("Slot Provvisorio").Sheets("Sessione").Cells(Rows.Count, "A").End(xlUp).Row
LR2 = Workbooks("UCM").Sheets("Dossier").Cells(Rows.Count, "A").End(xlUp).Row + 1
With Workbooks("Slot Provvisorio").Sheets("Sessione")
For r = 1 To LR1
If .Cells(r, 8).Value = "UCM" Then
.Range(.Cells(r, 1), .Cells(r, 1)).Copy Workbooks("UCM").Sheets("Dossier").Cells(LR2, 1)
LR2 = LR2 + 1
'UDA
LR2 = Workbooks("UDA").Sheets("Dossier").Cells(Rows.Count, "A").End(xlUp).Row + 1
For r = 1 To LR1
If .Cells(r, 8).Value = "UDA" Then
.Range(.Cells(r, 1), .Cells(r, 1)).Copy Workbooks("UDA").Sheets("Dossier").Cells(LR2, 1)
LR2 = LR2 + 1
'BDA
LR2 = Workbooks("BDA").Sheets("Dossier").Cells(Rows.Count, "A").End(xlUp).Row + 1
For r = 1 To LR1
If .Cells(r, 8).Value = "BDA" Then
.Range(.Cells(r, 1), .Cells(r, 1)).Copy Workbooks("BDA").Sheets("Dossier").Cells(LR2, 1)
LR2 = LR2 + 1
'DA
LR2 = Workbooks("DA").Sheets("Dossier").Cells(Rows.Count, "A").End(xlUp).Row + 1
For r = 1 To LR1
If .Cells(r, 8).Value = "DA" Then
.Range(.Cells(r, 1), .Cells(r, 1)).Copy Workbooks("DA").Sheets("Dossier").Cells(LR2, 1)
LR2 = LR2 + 1
'BCM
LR2 = Workbooks("BCM").Sheets("Dossier").Cells(Rows.Count, "A").End(xlUp).Row + 1
For r = 1 To LR1
If .Cells(r, 8).Value = "BCM" Then
.Range(.Cells(r, 1), .Cells(r, 1)).Copy Workbooks("BCM").Sheets("Dossier").Cells(LR2, 1)
LR2 = LR2 + 1
'CMB
LR2 = Workbooks("CMB").Sheets("Dossier").Cells(Rows.Count, "A").End(xlUp).Row + 1
For r = 1 To LR1
If .Cells(r, 8).Value = "CMB" Then
.Range(.Cells(r, 1), .Cells(r, 1)).Copy Workbooks("CMB").Sheets("Dossier").Cells(LR2, 1)
LR2 = LR2 + 1
'CMA
LR2 = Workbooks("CMA").Sheets("Dossier").Cells(Rows.Count, "A").End(xlUp).Row + 1
For r = 1 To LR1
If .Cells(r, 8).Value = "CMA" Then
.Range(.Cells(r, 1), .Cells(r, 1)).Copy Workbooks("CMA").Sheets("Dossier").Cells(LR2, 1)
LR2 = LR2 + 1
MsgBox "upload completato, SALVARE le sessioni nella cartella dello slot in lavorazione"
' processo di verifica finale
Windows("Schema_prod.xlsx").Activate
Rows("1:1").Select
With ActiveWindow
.SplitColumn = 0
.SplitRow = 1
Dim campo1 As Integer
campo1 = ActiveCell.Column - ActiveCell.End(xlToLeft).Column + 1
Windows("schema_prod.xlsx").Activate
Range("A1:B1").Select
Selection.Copy
Sheets("Verifica").Select
Range("E1").Select
ActiveSheet.Paste
Range("D2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-3],R2C5:R423C5,1,FALSE)"
Range("D2").Select
ActiveSheet.Range("C2").End(xlDown).Offset(0, 1).Select
Selection.FillDown
