If Trim(x) = Trim(cella) And Trim(cella.Offset(0, -4).Value) = "0" Then
APERTE = APERTE + 1
cella.Offset(0, -4).Value = Format(Date, "yyyymmdd")
If Trim(x) = Trim(cella) And Trim(cella.Offset(0, -4).Value) <> "0" Then
cella.Offset(0, 17) = Trim(cella.Offset(0, -4).Value) - Trim(cella.Offset(0, -5).Value)
max = Application.WorksheetFunction.max(T)
min = Application.WorksheetFunction.min(T)
If Trim(x) = Trim(cella) And Trim(cella.Offset(0, -4).Value) = Format(Date, "yyyymmdd") Then
cella.Offset(0, -4).Value = "0"
End If |
