Sub Pulsante1_Click()
Randomize Timer
Dim Valmax
Dim CL As Object
Dim Miamatrice As Range
Set Miamatrice = Range("A3:B3")
Valmax = 90
For Each CL In Miamatrice
CL.Value = Int(Rnd() * Valmax + 1)
Randomize (Timer)
Dim Valmax
Dim CL As Object
'Sheets("Foglio1").Select
Set Miamatrice = ActiveSheet.Range("A3:B4005")
Valmax = 90
Next |
Randomize (Timer)
Dim Valmax
Dim CL As Object
Valmax = 90
'CL.Value = Int(Rnd() * Valmax + 1)
CL.Value = Int((Rnd - Valmax + 1) * Rnd + Valmax)
Next |
