If Intersect(Target, Range("F1")) Is Nothing Then Exit Sub
Dim i As Long
Dim C_volte As Long
C_volte = 0
Dim SH1 As String
SH1 = "Foglio1"
For i = 2 To Sheets(SH1).Cells(Rows.Count, "A").End(xlUp).Row
If Sheets(SH1).Cells(i, "A") <> Range("F1") Then
If Sheets(SH1).Cells(i, "B") = Range("F3") And Sheets(SH1).Cells(i, "C") = Range("F2") Then
C_volte = C_volte + 1
Exit For
Range("H2") = C_volte '' mettere il Range a B2
Dim i As Long, Nriga As Long
Dim C_volte As Long
C_volte = 0
Dim SH1 As String
SH1 = "Foglio1"
Dim Cliente As String, Citta As String
If Sheets(SH1).Cells(i, "A") = Range("F1") Then
Nriga = i
Cliente = Sheets(SH1).Cells(i, "C")
Citta = Sheets(SH1).Cells(i, "B")
For i = 2 To Nriga
If Sheets(SH1).Cells(i, "C") = Cliente And Sheets(SH1).Cells(i, "B") = Citta Then
Range("B2") = C_volte
Range("F2") = Cliente
Range("F3") = Citta
Range("B3") = "SI"
If C_volte > 3 Then Range("B3") = "NO"
Sheets("Gastos").Unprotect Password:="123"
If Not Intersect(Target, Range("F1")) Is Nothing Then
Select Case Len(Target.Value)
Case Is = 1
Target.Value = Year(Date) & "0000" & Target.Value
Case Is = 2
Target.Value = Year(Date) & "000" & Target.Value
Case Is = 3
Target.Value = Year(Date) & "00" & Target.Value
Case Is = 4
Target.Value = Year(Date) & "0" & Target.Value
Case Is = 5
Target.Value = Year(Date) & "" & Target.Value
End Select
Dim C_volte As Long
C_volte = 0
Dim SH1 As String
SH1 = "Escalas"
Dim Barco As String, Puerto As String
Nriga = i
Barco = Sheets(SH1).Cells(i, "C")
Puerto = Sheets(SH1).Cells(i, "B")
For i = 2 To Nriga
If Sheets(SH1).Cells(i, "C") = Barco And Sheets(SH1).Cells(i, "B") = Puerto Then
Range("C62") = "SI"
If C_volte > 3 Then Range("C62") = "NO"
Sheets("Gastos").Protect Password:="123"
If Intersect(Target, Range("F1")) Is Nothing Then Exit Sub ''controllo scrittura F1 non protetta
''''''''''''''' indicizzazione delle variabili '''''''''''''
Dim C_volte As Long
C_volte = 0
Dim SH1 As String
SH1 = "Escalas"
''''''''''''''''''Inizia il Lavoro ''''''''''''''''''''
Sheets("Gastos").Unprotect Password:="123" ''Toglie protezione foglio
Select Case Len(Target.Value) ''Controllo immissione in F1
Case Is = 1
Case Is = 2
Case Is = 3
Case Is = 4
Case Is = 5
End Select '' Fine controllo
'' ricerca dei dati per il calcolo
Nriga = i
For i = 2 To Nriga
Range("C62") = "SI"
''''''' fine lavoro
Sheets("Gastos").Protect Password:="123" ''attivazione della pass nel foglio
