Sub Riduci()
ZoomToRange ZoomThisRange:=Range("A1:K40"), PreserveRows:=True
Sub Ingrandisci()
ZoomToRange ZoomThisRange:=Range("A1:K40"), PreserveRows:=False
Sub ZoomToRange(ByVal ZoomThisRange As Range, _
ByVal PreserveRows As Boolean)
Dim Wind As Window
Set Wind = ActiveWindow
Application.Goto ZoomThisRange(1, 1), True
With ZoomThisRange
If PreserveRows = True Then
.Resize(.Rows.Count, 1).Select
.Resize(1, .Columns.Count).Select
With Wind
.Zoom = True
.VisibleRange(1, 1).Select
Declare Function sndPlaySound32 Lib "WINMM.DLL" Alias "sndPlaySoundA" _
(ByVal lpszSoundName As String, ByVal uFlags As Long) As Long
Sub Informazioni_Varie()
Sheets("NOTE").WindowsMediaPlayer0.URL = "" ' INTERROMPE MUSICA MENU
' CREARE SUONO (FARE!!!)
' CREARE MUSICA LETTURA (FARE!!!)
Application.DisplayFullScreen = True 'VISUALIZZO A TUTTO SCHERMO
Foglio509.ScrollArea = "A111:S135" 'BLOCCO SCROLL
Sheets("MENU").Visible = False
Sheets("ISTRUZIONI").Visible = True
'ADATTA SCHERMO.............................................................
ZoomToRange ZoomThisRange:=Range("A111:S135"), PreserveRows:=False
Range("N111").Select
Sheets("NOTE").WindowsMediaPlayer0.URL = "" ' RIAVVIA MUSICA MENU
' CREARE SUONO
Dim Wind As Window
With ZoomThisRange
With Wind
.Zoom = True
Range("N111").Select ' non viene selezionata....??????!!!!!!!
