if condizione then
With tuorange
.Merge
.Font.Underline = xlUnderlineStyleSingle
end if |
Sub Settimane()
Dim Sh As Worksheet, Lr As Long, Lr1 As Long
Dim i As Long, x As Long, n As Long, SetNum As Integer
Dim Setm(), DataIn As Long, DataFin As Long, LastCol As Long
Dim GiornoIn As Integer, GiornoFin As Integer
Dim MeseIn As Integer, MeseFin As Integer
Dim SetIn As Integer, SetFin As Integer
Set Sh = Worksheets("Rr")
Lr = Sh.Cells(Rows.Count, 2).End(xlUp).Row
Lr1 = Sh.Cells(Rows.Count, 4).End(xlUp).Row
If Lr1 < 14 Then Lr1 = 14
LastCol = Sh.Cells(14, Columns.Count).End(xlToLeft).Column
Setm = Array(SetIn, SetFin)
With Sh.Range(Cells(15, 4), Cells(Lr1 + 1, LastCol))
.ClearContents
.UnMerge
.Borders(xlEdgeLeft).LineStyle = xlNone
.Borders(xlEdgeTop).LineStyle = xlNone
.Borders(xlEdgeBottom).LineStyle = xlNone
.Borders(xlEdgeRight).LineStyle = xlNone
.Borders(xlInsideVertical).LineStyle = xlNone
.Interior.Color = xlNone
Lr1 = 14
For i = 4 To Lr
If IsDate(Sh.Cells(i, 4).Value) And IsDate(Sh.Cells(i, 5).Value) Then
DataIn = Sh.Cells(i, 4).Value
DataFin = Sh.Cells(i, 5).Value
Setm(0) = WorksheetFunction.WeekNum(DataIn, 2)
Setm(1) = WorksheetFunction.WeekNum(DataFin, 2)
If Setm(0) <= Setm(1) Then
For x = 0 To 1
For n = 6 To LastCol
SetNum = Val(Right(Sh.Cells(14, n).Value, Len(Sh.Cells(14, n).Value) - 2))
If SetNum = Setm(x) Then
Setm(x) = n
Exit For
Next n
Next x
Lr1 = Lr1 + 1
With Sh.Range(Cells(Lr1, 4), Cells(Lr1, LastCol))
.Borders(xlEdgeTop).LineStyle = xlContinuous
.Borders(xlEdgeBottom).LineStyle = xlContinuous
.Borders(xlEdgeLeft).LineStyle = xlContinuous
.Borders(xlEdgeRight).LineStyle = xlContinuous
.Borders(xlInsideVertical).LineStyle = xlContinuous
Sh.Cells(Lr1, 4).Value = Sh.Cells(i, 3).Value
Sh.Cells(Lr1, 5).Value = Sh.Cells(i, 2).Value
Sh.Range(Cells(Lr1, Setm(0)), Cells(Lr1, Setm(1))).Merge
Sh.Range(Cells(Lr1, Setm(0)), Cells(Lr1, Setm(1))).Interior.Color = RGB(255, 155, 102)
GiornoIn = Day(DataIn): MeseIn = Month(DataIn)
GiornoFin = Day(DataFin): MeseFin = Month(DataFin)
Sh.Cells(Lr1, Setm(0)).Value = GiornoIn & "/" & MeseIn & " - " & GiornoFin & "/" & MeseFin
Set Sh = Nothing
.ClearContents
.UnMerge
.Borders.LineStyle = xlNone
.Borders.LineStyle = xlContinuous
End With |
Sub Settimane()
Dim MeseIn As Integer, MeseFin As Integer, Trovato As Boolean
.ClearContents
.UnMerge
Lr1 = 14
For i = 4 To Lr
For x = 0 To 1
Trovato = False
Setm(x) = n
Trovato = True
Exit For
Next n
Next x
If Trovato = False Then
MsgBox "Settimana per la categoria " & Sh.Cells(i, 3).Value & " non trovata"
Lr1 = Lr1 + 1
Sh.Range(Cells(Lr1, 4), Cells(Lr1, LastCol)).Borders.LineStyle = xlContinuous
MsgBox "Data Finale inferiore a data Iniziale categoria " & Sh.Cells(i, 3).Value
MsgBox "Controllare la validità o la presenza delle date per la categoria " & Sh.Cells(i, 3).Value
Set Sh = Nothing
Sub Settimane()
.ClearContents
.UnMerge
Lr1 = 14
For i = 4 To Lr
If Sh.Cells(i, 4).Value <= Sh.Cells(i, 5).Value Then
For x = 0 To 1
Trovato = False
Setm(x) = n
Trovato = True
Exit For
Next n
Next x
Lr1 = Lr1 + 1
Set Sh = Nothing
