Sub Macro1()
Dim fPath As String
fPath = ActiveWorkbook.Path
ActiveWorkbook.SaveAs Filename:=fPath & "" & Range("a1").Value & ".xlsm", FileFormat:= _
xlOpenXMLWorkbookMacroEnabled, CreateBackup:=False
Sub Test()
Dim ToPdf As Variant
Dim CurSH As Object
Set CurSH = ActiveSheet
ToPdf = Array("Foglio5", "Foglio8", "Foglio2")
Sheets(ToPdf).Select
ActiveSheet.ExportAsFixedFormat Type:=xlTypePDF, Filename:= _
"C:????????????.pdf", Quality:=xlQualityStandard, _
IncludeDocProperties:=True, IgnorePrintAreas:=False, OpenAfterPublish:= _
False
Set CurSH = Nothing
Sheets("Foglio1").Select
Sub Test()
Dim CurSH As Object
"C:clienti" & Range("E9").Value & ".pdf", Quality:=xlQualityStandard, _
False
Set CurSH = Nothing
Sub salvapdf1()
Dim CurSH As Object
ToPdf = Array("Riepilogo", "CI3", "report")
"C:clienti" & Sheets(1).Range("E9").Value & ".pdf", Quality:=xlQualityStandard, _
False
Set CurSH = Nothing
Sub salvapdf1()
Dim CurSH As Object
"C:clientipippo.pdf" & Sheets(1).Range("C9").Value & ".pdf", Quality:=xlQualityStandard, _
False
Set CurSH = Nothing
Sheets("riepilogo").Select
Sub salvapdf1()
Dim CurSH As Object
"C:clienti" & WorkSheets("Riepilogo").Range("C9").Value & ".pdf", Quality:=xlQualityStandard, _
False
Set CurSH = Nothing
Dim CurSH As Object Set CurSH = ActiveSheet Set CurSH = Nothing |
