Sub Macro1()
Dim rng As Range
Dim cel As Range
Dim ur As Long
Dim lr As Long
Dim FGL As String
Set rng = Range("a1:a" & Cells(Rows.Count, 1).End(xlUp).Row)
For Each cel In rng
FGL = cel.Offset(0, 3).Value
ur = Worksheets(FGL).Cells(Rows.Count, 1).End(xlUp).Row
Range("A" & cel.Row & ":" & "d" & cel.Row).Copy Destination:=Worksheets(FGL).Range("A" & ur + 1)
Next cel
Sub SuddividiPerFogli()
Dim i As Integer
Dim CL As Range, Intervallo As Range, Elenco As New Collection
Dim Valori As Variant
Dim rng As Range
Dim cel As Range
Dim ur As Long
Dim lr As Long
Dim FGL As String
Worksheets("Foglio1").Select
Set Intervallo = Range("d1", Range("d1").End(xlDown))
For Each CL In Intervallo
Elenco.Add CL.Value, CStr(CL.Value)
On Error GoTo 0
For i = 1 To Elenco.Count
ThisWorkbook.Sheets.Add After:=Worksheets(Worksheets.Count)
Sheets(i + 1).Name = Elenco(i)
For i = 2 To Sheets.Count
Sheets(i).Cells(1, 1).Value = "NOME"
Sheets(i).Cells(1, 2).Value = "COGNOME"
Sheets(i).Cells(1, 3).Value = "ETA"
Sheets(i).Cells(1, 4).Value = "LUOGO"
Worksheets("Foglio1").Activate
For Each cel In rng
Next cel
1 Sub Macro1()
2 Dim rng As Range
3 Dim cel As Range
4 Dim ur As Long
5 Dim lr As Long
6 Set rng = Range("D1:D" & Cells(Rows.Count, 1).End(xlUp).Row)
7 Application.ScreenUpdating = False
8 For Each cel In rng
9 lr = Worksheets("ESTERE").Cells(Rows.Count, 1).End(xlUp).Row
10 ur = Worksheets("ITALIANE").Cells(Rows.Count, 1).End(xlUp).Row
11 If cel.Value = "LONDRA" Or cel.Value = "BERLINO" Or cel.Value = "MADRID" Then
12 Range("A" & cel.Row & ":" & "d" & cel.Row).Copy Destination:=Worksheets("ESTERE").Range("A" & lr + 1)
13 Else
14 Range("A" & cel.Row & ":" & "d" & cel.Row).Copy Destination:=Worksheets("ITALIANE").Range("A" & ur + 1)
15 End If
16 Next cel
17 Application.ScreenUpdating = True
18 MsgBox "Operazione effettuata"
19 Set rng = Nothing
20 Set cel = Nothing
21 End Sub
11 If cel.Value = "LONDRA" Or cel.Value = "BERLINO" Or cel.Value = "MADRID" Then 11 If Trim(cel.Value) = "LONDRA" Or cel.Value = "BERLINO" Or cel.Value = "MADRID" Then |
