Sub Pulsante1_Click()
Dim rng As Range, max_value As Long, cell As Range
Dim d As Single
Set rng = Range("B2:B14")
max_value = Application.Max(rng)
For Each cell In rng
d = cell / max_value
cell.Offset(, 1) = d
Randomize Timer
Do
For Each cell In rng.Offset(, 1)
cell = Rnd(1) * 1
Loop Until Range("C16") - Range("B15") < 1# And Range("B16") - Range("C16") < 1#
MsgBox "Finito"
Dim cell As Range
Randomize Timer
Do
For Each cell In Range("C2:C14")
cell = Rnd(1) * 1
Loop Until Range("C16") >= Range("B15") And Range("C16") <= Range("B16")
MsgBox "Finito"
| scossa's web site |
| Se tu hai una mela, ed io ho una mela, e ce le scambiamo, allora tu ed io abbiamo sempre una mela per uno. Ma se tu hai un'idea, ed io ho un'idea, e ce le scambiamo, allora abbiamo entrambi due idee. (George Bernard Shaw) |
Dim ws As Worksheet
Dim rngMin As Range
Dim rngMax As Range
Dim rngVal As Range
Dim rngPesi As Range
Dim rngTarget As Range
Dim nPeso As Double
Dim nOb As Double
Dim j As Long
Dim k As Long
Set ws = ActiveSheet
Set rngVal = ws.Range("B2:B14")
Set rngPesi = ws.Range("C2:C14")
Set rngTarget = ws.Range("C16")
nOb = Round(ws.Range("B16").Value, 3)
With Application.WorksheetFunction
Set rngMin = rngVal.Cells(.Match(.Small(rngVal, 1), rngVal, 0), 1)
Set rngMax = rngVal.Cells(.Match(.Large(rngVal, 1), rngVal, 0), 1)
rngPesi.Value = Round(1 / rngPesi.Rows.Count, 6)
nPeso = Round(.Sum(rngPesi), 5)
j = 0
Do While Round(rngTarget.Value, 2) <> nOb And j <= rngPesi.Rows.Count
If Round(rngTarget.Value, 2) > nOb Then
With rngMax.Offset(0, 1)
If .Value > 0.0001 And rngMin.Offset(0, 1).Value < 0.9999 Then
.Value = .Value - 0.0001
rngMin.Offset(0, 1).Value = rngMin.Offset(0, 1).Value + 0.0001
j = j + 1
Set rngMin = rngVal.Cells(.Match(.Small(rngVal, j), rngVal, 0), 1)
Set rngMax = rngVal.Cells(.Match(.Large(rngVal, j), rngVal, 0), 1)
If .Value < 0.9999 And rngMin.Offset(0, 1).Value > 0.0002 Then
.Value = .Value + 0.0001
rngMin.Offset(0, 1).Value = rngMin.Offset(0, 1).Value - 0.0001
j = j + 1
Loop
If Round(rngTarget.Value, 2) = nOb Then MsgBox "Bingo!" Else MsgBox "Failed!"
Set rngPesi = Nothing
Set rngTarget = Nothing
Set rngOb = Nothing
| scossa's web site |
| scossa's web site |
Dim ws As Worksheet
Dim rngMin As Range
Dim rngMax As Range
Dim rngVal As Range
Dim nPeso As Double
Dim nOb As Double
Dim j As Long
Dim nRows As Long
Dim nRand As Single
Dim nDummy
nOb = Round(ws.Range("B16").Value, 4)
nRows = rngPesi.Rows.Count
rngPesi.Value = Round(1 / nRows, 6)
For j = 1 To Int(nRows / 2)
Randomize Timer
nRand = Application.RandBetween(5, 10) / 100 + Rnd() / 1000
nDummy = rngPesi.Offset(Int(nRows / 2), 0).Cells(1, 1).Value
If Abs(nDummy + (rngPesi(j, 1).Value - nRand)) < 1 And Abs(nDummy + (rngPesi(j, 1).Value - nRand)) > 0 Then
rngPesi.Offset(Int(nRows / 2) + j, 0).Cells(1, 1).Value = nDummy + (rngPesi(j, 1).Value - nRand)
rngPesi(j, 1) = nRand
j = 0
Do While Round(rngTarget.Value, 4) <> nOb And j <= nRows
If .Value > 0.000001 And rngMin.Offset(0, 1).Value < 0.999999 Then
.Value = .Value - 0.000001
rngMin.Offset(0, 1).Value = rngMin.Offset(0, 1).Value + 0.000001
j = j + 1
If .Value < 0.999999 And rngMin.Offset(0, 1).Value > 0.000001 Then
.Value = .Value + 0.000001
rngMin.Offset(0, 1).Value = rngMin.Offset(0, 1).Value - 0.000001
j = j + 1
Loop
If Round(rngTarget.Value, 4) = nOb Then MsgBox "Bingo!" Else MsgBox "Failed!"
Set rngOb = Nothing
| scossa's web site |
| scossa's web site |
