'Trascrive i Risultati nella Zona di record'
Sheets("Formazioni").Select
Range("BF3:BH9").Select
Selection.Copy
r = Cells(2, 58).Value
Sheets("Risultati").Select
Cells((r - 1) * 7 + 1, 52).Select
Selection.PasteSpecial Paste:=xlValues, Operation:=xlNone, SkipBlanks:= _
False, Transpose:=False
Range("Aq4:Ar10").Select
Selection.Copy
Cells((r - 1) * 7 + 1, 55).Select
'Classifica Generale'
Sheets("Classifiche").Select
Range("V4:AT17").Select
Range("AT17").Activate
Selection.Sort Key1:=Range("W4"), Order1:=xlDescending, Key2:=Range("AF4" _
), Order2:=xlDescending, Key3:=Range("AD4"), Order3:=xlDescending, _
Header:=xlNo, OrderCustom:=1, MatchCase:=False, Orientation:= _
xlTopToBottom, DataOption1:=xlSortNormal, DataOption2:=xlSortNormal, _
DataOption3:=xlSortNormal
'Classifica a Punti'
Range("Aj19:Ak33").Select
Selection.Sort Key1:=Range("Ak20"), Order1:=xlDescending, Header:=xlGuess _
, OrderCustom:=1, MatchCase:=False, Orientation:=xlTopToBottom
Range("Aj20:Ak33").Select
Selection.Copy
Cells((r - 1) * 14 + 1, 60).Select
'Ordinare Classifica Punti'
Range("u19:av33").Select
Range("av33").Activate
Selection.Sort Key1:=Range("u19"), Order1:=xlDescending, Header:=xlGuess, _
'Classifica_Parziale'
Range("V4:W17").Select
Selection.Copy
Cells((r - 1) * 14 + 1, 66).Select
'Conteggio Media Portiere'
Range("Aj212:AK225").Select
Selection.Copy
Cells((r - 1) * 14 + 1, 126).Select
