Public Sub Callback1(control As IRibbonControl)
check
Public Sub Callback2(control As IRibbonControl)
Preparation
Public Sub Callback3(control As IRibbonControl)
cancella
Public Sub Callback4(control As IRibbonControl)
UserForm1.MultiPage1.Value = 0
UserForm1.Show
Public Sub Callback5(control As IRibbonControl)
SolverCall
Public Sub Callback6(control As IRibbonControl)
Grafico
Public Sub ConvertLenght()
For Each c In Range(ActiveWorkbook.Names("lenghtprofile"))
c.Value = modify_lenght(c.Value)
Range(ActiveWorkbook.Names("lcheck")).Value = "m"
Public Sub ConvertAltitude()
For Each c In Range(ActiveWorkbook.Names("Altitude"))
c.Value = modify_altitude(c.Value)
Range(ActiveWorkbook.Names("acheck")).Value = "m"
Public Sub ConvertPressure()
b = Range(ActiveWorkbook.Names("pcheck")).Value
For Each c In Range(ActiveWorkbook.Names("PressureProfile"))
Select Case b
Case "bara", "psia", "KPaa", "Paa", "MPaa"
c.Value = modify_pressure(c.Value) - Cells(c.Row, c.Column + 2).Value
Case "barg", "psig", "KPag", "Pag", "MPag"
End Select
Range(ActiveWorkbook.Names("pcheck")).Value = "barg"
Public Function Lconvert(a)
Select Case a
Case "m"
Lconvert = 1
Case "km"
Lconvert = 1000
Case "in"
Lconvert = 0.0254
Case "ft"
Lconvert = 0.3048
End Select
Public Function Pconvert(a)
Select Case a
Case "barg", "bara"
Pconvert = 1
Case "psig", "psia"
Pconvert = 0.0689476
Case "KPag", "KPaa"
Pconvert = 0.01
Case "Pag", "Paa"
Pconvert = 10 ^ -5
Case "MPag", "MPaa"
Pconvert = 10
End Select
Public Function modify_lenght(a)
lck = Range(ActiveWorkbook.Names("lcheck")).Value
modify_lenght = a * Lconvert(lck)
Public Function modify_altitude(a)
ack = Range(ActiveWorkbook.Names("acheck")).Value
modify_altitude = a * Lconvert(ack)
Public Function modify_pressure(a)
pck = Range(ActiveWorkbook.Names("pcheck")).Value
modify_pressure = a * Pconvert(pck)
Public Sub Area()
Pi = Excel.WorksheetFunction.Pi
For Each c In Range(ActiveWorkbook.Names("diameter"))
col = c.Column
Row = c.Row
tk = col + 1
sup = col + 5
Diam = (c.Value - 2 * Cells(Row, tk).Value) / 1000
Cells(Row, sup).Value = (Pi * Diam ^ 2) / 4
Public Sub Temperature()
For Each d In Range(ActiveWorkbook.Names("diameter"))
iniz = d.Column + 2
fin = d.Column + 3
rowin = d.Row
Ttcol = d.Column + 4
Tt = Cells(rowin, Ttcol).Value
Viniz = Cells(rowin, iniz).Value
Vfin = Cells(rowin, fin).Value
For Each e In Range(ActiveWorkbook.Names("lenghtprofile"))
Row = e.Row
col = e.Column
Tcol = col + 3
m = e.Value
If m >= Viniz And m <= Vfin Then
Cells(Row, Tcol).Value = Tt
Public Sub Prif()
R = 1000 * Range(ActiveWorkbook.Names("CgasMW")).Value
CostExp = (9.81 / (R * (273.15 + 20)))
col = c.Column
Row = c.Row
colP = col + 3
h = c.Value
P0 = 1.01325
Cells(Row, colP).Value = P0 * Exp(-CostExp * h)
Public Sub Volume()
iniz = d.Column + 2
fin = d.Column + 3
rowin = d.Row
Acol = d.Column + 5
surface = Cells(rowin, Acol).Value
Row = e.Row
col = e.Column
Vcol = col + 5
m = e.Value
Cells(Row, Vcol).Value = surface * Abs((Cells(Row, col).Value - Cells(Row + 1, col)))
Range(ActiveWorkbook.Names("Vol")).End(xlDown).Select
ActiveCell.Delete
Public Sub Pequib_iniz()
Range(ActiveWorkbook.Names("PEquilib")).Value = Excel.WorksheetFunction.Average(Range(ActiveWorkbook.Names("PressureProfile")))
Public Sub gamma1()
Range(ActiveWorkbook.Names("ggamma1")).Value = Excel.WorksheetFunction.Average(Range(ActiveWorkbook.Names("gamma")))
Public Sub Volume_Final_formula()
nc = Range(ActiveWorkbook.Names("Vol")).Count + 5
Range("g6").Formula = "=F6*(EXP(-(PEquilib-C6)/(ggamma1*PEquilib)))"
Range("g6").Select
Selection.AutoFill Destination:=Range("G6:G" & nc)
'Range("g6").Formula = "=F6*(EXP(-(PEquilib-C6)/(gamma*PEquilib)))"
Public Sub density_final_formula()
Range("h6").Formula = "=((PEquilib+E6)*100)/(CgasMW*(D6+273.15))"
Range("h6").Select
Selection.AutoFill Destination:=Range("h6:h" & nc)
Public Sub work_final_formula()
Range("i6").Formula = "=((PEquilib+E6)*G6-(C6+E6)*F6)/(1-ggamma1)"
Range("i6").Select
Selection.AutoFill Destination:=Range("i6:i" & nc)
Public Sub shiftwork_final_formula()
Range("j6").Formula = "=(H6*9.81*ABS(F6-G6)*(B6-B7))"
Range("j6").Select
Selection.AutoFill Destination:=Range("j6:j" & nc)
Public Sub delta()
Range(ActiveWorkbook.Names("deltawork")).Formula = "=SUM(Work)+SUM(shiftwork)"
Range(ActiveWorkbook.Names("deltavol")).Formula = "=abs(sum(Vol)-SUM(VOlfinal))"
Range(ActiveWorkbook.Names("deltaperc")).Formula = "=IF(deltavol<>"""",(ABS(SUM(Vol)-SUM(Volfinal))/SUM(Vol)),"""")"
Public Sub PressProf()
nc = Range(ActiveWorkbook.Names("lenghtprofile")).Count + 5
Range("k6").Formula = "=PEquilib+(9.81*H6*(0-B6))/100000"
Range("k7").Formula = "=K6+(9.81*H6*(B6-B7)/100000)"
Range("k7").Select
Selection.AutoFill Destination:=Range("k7:k" & nc)
Public Sub check()
'CHECK LENGHT DATA
clenght = 0
If Not IsNumeric(e) Or IsEmpty(e) Then
With e.Interior
.Pattern = xlSolid
.PatternColorIndex = xlAutomatic
.Color = 65535
.TintAndShade = 0
.PatternTintAndShade = 0
clenght = clenght + 1
With e.Interior
.Pattern = xlNone
.TintAndShade = 0
clenght = clenght + 0
'CHECK ALTITUDE DATA
caltitude = 0
For Each f In Range(ActiveWorkbook.Names("Altitude"))
If Not IsNumeric(f) Or IsEmpty(f) Then
With f.Interior
.Pattern = xlSolid
.Color = 65535
.TintAndShade = 0
caltitude = caltitudet + 1
With f.Interior
.Pattern = xlNone
.TintAndShade = 0
caltitude = caltitude + 0
'CHECK PRESSURE PROFILE DATA
cpress = 0
For Each g In Range(ActiveWorkbook.Names("PressureProfile"))
If Not IsNumeric(g) Or IsEmpty(g) Then
With g.Interior
.Pattern = xlSolid
.Color = 65535
.TintAndShade = 0
cpress = cpress + 1
With g.Interior
.Pattern = xlNone
.TintAndShade = 0
cpress = cpress + 0
'CHECK DIAMETER DATA
n = Range(ActiveWorkbook.Names("diameter")).Count + 5
'Dd = Range("M6", "Q" & n)
cdiam = 0
For Each h In Range("M6", "Q" & n)
If Not IsNumeric(h) Or IsEmpty(h) Then
With h.Interior
.Pattern = xlSolid
.Color = 65535
.TintAndShade = 0
cdiam = cdiam + 1
With h.Interior
.Pattern = xlNone
.TintAndShade = 0
cdiam = cdiam + 0
'CHECK GAS DATA
cgasd = 0
For Each i In Range(ActiveWorkbook.Names("gdata"))
If Not IsNumeric(i) Or IsEmpty(i) Then
With i.Interior
.Pattern = xlSolid
.Color = 65535
.TintAndShade = 0
cgasd = cgasd + 1
With i.Interior
.Pattern = xlNone
.TintAndShade = 0
cgasd = cgasd + 0
'Messaggi
'Lunghezza
If clenght = 0 Then
txtL = "OK"
txtL = "there isare " & clenght & " cell(s) that isare not numbers. Check yellow cells and correct"
'Altitude
If caltitude = 0 Then
txtA = "OK"
txtA = "there isare " & clenght & " cell(s) that isare not numbers. Check yellow cells and correct"
'Pressure
If cpress = 0 Then
txtP = "OK"
txtP = "there isare " & clenght & " cell(s) that isare not numbers. Check yellow cells and correct"
'Diameter
If cdiam = 0 Then
txtD = "OK"
txtD = "there isare " & clenght & " cell(s) that isare not numbers. Check yellow cells and correct"
'Gas
If cgasd = 0 Then
txtG = "OK"
txtGD = "there isare " & clenght & " cell(s) that isare not numbers. Check yellow cells and correct"
somma = clenght + caltitude + cpress + cdiam + cgasd
If somma = 0 Then
txtS = "Check complete. Can proceed with Sheet preparation"
Range(ActiveWorkbook.Names("start")).Value = 1
txtS = "Correct and Check again"
Range(ActiveWorkbook.Names("start")).Value = 0
MsgBox "Lenght: " & txtL & vbNewLine & "Altitude: " & txtA & vbNewLine & "Pressure: " & txtP & vbNewLine & "Pipeline geometry: " & txtD & vbNewLine & "Gas Prop: " & txtG & vbNewLine & txtS
Public Sub Preparation()
If Range(ActiveWorkbook.Names("start")).Value = 0 Then
MsgBox "Before preparing Worksheet check data, then try again"
ConvertLenght
ConvertAltitude
ConvertPressure
Area
Temperature
Prif
Volume
Pequib_iniz
gamma1
work_final_formula
delta
PressProf
MsgBox "Worksheet ready to be used"
Public Sub cancella()
mm = Range(ActiveWorkbook.Names("lenghtprofile")).Count + 5
nn = Range(ActiveWorkbook.Names("diameter")).Count + 5
Range("A6", "K" & mm).ClearContents
Range("M6", "R" & nn).ClearContents
Range("U6", "W6").ClearContents
Range(ActiveWorkbook.Names("PEquilib")).ClearContents
Range(ActiveWorkbook.Names("ggamma1")).ClearContents
Range(ActiveWorkbook.Names("deltawork")).ClearContents
Range(ActiveWorkbook.Names("deltavol")).ClearContents
Public Sub SolverCall()
MsgBox "Before solving, check and prepare Worksheet, then try again"
SolverAdd CellRef:="$F$2", Relation:=1, FormulaText:="0.1"
SolverOk SetCell:="$E$1", MaxMinVal:=3, ValueOf:=0, ByChange:="$B$1", Engine:=1 _
, EngineDesc:="GRG Nonlinear"
SolverSolve
'SolverOk SetCell:="$E$1", MaxMinVal:=3, ValueOf:=0, ByChange:="$B$1", Engine:=1 _
' , EngineDesc:="GRG Nonlinear"
' SolverAdd CellRef:="$F$2", Relation:=1, FormulaText:="0.1"
'SolverSolve
Sub Grafico()
Dim sh As Worksheet
For i = 1 To Worksheets.Count
If ActiveWorkbook.Sheets(i).Name = "SD Pressure" Then
a = ActiveWorkbook.Sheets(i).Name
ActiveWorkbook.Sheets(i).Delete
ActiveSheet.Shapes.AddChart2(240, xlXYScatterSmoothNoMarkers).Select
ActiveChart.SetSourceData Source:=Range( _
"lenghtprofile,PressureProfile,Peqprofile")
With ActiveChart
'chart name
.HasTitle = True
.ChartTitle.Characters.Text = "Profilo Pressione"
'X axis name
.Axes(xlCategory, xlPrimary).HasTitle = True
.Axes(xlCategory, xlPrimary).AxisTitle.Characters.Text = "Lenght (m)"
'y-axis name
.Axes(xlValue, xlPrimary).HasTitle = True
.Axes(xlValue, xlPrimary).AxisTitle.Characters.Text = "Pressure (barg)"
.SetElement (msoElementLegendTop)
.SeriesCollection(1).Name = "Pressure"
.SeriesCollection(2).Name = "SD Pressure"
.Location Where:=xlLocationAsNewSheet, Name:="SD Pressure"
