Sub Creo_pivot1(Nome_sheet, almenoUNO As String)
Dim MyDate, Data_vis, mesepiv As Date
MyDate = Date
Data_vis = Date
MyDate = Format(MyDate, "dd_mm_yy")
almenoUNO = 1
Dim MesiUnione(12)
Dim mesi_ris
Dim ind_mesi, ind, numcolPiv, numrigPiv, colonna, riga, colPivNumero, rigaPiv As Long
Dim Availab, a, colPivLet, colPivLettera, descriz_prova As String
Dim tot_bench, tot_over, tot_partial, tot_under, tot_ok As Long
Dim totale_bench, totale_over, totale_partial, totale_under, totale_ok As Integer
ind_mesi = 67 ' attenzione a qs colonna WRap ha già modificato più volte la posizione
Sheets(2).Select
For ind = 1 To 12
mesepiv = Sheets(2).Cells(1, ind_mesi)
MesiUnione(ind) = Format(mesepiv, "mmm-yy")
ind_mesi = ind_mesi + 1
Next ind
Dim numcol, numrow As Long
Dim Nome_sheet_pivot As String
Nome_sheet_pivot = "Demand Resources " & codeITOABS
numcol = (Worksheets(Nome_sheet).Cells(1, Columns.Count).End(xlToLeft).Column)
numrow = (Worksheets(Nome_sheet).Cells(Application.Rows.Count, 7).End(xlUp).Row) 'testo la colonna Portfolio per righe piene
Worksheets.Add(after:=Sheets(Worksheets.Count)).Name = Nome_sheet_pivot
Sheets(Nome_sheet_pivot).Select
With ActiveWorkbook.Sheets(Nome_sheet_pivot).Tab
.ColorIndex = 45
.TintAndShade = 0
ActiveWorkbook.PivotCaches.Create(SourceType:=xlDatabase, SourceData:= _
Nome_sheet & "!R1C1:R" & numrow & "C" & numcol, Version:=xlPivotTableVersion15).CreatePivotTable _
TableDestination:="'" & Nome_sheet_pivot & "'!R1C1", TableName:="PivotTable1", _
DefaultVersion:=xlPivotTableVersion15
'ActiveWindow.SmallScroll Down:=3
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Portfolio")
.Orientation = xlPageField
.Position = 1
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Owning Country")
.Position = 1
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Payroll Country")
.Position = 1
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Manager Name")
' .LayoutBlankLine = True
' .LayoutForm = xlTabular
.Position = 1
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Resource Name")
.Orientation = xlRowField
.Position = 1
ActiveSheet.PivotTables("PivotTable1").PivotFields("Resource Name"). _
Subtotals = Array(False, False, False, False, False, False, False, False, False, False, _
False, False)
PivotFilters.Add2 Type:=xlCaptionDoesNotEqual, Value1:="PromiseResource"
'ActiveSheet.PivotTables("PivotTable1").PivotFields("Resource Name"). _
PivotFilters.Add3 Type:=xlCaptionDoesNotEqual, Value1:=""
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Employee ID")
.Position = 2
ActiveSheet.PivotTables("PivotTable1").PivotFields("Employee ID").Subtotals = _
Array(False, False, False, False, False, False, False, False, False, False, False, False)
ActiveSheet.PivotTables("PivotTable1").PivotFields("Employee ID"). _
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Availability")
.Position = 3
ActiveSheet.PivotTables("PivotTable1").PivotFields("Availability").Subtotals = _
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Project Name")
.Position = 4
ActiveSheet.PivotTables("PivotTable1").PivotFields("Project Name").Subtotals = _
ActiveSheet.PivotTables("PivotTable1").PivotFields("Availability").ShowDetail = False
For ind = 1 To 12
' inserisce MESI in pivot
mesi_ris = MesiUnione(ind)
ActiveSheet.PivotTables("PivotTable1").AddDataField ActiveSheet.PivotTables( _
"PivotTable1").PivotFields(mesi_ris), " " & mesi_ris, xlSum
With ActiveSheet.PivotTables("PivotTable1").PivotFields(mesi_ris)
.Caption = mesi_ris
'formatto dati
Rows("6:6").Select
Selection.Replace what:="Etichette di riga", Replacement:="RESOURCE NAME", LookAt:=xlPart, _
searchorder:=xlByRows, MatchCase:=False, SearchFormat:=False, _
ReplaceFormat:=False
Columns("C:O").Select
With Selection
.HorizontalAlignment = xlCenter
.VerticalAlignment = xlCenter
.NumberFormat = "0.00"
Rows("1:5").Select
With Selection
.NumberFormat = "0"
Rows("6:6").Select
' nasconde list pivot e cambia formattazione righe e colonne
ActiveWorkbook.ShowPivotTableFieldList = False
Cells.Select
ActiveSheet.PivotTables("PivotTable1").ShowTableStyleColumnStripes = True
ActiveSheet.PivotTables("PivotTable1").ShowTableStyleRowStripes = True
' ActiveSheet.PivotTables("PivotTable1").TableStyle2 = "MyPivotStyleMedium2 2"
ActiveSheet.PivotTables("PivotTable1").TableStyle2 = "MyPivotStyleReport3 2"
' toglie griglia da foglio con Pivot
ActiveWindow.DisplayGridlines = False
' conta righe e colonne pivot
numcolPiv = Worksheets(Nome_sheet_pivot).Cells(6, Columns.Count).End(xlToLeft).Column
numrigPiv = Worksheets(Nome_sheet_pivot).Cells(Rows.Count, 1).End(xlUp).Row - 1
' da riga 4 ad ultima e per tutte le colonne formatta in base a valori
For riga = 7 To numrigPiv
tot_bench = 0
tot_over = 0
tot_partial = 0
tot_under = 0
tot_ok = 0
For colonna = 4 To numcolPiv
Availab = Cells(riga, 3)
a = Worksheets(Nome_sheet_pivot).Cells(riga, colonna).Value
Cells(riga, colonna).Select
If a = "" Then
tot_bench = 1
With Selection.Interior
.Pattern = xlSolid
.PatternColorIndex = xlAutomatic
.ColorIndex = 45
.TintAndShade = 0
.PatternTintAndShade = 0
If a = Availab Then tot_ok = 1: GoTo proseguo_format
If a > Availab Then
tot_over = 1
Selection.Font.Bold = True
Selection.Font.Color = 255
If (a > "0,00" And a <= "0,49") Then
tot_partial = 1
.Pattern = xlSolid
.ColorIndex = 40
.TintAndShade = 0
If (a > "0,49" And a <= "0,79") Then
tot_under = 1
.Pattern = xlSolid
.ColorIndex = 36
.TintAndShade = 0
proseguo_format:
If tot_bench = 1 And tot_partial = 0 And tot_under = 0 And tot_over = 0 And tot_ok = 0 Then totale_bench = totale_bench + 1: GoTo altro_rec
If tot_over = 1 Then totale_over = totale_over + 1: GoTo altro_rec
If tot_partial = 1 Then totale_partial = totale_partial + 1: GoTo altro_rec
If tot_under = 1 Then totale_under = totale_under + 1: GoTo altro_rec
totale_ok = totale_ok + 1
altro_rec:
' inserisce legenda x colori e valori
Rows("1:1").Select
' trovo n° ultima colonna blank
colPivNumero = Selection.Cells(1, Selection.Columns.Count).End(xlToLeft).Column + 3
colPivLet = Cells(1, colPivNumero).Address(True, False)
colPivLettera = Split(colPivLet, "$")(0)
rigaPiv = 1
Range(Cells(rigaPiv, colPivNumero - 1), Cells(rigaPiv, colPivNumero - 1)).Select
Range(Cells(rigaPiv, colPivNumero - 1), Cells(rigaPiv + 4, colPivNumero - 1)).MergeCells = True
With Selection.Font
.Bold = True
.Size = 12.5
.TintAndShade = 0
With Selection
With Selection.Borders
.LineStyle = xlContinuous
.Weight = xlMedium
.ColorIndex = xlAutomatic
descriz_prova = "Legenda" & Chr(13) & Chr(10) & "e" & Chr(13) & Chr(10) & "Totali"
ActiveCell.FormulaR1C1 = descriz_prova
Range(Cells(rigaPiv, colPivNumero), Cells(rigaPiv, colPivNumero + 2)).Select
With Selection.Font
.Bold = True
.Color = 255
.TintAndShade = 0
With Selection
.Weight = xlMedium
Range(Cells(rigaPiv, colPivNumero), Cells(rigaPiv, colPivNumero)).Select
ActiveCell.FormulaR1C1 = totale_over
Range(Cells(rigaPiv, colPivNumero + 1), Cells(rigaPiv, colPivNumero + 1)).Select
ActiveCell.FormulaR1C1 = "Overallocation"
Range(Cells(rigaPiv, colPivNumero + 2), Cells(rigaPiv, colPivNumero + 2)).Select
ActiveCell.FormulaR1C1 = "'> Availability"
Range(Cells(rigaPiv + 1, colPivNumero), Cells(rigaPiv + 1, colPivNumero + 2)).Select
With Selection.Font
.Bold = True
.ColorIndex = 5
.TintAndShade = 0
With Selection
.Weight = xlMedium
Range(Cells(rigaPiv + 1, colPivNumero), Cells(rigaPiv + 1, colPivNumero)).Select
ActiveCell.FormulaR1C1 = totale_ok
Range(Cells(rigaPiv + 1, colPivNumero + 1), Cells(rigaPiv + 1, colPivNumero + 1)).Select
ActiveCell.FormulaR1C1 = "Filled"
Range(Cells(rigaPiv + 1, colPivNumero + 2), Cells(rigaPiv + 1, colPivNumero + 2)).Select
ActiveCell.FormulaR1C1 = "0,80>=<1,00"
Range(Cells(rigaPiv + 2, colPivNumero), Cells(rigaPiv + 2, colPivNumero + 2)).Select
.Pattern = xlSolid
.ColorIndex = 36
.TintAndShade = 0
With Selection
.Weight = xlMedium
Range(Cells(rigaPiv + 2, colPivNumero), Cells(rigaPiv + 2, colPivNumero)).Select
ActiveCell.FormulaR1C1 = totale_under
Range(Cells(rigaPiv + 2, colPivNumero + 1), Cells(rigaPiv + 2, colPivNumero + 1)).Select
ActiveCell.FormulaR1C1 = "Underallocation"
Range(Cells(rigaPiv + 2, colPivNumero + 2), Cells(rigaPiv + 2, colPivNumero + 2)).Select
ActiveCell.FormulaR1C1 = "0,50>=<0,79"
Range(Cells(rigaPiv + 3, colPivNumero), Cells(rigaPiv + 3, colPivNumero + 2)).Select
.Pattern = xlSolid
.ColorIndex = 40
.TintAndShade = 0
With Selection
.Weight = xlMedium
Range(Cells(rigaPiv + 3, colPivNumero), Cells(rigaPiv + 3, colPivNumero)).Select
ActiveCell.FormulaR1C1 = totale_partial
Range(Cells(rigaPiv + 3, colPivNumero + 1), Cells(rigaPiv + 3, colPivNumero + 1)).Select
ActiveCell.FormulaR1C1 = "Partial Bench"
Range(Cells(rigaPiv + 3, colPivNumero + 2), Cells(rigaPiv + 3, colPivNumero + 2)).Select
ActiveCell.FormulaR1C1 = "<=0,49"
Range(Cells(rigaPiv + 4, colPivNumero), Cells(rigaPiv + 4, colPivNumero + 2)).Select
.Pattern = xlSolid
.ColorIndex = 45
.TintAndShade = 0
With Selection
.Weight = xlMedium
Range(Cells(rigaPiv + 4, colPivNumero), Cells(rigaPiv + 4, colPivNumero)).Select
ActiveCell.FormulaR1C1 = totale_bench
Range(Cells(rigaPiv + 4, colPivNumero + 1), Cells(rigaPiv + 4, colPivNumero + 1)).Select
ActiveCell.FormulaR1C1 = "Bench"
Columns("A:O").Select
Columns("A:O").EntireColumn.AutoFit
ThisWorkbook.Worksheets(Nome_sheet_pivot).Cells.EntireColumn.AutoFit
Rows("7:7").Select
ActiveWindow.FreezePanes = True ' blocca le righe iniziali per lo scrolling
