Private Declare Sub keybd_event Lib "user32" (ByVal bVk As Byte, ByVal bScan As Byte, ByVal dwFlags As Long, ByVal dwExtraInfo As Long)
Private Declare Function MapVirtualKey Lib "user32" Alias "MapVirtualKeyA" (ByVal wCode As Long, ByVal wMapType As Long) As Long
Private Const WM_CLOSE = &H10
Private Const VK_MENU = &H12
Private Const VK_SNAPSHOT = &H2C
Private Const KEYEVENTF_KEYUP = &H2
Private Declare Sub Sleep Lib "kernel32.dll" (ByVal dwMilliseconds As Long)
Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
Private Declare Function ShowWindow Lib "user32" (ByVal hwnd As Long, ByVal nCmdShow As Long) As Long
Private Const SW_SHOWMAXIMIZED = 3
Public Sub SaveImageActiveWindow()
'// Ivan F Moala //
'// For my friend Colo //
Dim Altscan As Double
On Error GoTo ErrHandler
'// Copy picture into the clip board.
Altscan = MapVirtualKey(VK_MENU, 0)
keybd_event VK_MENU, Altscan, 0, 0
keybd_event VK_SNAPSHOT, 0, 0, 0
keybd_event VK_MENU, Altscan, KEYEVENTF_KEYUP, 0
Application.Wait Now + TimeSerial(0, 0, 1)
SavePicture PastePicture(xlBitmap), "C:Users502390548DesktopAWBTest.bmp"
ErrHandler:
'// Error handling
MsgBox Err.Number & ":= " & Err.Description
Private Sub UserForm_Click()
MsgBox "Done !"
Sub Snapshot()
Dim IE As Object
Dim hwnd As Long, IECaption As String
Set IE = CreateObject("InternetExplorer.Application")
IE.Visible = True
IE.Navigate "INDIRIZZO DELLA DHL" & Cells(2, 1)
Sleep 2000
'~~> Get the caption of IE
IECaption = "Rintracciare, Rintracciare le spedizioni | Ricerca spedizioni di DHL Express - Windows Internet Explorer"
'~~> Get handle of IE
hwnd = FindWindow(vbNullString, IECaption)
If hwnd = 0 Then
MsgBox "IE Window Not found!"
'~~> Maximize IE
ShowWindow hwnd, SW_SHOWMAXIMIZED
Sleep 1000
DoEvents
'~~> Take a snapshot
Call keybd_event(VK_SNAPSHOT, 0, 0, 0)
'=========ALTRO CODICE=========================
SavePicture PastePicture(xlBitmap), "C:Users502390548DesktopDHL " & Cells(2, 1) & ".bmp"
ErrHandler:
'// Error handling
Sub Snapshot1()
Dim IE As Object
Dim i As String
i = 2
While i <> ""
IE.Visible = True
IE.Navigate "INDIRIZZO DHL" & Cells(i, 1)
Sleep 2000
If hwnd = 0 Then
'~~> Maximize IE
Sleep 1000
DoEvents
SavePicture PastePicture(xlBitmap), "C:Users502390548DesktopPOD DHLDHL " & Cells(i, 1) & ".bmp"
ErrHandler:
'// Error handling
Windows("SalvareScreenshot.xls").Activate
i = i + 1
Wend
