Private Sub cmdCaricapromo_Click()
Dim Unione As Range
Dim c1, c2, c3 As Range
Dim wb As Workbook
Dim FinalRow As Long
Dim Percorso As String, promo As String
FinalRow = Cells(Rows.Count, 1).End(xlUp).Row
Range("K4:K" & FinalRow) = Array(1292)
Set c1 = Range("K4:K" & FinalRow)
Set c2 = Range("A4:A" & FinalRow)
Set c3 = Range("J4:J" & FinalRow)
Set Unione = Union(c1, c2, c3)
Unione.Copy
Set wb = Workbooks.Add
Selection.PasteSpecial Paste:=xlPasteValues
wb.Activate
Range("C:C").Select
Selection.Cut
Range("A:A").Select
Selection.Insert Shift:=xlToRight
promo = InputBox("Salva Con Nome") & ".csv"
Percorso = "S:Preordini Preas_Pdv"
ActiveWorkbook.SaveAs Filename:=Percorso & promo, FileFormat:=xlCSV
Dim Unione As Range
Dim wb As Workbook
Unione.Copy
With ActiveSheet
.Range("C:C").Select
Selection.Cut
.Range("A:A").Select
Dim wbFrom As Workbook, wbTo As Workbook
Dim wsFrom As Worksheet, wsTo As Worksheet
With Application
Set wbFrom = ThisWorkbook
Set wsFrom = wbFrom.Worksheets(1)
Set wbTo = Application.Workbooks.Add
Set wsTo = wbTo.Worksheets(1)
'come la volta scorsa, se di default crei un .xls invece che un .xlsx/xlsm potresti incasinarti
FinalRow = wsFrom.Cells(wsFrom.Rows.Count, 1).End(xlUp).Row '''''''''''''''''''''''''''''''''''
wsTo.Range("A1:A" & FinalRow - 3) = 1292
wsTo.Range("B1:B" & FinalRow - 3) = wsFrom.Range("J4:J" & FinalRow).Value
wsTo.Range("C1:C" & FinalRow - 3) = wsFrom.Range("A4:A" & FinalRow).Value
wbTo.SaveAs Filename:=Percorso & promo, FileFormat:=xlCSV
With Application
Set wbFrom = Nothing
Set wsFrom = Nothing
Set wbTo = Nothing
Set wsTo = Nothing
Call Accendi(False)
Call Accendi(True)
Set wbTo = Nothing
Set wsTo = Nothing
Sub Accendi(ByVal bApp As Boolean)
With Application
.ScreenUpdating = bApp
.EnableEvents = bApp
wsTo.Range("C1:C" & FinalRow - 3).NumberFormat = "000000" 'RIGA AGGIUNTA |
Dim rC1 As Range
Call Accendi(False)
''COPIO CELLE VISIBILI COLONNA A
Set rC1 = wsFrom.Range("A4:A" & FinalRow)
rC1.SpecialCells(xlCellTypeVisible).Copy Destination:=wsTo.Range("B1")
''COPIO CELLE VISIBILI COLONNA J
Set rC1 = wsFrom.Range("J4:J" & FinalRow)
rC1.SpecialCells(xlCellTypeVisible).Copy Destination:=wsTo.Range("C1")
''RICALCOLO ULTIMA RIGA SU NUOVO FILE
FinalRow = wsTo.Cells(wsTo.Rows.Count, 2).End(xlUp).Row
wsTo.Range("A1:A" & FinalRow) = 1292
wsTo.Range("B1:B" & FinalRow).NumberFormat = "000000"
Percorso = "C:ProveFiles"
'PERSONALMENTE AGGIUNGEREI CHIUSURA DEL FILE E POSIZIONAMENTO SU CARTELLA IN CUI E' SALVATO:
wbTo.Close vbNo
Call Shell("Explorer.exe " & Percorso, vbNormalNoFocus)
Call Accendi(True)
Set wbTo = Nothing
Set wsTo = Nothing
With Application
