Dim Msg1 As String, Msg2 As String
Msg1 = "La cella E5 contiene dati"
Msg2 = "La cella E5 non è valorizzata"
If Target.Address = "$E$5" Then
If Not IsEmpty([e5]) Then MsgBox Msg1 Else MsgBox Msg2
Sub Inserisci_Trattamento_Click()
' Macro
Sheets("Database").Select
Rows("2:2").Select
Selection.Insert Shift:=xlDown, CopyOrigin:=xlFormatFromLeftOrAbove
Range("A2").Select
Sheets("Home").Select
Range("E5").Select
Selection.Copy
:=False, Transpose:=False
Range("H5").Select
Selection.Copy
Range("B2").Select
Range("E7").Select
Selection.Copy
Range("C2").Select
Range("C2").Select
Range("H7").Select
Selection.Copy
Range("D2").Select
Range("E9").Select
Selection.Copy
Range("E2").Select
ActiveSheet.Paste
Range("H9").Select
Selection.Copy
Range("F2").Select
ActiveSheet.Paste
Range("E11").Select
Selection.Copy
Range("G2").Select
ActiveSheet.Paste
Range("H11").Select
Selection.Copy
Range("H2").Select
ActiveSheet.Paste
Range("E13").Select
Selection.Copy
Range("I2").Select
ActiveSheet.Paste
Range("H13").Select
Selection.Copy
Range("J2").Select
ActiveSheet.Paste
Range("E15").Select
Selection.Copy
Range("K2").Select
ActiveSheet.Paste
Range("H15").Select
Selection.Copy
Range("L2").Select
ActiveSheet.Paste
Range("E17").Select
Selection.Copy
Range("M2").Select
ActiveSheet.Paste
Range("H17").Select
Selection.Copy
Range("N2").Select
ActiveSheet.Paste
Range("E19").Select
Selection.Copy
Range("O2").Select
ActiveSheet.Paste
'Elimina_Righe_Vuote
Dim Intervallo As Range
Dim Righe, R, Colonne, C, FL As Boolean
Set Intervallo = ActiveSheet.UsedRange
Righe = Intervallo.Rows.Count
Colonne = Intervallo.Columns.Count
For R = Righe To 1 Step -1
FL = False
For C = 1 To Colonne
If Intervallo(R, C) <> "" Then
FL = True
If FL = False Then
Intervallo(R, 1).EntireRow.Delete
'Pulusci foglio Home
Range("E5:E19").Select
Range("E5:E19").Activate
Selection.ClearContents
Range("H5:H19").Select
Range("H5:H19").Activate
Range("E5").Select
Sub verifica()
If Sheets("Home").Range("E5") = "" Then
MsgBox "Vuota"
MsgBox "Piena"
Ps nota la differenza con il Tuo e se ci fossero anche le variabili dei fogli sarebbe meglio
Sheets("Database").Rows("2:2").Insert Shift:=xlDown, CopyOrigin:=xlFormatFromLeftOrAbove
Sheets("Home").Range("E5").Copy
Sheets("Database").PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks:=False, Transpose:=False
Sub Inserisci_Trattamento_Click_Textomb()
Dim i As Integer
For i = 5 To 19 Step 2
Sheets("Home").Range("e" & i & ",h" & i).Copy
Sheets("Database").Cells(3, i - 4).PasteSpecial xlPasteValues
Sheets("Home").Range("e" & i & ",h" & i).ClearContents
' Macro1
Dim i As Integer
Sheets("Database").Cells(2, i - 4).PasteSpecial xlPasteValues
If Sheets("Home").Range("E5") <> "" Then
MsgBox "Non Hai inserito nessun dato"
MsgBox "Inserimento eseguito con successo"
FL = False
FL = True
If FL = False Then
Range("E5").Select
Dim i As Integer
If IsEmpty(Sheets("Home").Range("E5")) Then
Sheets("Home").Range("E5:E19,H5:H19").ClearContents
Sub Inserisci_Telefono_Click()
'Inserisci_Telefono
Dim i As Integer
Sheets("Telefono").Rows("2:2").Insert Shift:=xlDown
Sheets("Telefono").Cells(2, i - 4).PasteSpecial xlPasteValues
'Inserisci_Telefono
Sheets("Telefono").Range("a2").Value = Sheets("Home").Range("e5").Value
Sheets("Telefono").Range("b2").Value = Sheets("Home").Range("h19").Value
' Se vuoi cancellare le due celle E5 e H19 dal Foglio Home dovrai eseguire la seguente istruzione
Sheets("Home").Range("e5,h19").ClearContents
