Sheets(1).Select
Range("B:B").Select
Range("B1").Activate
Selection.NumberFormat = "dd/mm/yyyy"
With Selection
.HorizontalAlignment = xlLeft
.VerticalAlignment = xlBottom
.WrapText = False
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.ShrinkToFit = False
.ReadingOrder = xlContext
.MergeCells = False
Selection.Replace What:=".", Replacement:="/", LookAt:=xlPart, _
SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _
ReplaceFormat:=False
Range("H:H").Select
Range("H1").Activate
With Selection
.WrapText = False
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.MergeCells = False
ActiveSheet.Range("$B$1:$AC$999").AutoFilter Field:=7, Criteria1:= _
">" & Date, Operator:=xlAnd |
Sub Macro1() 'Testo in colonne
Columns("B:B").TextToColumns Destination:=Range("B1"), DataType:=xlDelimited, _
TextQualifier:=xlSingleQuote, ConsecutiveDelimiter:=False, Tab:=False, _
Semicolon:=True, Comma:=False, Space:=False, Other:=False, FieldInfo _
:=Array(1, 4), TrailingMinusNumbers:=True
Sheets(1).Select
ActiveSheet.Range("$b$1:$ac$999").Autofilter Field=7, Criteria1:= _
sub Trasforma_Testo
dim H
dim B
sheets(1).Select
Set H = Range("H1:H999")
Set B = Range ("B1:B999")
H.Select
Selection.TextToColumns Destination:=Range("H1"), DataType:=xlDelimited, _
B-Select
Selection.TextToColumns Destination:=Range("B1"), DataType:=xlDelimited, _
sheets(2).Select
H.Select
B-Select
Sub Filtra_AT_DE
dim Data
Data = Date
Sheets (1).Select
ActiveSheet.Range("$B$1:$AC$999").AutoFilter Field:=13, Criteria1:="=102", _
Operator:=xlOr, Criteria2:="=103"
ActiveSheet.Range("$B$1:$AC$999").AutoFilter Field:=9, Criteria1:="+"
">" & Data, Operator:=xlAnd
Sheets (2).Select
Data = Format(Date, "mm/dd/yyyy") ' all'inglese |
FieldInfo:=Array(1, 4) ' 1 = la prima colonna (H), 4 = tipo Data
