Sub cerca1()
Dim Lrow As Long, LR As Long, c As Range, Ir As Long, ISRC As String
Lrow = Sheets("Conflitti").Range("A" & Rows.Count).End(xlUp).Row
LR = Sheets("Tutti4").Range("A" & Rows.Count).End(xlUp).Row
Sheets("Tutti4").Range("A:A").Interior.ColorIndex = xlNone
For Ir = 2 To Lrow
ISRC = Sheets("Conflitti").Cells(Ir, 4)
With Sheets("Tutti4").Range("E2:E" & LR)
Set c = .Find(ISRC, LookIn:=xlValues)
If Not c Is Nothing Then c.Offset(0, -4).Interior.ColorIndex = 4
Next Ir
MsgBox "Terminato"
qui
Application.Calculation = xlManual ''sospende il calcolo delle formule
e qui
Next Ir
Application.Calculation = xlAutomatic ''riattiva il calcolo automatico
Calculate '' forza un calcolo = F9 su un foglio di excel
Sub ColoraCelleUguali()
'by Marius44
Dim i As Long, j As Long, uriga1 As Long, uriga2 As Long
Dim wks1 As Worksheet, wks2 As Worksheet
Dim Rng As Range
Dim RP, SH, itime, ftime
itime = Timer
Set wks1 = ThisWorkbook.Worksheets("Foglio1")
Set wks2 = ThisWorkbook.Worksheets("Foglio2")
Sheets("Foglio1").Select
uriga1 = wks1.Range("A" & Rows.Count).End(xlUp).Row
RP = wks1.Range(Cells(2, 1), Cells(uriga1, 1)).Value ''''
Sheets("Foglio2").Select
Set Rng = Range("A2:A" & Range("A" & Rows.Count).End(xlUp).Row)
Rng.Interior.ColorIndex = xlNone
uriga2 = wks2.Range("A" & Rows.Count).End(xlUp).Row
SH = wks2.Range(wks2.Cells(2, 1), wks2.Cells(uriga2, 1)).Value
For i = 2 - 1 To uriga1 - 1
If RP(i, 1) <> "" Then
For j = 2 - 1 To uriga2 - 1
If RP(i, 1) = SH(j, 1) Then
wks2.Cells(j, 1).Interior.ColorIndex = 4
Next j
Set wks1 = Nothing
Set wks2 = Nothing
ftime = Timer
Cells(2, 5) = ftime - itime
MsgBox "Fatto!", vbExclamation
Cit: Non riesco a scaricare il file,il copia/incolla ha alterato il link
Io ho solo inserito la punteggiatura in "www dropbox com" per scaricare il file.
'by Marius44
Dim Rng As Range
itime = Timer
Set wks1 = ThisWorkbook.Worksheets(1)
Set wks2 = ThisWorkbook.Worksheets(2)
Sheets(1).Select
Sheets(2).Select
Set Rng = Range("E2:E" & Range("A" & Rows.Count).End(xlUp).Row)
uriga2 = wks2.Range("E" & Rows.Count).End(xlUp).Row
SH = wks2.Range(wks2.Cells(2, 5), wks2.Cells(uriga2, 5)).Value
wks1.Cells(2, 8) = Now
Next j
wks1.Cells(3, 8) = Now
Set wks1 = Nothing
Set wks2 = Nothing
ftime = Timer
Cells(5, 8) = ftime - itime
Public Sub Colora_Celle()
Dim S1 As Worksheet, S2 As Worksheet
Dim V1 As Variant, V2 As Variant
Dim uR1 As Long, uR2 As Long, R1 As Long, R2 As Long
Dim T1 As Single
T1 = Timer
Set S1 = Sheets("Foglio1")
Set S2 = Sheets("Tutti2016_1")
With S1
uR1 = .Cells(Rows.Count, "A").End(xlUp).Row
V1 = .Range("A1:A" & uR1)
With S2
uR2 = .Cells(Rows.Count, "E").End(xlUp).Row
V2 = .Range("E1:E" & uR2)
S2.Range("A:A").Interior.ColorIndex = xlNone
For R1 = 2 To uR1
For R2 = 2 To uR2
If V1(R1, 1) = V2(R2, 1) Then
S2.Cells(R2, 1).Interior.ColorIndex = 4
Next R2
Next R1
MsgBox Format((uR1 - 1) * (uR2 - 1), "standard") & " confronti" & vbCrLf & "in: " & Timer - T1 & " secondi."
Set S1 = Nothing
Set S2 = Nothing
'by Marius44
Dim Rng As Range
itime = Timer
Set wks2 = ThisWorkbook.Worksheets("Tutti2016_1")
Sheets(1).Select
Sheets(2).Select
wks2.Cells(j, 1).Interior.ColorIndex = 9
Next j
Set wks1 = Nothing
Set wks2 = Nothing
ftime = Timer
itime = Timer
Set wks2 = ThisWorkbook.Worksheets("Tutti2016_2")
Sheets(1).Select
Sheets(2).Select
Next j
Set wks1 = Nothing
Set wks2 = Nothing
ftime = Timer
Sub ColoraCelleUguali() ‘versione con ciclo per i Fogli
'by Marius44
Dim Rng As Range
itime = Timer
wks1.Cells(2, 8) = Now ‘riga spostata
Sheets(1).Select
‘inizio ciclo per fogli
For fg = 2 to Sheets.Count
Set wks2 = ThisWorkbook.Worksheets(fg) ‘fg è il numero del Foglio
Sheets(fg).Select
Next j
Next fg
Set wks1 = Nothing
Set wks2 = Nothing
ftime = Timer
